Projects Finally I get my Flathead powered T Roadster
Discussion in 'Traditional Hot Rods' started by mctim64, Dec 4, 2014.
  1. Rocky
    Rocky
    Classified Editor
    Kyra has beautiful teeth. Love the roadster project.
    chryslerfan55, Spoggie and hendelec like this.
  2. Jalopy Joker
    Jalopy Joker
    Cool -looks great
  3. Great start and the attention to detail right off the bat! Luv it!
  4. Swiss50chevy
    Swiss50chevy
  5. dehartcarl
    dehartcarl
    subscribed
  6. 36tudordeluxe
    36tudordeluxe
    I gotta go with Larry on this one and the "T" isn't bad either.
    3wLarry, daddio211 and mctim64 like this.
  7. glrbird
    glrbird
    I was wondering what you were up to.
    mctim64 likes this.
  8. flatblackdave
    flatblackdave
  9. Blue One
    Blue One
    from Alberta
    Outback, Jigger, steinauge and 3 others like this.
  10. Frankly Larry I like the A frame look better. Call me weird, just how I am.
    Outback, Blue One, clem and 3 others like this.
  11. daddio211
    daddio211
    Thanks for the link, I'm in too! Hope you don't finish yours before mine is done. LOL
    mctim64 likes this.
  12. Blue One
    Blue One
    from Alberta
    OK Tim, you're weird ;) But in a good way :D
    Larry.
    volvobrynk and dana barlow like this.
  13. 64 DODGE 440
    64 DODGE 440
    from so cal
    At the rate Tim builds at it will probably be done by Christmas. ;)
    brsturges and daddio211 like this.
  14. I just hope by next October.
  15. A Boner
    A Boner
    Building quick change is a lot of work for one person. I always thought it would be a neat idea if a group of friends got together and built some. With each person doing his specialized talent, engineering, parts person, tig welding, machining, metal finishing, ect.
    Does anyone have any blueprints or plans to build a quick change using a V8 Ford rear end?
    Outback and volvobrynk like this.
  16. Marty Strode
    Marty Strode
    A *****, building a converted QC, can be a tough slog. The biggest problem that I see, is getting the lower shaft and housing "dead pa 2012-07-03 170107.jpg 2012-07-03 185112.jpg rallel" to the existing pinion. With all of the welding involved, things move around a lot, making it difficult to pull off. Here is a shot of the "Bart Bilt" unit that I used in my Track Roadster, it was far from perfect but for $200 bucks, it worked OK.
  17. King ford
    King ford
    from 08302
    She sure is a realBEAUTY. ..I like your car plans and flathead too!
  18. Blue One
    Blue One
    from Alberta
    The key there would be to weld absolutely everything and then do all the machining afterwards. Problem solved :)
    volvobrynk and daddio211 like this.
  19. A Boner
    A Boner
    I'm not a machinist, but welding first, then doing the machining sounds like a plan. Now all we need are the critical dimensions.
  20. 51farmtruck
    51farmtruck
    Thanks Marty and Mctim. I hope some more info pops up on his QC.
  21. bone31
    bone31
    Tim
    I will post the build of the q.c. from start to finish.First thing is a center section from 1935 to 1948.I make everything only buy the bearings and steel.I am an old time tool and die maker six year aprentiship.No cnc stuff here
    Outback, GuyW, Brootal and 7 others like this.
  22. bct
    bct
    can't wait!
  23. Thank you Mike! I know there are many interested in seeing the process, myself included.
  24. Kiwi Tinbender
    Kiwi Tinbender
    Yep,Mike--add me to the list of interested parties.....can`t afford one though....
  25. I love the Halibrand in your T.
    You Probably got it cheaper than you'll be able piece another QC together!
  26. bone31
    bone31
    The q. c. center, many people have done this with a ford center, I have many pics of home made ones there are a lot on the hamb to look at.I think some were made before ww2 many in the late 40's.No one person made a bunch, just for there own use, a few for others maybe. every one made different to his way of thinkingI thought about mine for a long time, then when I saw a pic of one made in the middle 50's by Bill Parham from Portland Or. I said this is it because of the rear cover bearings that were not in the cover. Will post pics tomorrow.
    volvobrynk likes this.
  27. T&A Flathead
    T&A Flathead
    Nothing wrong with a T on an A frame.
    Outback, Lil'Alb, Jigger and 12 others like this.
  28. trosa54
    trosa54
