Projects Only 15 First Hot Rod Build
Discussion in 'The Hokey Ass Message Board' started by v8juice, Jan 26, 2014.
  1. v8juice
    v8juice
    Thats a really cool picture. Thanks for the compliment.
  2. v8juice
    v8juice
    First of thanks for all of your help and encouragement. I'll be keeping the 318. This build is quite a learning experience for sure. Looking back at how little I knew about cars less than a year ago astounds me. I didn't even know what a cam was!!!
  3. v8juice
    v8juice
    Thanks for the info. I most likely will need some u-joints to clear the headers so this info is a great help. I don't think I could pay the $70 for the flaming river ones.
  4. Dick Stevens
    Dick Stevens
    For the crossmember, using the S10 would be a good idea and perhaps
    the easiest way to accomplish the desired results.
  5. v8juice
    v8juice
    Well I've been working on the plymouth almost every day since my last post. However I went out to weld some more of the floor supports last night and my harbor freight welder ****ped out. It seems like the motor that powers the wire feed went bad. Rather than trying to fix it I'm thinking about upgrading to a good welder like a Miller, Hobart or Lincoln. Do any of you guys have suggestions on good welders. I'm looking to spend under a grand if possible. Thanks
  6. missysdad1
    missysdad1
    I have all Miller welding and plasma cutting equipment and couldn't be happier. Miller has been courting the hot rod market for several years and offer several small but efficient MIGs that would do you nicely. They've got a great website that will answer all your questions. A word of advice: buy a welder that is a step or two above the minimum requirement for your needs even if you have to save for it. Doing this will insure that your welder can keep up with your growing skills.
    http://www.millerwelds.com/
  7. v8juice
    v8juice
  8. oldcars.acadia
    oldcars.acadia
    Hi Sam. I have the Miller 140 that works on 120 volt and it does very well on most jobs that I use a mig welder for. I also have a stick welder ( Old Lincoln tomb stone) for the heavy gauge work. The 140 has been replaced by the 141. Either that or the 190 should work ok for you. If you have 240 volt available everywhere you will be using the welder the 190 may be a little more versatile for heavy work. I have found that I use mine away from the shop at times and the 120 volt is more convenient. Hope you are making good progress.
    Bob
  9. This will be a great project for you, take your time , you'll learn much to stay with you in later life, good luck.
  10. v8juice
    v8juice
    I might get the 141 as I do have an old craftsman stick welder. It burns through anything thinner than like 3/16". I'll still probably get the 190 as I've been experimenting with some pretty heavy metal sculptures and furniture. The stick welder is quite difficult to use compared to a mig.
    Thanks
    1927graham likes this.
  11. v8juice
    v8juice
    Since I can't weld I've been cleaning the garage. Anyone want a free transmission lol ImageUploadedByH.A.M.B.1417301958.116282.jpg
    And here's a lamp I made for my moms birthday just before the welder quit. ImageUploadedByH.A.M.B.1417302071.410190.jpg ImageUploadedByH.A.M.B.1417302104.395699.jpg
  12. oldcars.acadia
    oldcars.acadia
    That's creative Sam. The trans looks like a 58 to 64 Chevy.
  13. v8juice
    v8juice
    Thanks! I found the trans in my backyard a couple summers ago. I had just ***umed it came out of the 1950 chevy that it was next to. It'll probably end up as a lamp or something :D
  14. v8juice
    v8juice
    Here's my new welder. It's a miller 211. It's definitely much better than the harbor freight welder.
  15. missysdad1
    missysdad1
    Congratulations!
  16. oldcars.acadia
    oldcars.acadia
    Very nice addition Sam.
  17. v8juice
    v8juice
    Thank you
  18. v8juice
    v8juice
    I had today off because of the weather so I worked on floor supports. I'll post up some pictures this weekend when I have some time. Since I'm using the plymouth fury radiator how should I mount it? Do I need rubber mounts? Thanks for any help.
  19. oldcars.acadia
    oldcars.acadia
    Not sure of the type of radiator that you are using. If it has flanges on the sides with bolt holes it bolts directly to the core support. If it is the more common late cross flow type, it will sit in cradle brackets at the side tanks and will have rubber insulator pads at the top and bottom. If you still have the 6 cyl radiator it would probably work OK in the Maine temperatures.
    Bob
  20. hotrodderhaag
    hotrodderhaag
    i just stumbled on tis thread... wow.... 15 years old... un real.... Keep working at it.. your doing a hell of a job. the progress is amazing and your skills are insane. glad to see such a young guy building the car HE wants..
    always keep that in mind, the hamb is a great place for ideas and advice.. but always build your cars to what YOU want, dont try to please others.. That way down the road, you know that the choices you made were made by you and it the car YOU want.
    keep up the excellent work and post lots of pics! pictures make a build thread. it makes it exciting and alot more fun to read! NICE JOB!!
  21. v8juice
    v8juice
    Thank you! I'll make sure I post lots of pictures.
  22. v8juice
    v8juice
    I made two body mounts yesterday ImageUploadedByH.A.M.B.1418526036.578117.jpg then I ran the exhaust back to the axle and tore some stuff out from behind the dash so I can finish the firewall ImageUploadedByH.A.M.B.1418526139.693618.jpg I'm going to use a transmission cooler and a small fan for a heater. So I don't need the little 6 volt fan and the controls.
  23. oldcars.acadia
    oldcars.acadia
    Nice looking welds Sam. Have you found the Miller an improvement over the Harbor Fright ??
  24. missysdad1
    missysdad1
    Looking good! While the ****** cooler heater is a very clever idea you'd probably be better served by one of the many styles of add-on heaters that were common in '40s cars. They bolt to the inside of the firewall wherever you have room and are easy to hook up. They can be powered up using a voltage drop device of sufficient amperage or replace the original 6-volt electric fan motor with a 12-volt motor. You might even get lucky and find one that's already 12-volts, they are around. Keep up the good work...and stay warm!
  25. oldcars.acadia
    oldcars.acadia
    MissysDad1 has good advise on the trans cooler heater. The small diameter tubes in the trans cooler may restrict the hot water flow and produce minimal heat. A heater core and a fabricated box may be a better choice. Save the Plymouth control as those dashes were nice looking and the control and switches can be used with 12 volts .
  26. v8juice
    v8juice
    Thanks. The Miller is definitely a huge improvement over the harbor freight welder.
    Thank you. Your probably right about the trans cooler heater. I might still try it as I am getting a free trans cooler from a friend at school. If it doesn't work I can switch to an add-on heater.
    I guess I didn't really think about the trans cooler having smaller diameter tubes. Don't worry I'm saving all of the switches and parts even if I'm not using them.
  27. v8juice
    v8juice
    For Christmas my dad is getting me stuff to wire the car. Should I have him get me a wiring kit like a rebel wire or just have him get a fuse panel and switches and everything else separately. I have the whole wiring harness from the Fury and some really cool switches including a dimmer switch which is actually worth more than I payed for the whole engine and trans. Anyway I don't want to get a kit only to find I still need to buy a whole bunch of parts. Thanks for any advice.
  28. missysdad1
    missysdad1
    I'd go for a kit every time. Do some research to see what comes in each kit from the major suppliers and choose the one that fits your needs best. All the info is on their websites online. Your car will be fairly simple - no power windows, power doors, high-end stereo, air conditioning or other fancy electronic stuff - so one of the basic "complete" kits should do you just fine. What a great Christmas gift from your Dad!
  29. oldcars.acadia
    oldcars.acadia
    Nice Christmas gift. Several decisions you need to make before ordering wiring components. Steering column choice is the first. If you use the Fury column than the fury harness is a possibility as the directionals, dimmer and ignition will all plug in. Any other column and a lot of sorting will be necessary. The fury harness will be primarily a source for wire as a lot will need to be eliminated or rerouted. The best option is a basic wiring kit as it will come with the wires labeled every 6 inches as to the circuit and with most of the necessary terminal ends. They can be ordered to plug into a specified steering column or if you use your original 49 Plymouth column you can get a harness that will work with the basic signal switch, floor dimmer switch and a dash mounted key switch. Trying to buy coils of wire and the terminals separate, and the time to figure it out is often more expensive and a heck of a lot more aggravation then the basic wiring kits. Talk to the kit vender or company to get what you need.
    Bob
  30. mohr hp
    mohr hp
    from Georgia
    Keep plugging away kid! I was in your same shoes 35 years ago. Young and inexperienced and not having parental guidance can be overcome. At least for you there's this wealth of info any time. I love how you hit snags, show pics of a problem that stops many more experienced guys dead in their tracks, then a couple posts later you've worked out a solution. You've obviously got the necessary level of stick-to-it-ivism to finish this as your own, home built, running hot rod. Bravo! Your level of determination will carry you through so many other aspects of life. Carry on!
