what did you get done today
Discussion in 'The Hokey Ass Message Board' started by 4rod, Mar 2, 2013.
  1. 340HilbornDuster
    340HilbornDuster
    Howzit Jack...
    (sssh! It's fuel injected....)
    Don't worry...I wont tell anyone here!..
    Which system are you running?
    Aloha
    Tommy
  2. jack_pine
    jack_pine
    from Motor City
    I'm running the Holley EFI. The newer stuff. This one is plug and play TBI since the '68 340 is basically stock. 14mpg and until that photo was taken, it started up in any weather.
  3. junkyardjeff
    junkyardjeff
    Put the carb spacer and Holley back on my custom 500 today,I think I let the cab sit a little too long while I found a spacer with a pcv port (4 years) and now the pump diaphram is leaking a little so I picked one up while I went out for food.
  4. Moby
    Moby
    Cleaned a half barrel of really stinky mouse nest out from behind the seat of a 26 roadster. It was so totally packed I think the mice had to move out!
  5. nmpontiac
    nmpontiac
    from Taos, NM
    Got one of the pitted F-1 backing plates blasted, shot with high build primer, sanded and painted black. Started on the other one and my gl*** beader started acting up from the high humidity. Ran the heat gun down in the pressure pot and dried things out - time to quit.
  6. NAES
    NAES
    Kinda swinging on my own nuts right now. Finally got the truck suspension dialed to lay frame. All fabbed at home, no kits. Big C-notch out back. 3" Z up front. 1 3/4" crossmember pancake. 3" cupped lower A-arms. Pie cut uppers. Next $ item is an air ride kit. Hoping for a Pomona score tomorrow!
  7. seb fontana
    seb fontana
    from ct
    Fixed the dog"s tie out lead..Did some putor stuff and garage roaming about trying to figure out how to arrange stuff and get the vacuum , had a nap to think about it, drew up some plans for more shelves for HF cabinets and thats about it..So not much..
  8. walter
    walter
    Good Day!!! Top of cowl install, door hinge install, floor pan, tail lights, and license plate lamp.
    Walter
  9. HOTRODPRIMER
    HOTRODPRIMER
    Cleaned up the shop and changed oil in the sedan,and watched it rain! HRP
  10. 31ford429
    31ford429
    from Florida
    Hung some Christmas lights cause the wife told me that was what I was going to be doing today
    Look at that Cadillac
  11. timwhit
    timwhit
    Added some anti-freeze to cabrio and cut out a door panel pattern...out in the driveway. Got pretty cold.
  12. 340HilbornDuster
    340HilbornDuster
    Yesterday my radiator grenaded...($10 radiator cap from O'Realy's...)
    Today:
    Did some metal work for a hour.
    My butch cat Ivar showed up with a big hole in his neck.
    Dropped him at the vet...
    Came out...wifes car didn't start...
    Alternator bad..
    Walked to O'Realys..(no choice)
    Got battery, alternator, belts & $7 wrench.
    Returned battery, alettnator core and one belt....picked up butch...
    (Shaved head & neck+ big scar.)
    Now back to the Phaeton...
    Tommy
  13. SanDiegoHighwayman
    SanDiegoHighwayman
    only one "save" today but made, MY day, as well, DOING it
    THEN -- I'd made a call to KUSI about the vandalism - theft that occurred @ the Dusty Rhoads dog park last nite or yesterday -- went back to and met a KUSI cameraman reporter there for the story -- it'll be aired 10pm tonite - and headin home i come across this fella OOG -- simplest thing I do -- took less then 5 minutes and he was on his way SO - -I got to do ANUTHER save today yippie! that was FUN -- now, to see if I'm still awake @ 10pm to see if the dog park story airs I'm tuckered --
    "}" data-reactid=".c" style="color: rgb(109, 132, 180); cursor: pointer;">Like · · Share
  14. jazz1
    jazz1
    I decided to start on the gas tank today. Easy enough to remove the gas tank in my '48 sedan delivery and check for holes,,a few the size of a quarter,,,and nesting materials inside tank. Seems any surface rust will reveal a rust hole. Those black circles mark a pinhole. This ****s!
  15. mad mikey
    mad mikey
    Nothing! Took a stress day.
  16. I've been polishing alloy rocker covers, by hand.
  17. Mike Miller
    Mike Miller
    Finished the cylinder heads for a 460 I'm building and worked a little in the 29 Studebaker.
  18. conormulroney
    conormulroney
    <--- I drove my truck around the block. Twice.
    4 months and 2 weeks to dis***emble down to the frame, swap cabs and build a fresh engine. Mostly in my driveway at night with hand tools.
    It was a great day!
    plumbid likes this.
  19. BIG-JIM
    BIG-JIM
    from CT
    Did anyone else see the red roadster fly by at about the 2:06 mark?
  20. captmullette
    captmullette
  21. daddio211
    daddio211
    Took photos for my wife's online boutique Sunday afternoon. My car, my front yard, wife's model and clothing line.
  22. seatex
    seatex
    Not a damn thing. It seems to be a disturbing new trend...................:(
  23. Mike Miller
    Mike Miller
    Got greasy, grimy, dirty, oily, discusted and angry working on my project while the wife stayed spotless working on her Studebaker. Think I'll just hand her tools from now on.
  24. missysdad1
    missysdad1
    Spent two days on and off finding and fixing the rattles, squeaks, thumps, bangs and groans coming from underneath my coupester. It's an old build that's been consistently neglected up until now. I'm the umpteeth owner and the first, apparently, to give a s**t about this kind of stuff. Dirty, greasy and dog tired but, damn, the car sure goes down the road nice now!
  25. I've had a bling day. Polished up these two old fire extinguishers for an old mate, and ordered and payed for a pair of stainless Guides.
    They going to take a while getting here. Air freight was going to cost $700 to $900!!!
    They on the boat, so will take at least a month.
    Top right light. IMG_20141208_144401.jpg IMG_20141209_125602.jpg 2014-10-07_1439.png
  26. bobss396
    bobss396
    1129141350a.jpg Got my '59 in the garage finally. Now the winter work can begin!
  27. BangBam
    BangBam
    Worked on cab hight and wheel spacing. If anyone is in the Orlando area florida mall, I could sure use some drinking buddies and free labor. Lol
    One truck, one welder, endless possibilities!
  28. Well yesterday I de-raked a '56 panhead frame, I still have to create new gussets and finish welding it up.
    Saturday I moved my 394 up to the garage for final ***embly. Once the bike frame is gone it will get its final ***embly and be **almost ready to go racin'.
    ** almost ready- will still need fine tuning, that happens at the track.
  29. Dick Stevens
    Dick Stevens
    Yesterday, other than the work around the house you don't care to hear about, I got in some garage time and cut out rusted floor pan in my 58 Biscayne and cleaned it up to get ready to weld in the replacement pan.
  30. jazz1
    jazz1
    took advantage of the fine weather and blasted the sedan delivery,,damn theres a lot of sheet metal on this car!
    got rid of the hideous paint
