Technical question on Fillers /Bondo
Discussion in 'Traditional Hot Rods' started by blazedogs, Dec 6, 2014.
  1. blazedogs
    blazedogs
    Well after all the welded seams new metal roof insert, patch panels, even after grinding down all the welds ,there will be a lot of bondo required on our 29 Model A. There a a lot of different ones on the market,fibergl*** stranded ,ultra light bondo.different brands etc. From your experience what is the best brand and best quality to use? Gene
  2. walker
    walker
    Just chat with the guys at the body shop supply place. I have had good luck with the lightweight blueish one, as well as the ones with the kitty hair, depends on your application. I never use more than a light coat, YMMV.
  3. metlmunchr
    metlmunchr
    Most body shop supply houses will stock Fibergl*** Evercoat products. Best fillers on the market. Stay away from anything in the chain parts stores.
  4. Slopok
    Slopok
    Rage.....Made by Evercoat.
    49ratfink, JimSibley and Texas57 like this.
  5. matthew mcglothin
    matthew mcglothin
    Can't go wrong with evercoat products. They make a nice plastic filler.
  6. timwhit
    timwhit
    Evercoat's evergl*** is recommended for rough areas or over welds and places like door edges. Its very durable and strong. They have other products for use over the evergl***. Tim
  7. loveoftiki
    loveoftiki
    from Livonia,Mi
    You need to use a fibergl*** reinforced filler over your welds. Check out 3M's short strand fibergl*** reinforced filler.....easy to spread and sands better than some other fibergl*** fillers
  8. Autodave
    Autodave
    from Menifee,Ca
    Evercoat Rage or Rage Gold for a filler. Evercoat Metal Glaze for a finishing glaze.
  9. blazedogs
    blazedogs
  10. blazedogs
    blazedogs
    The same as painting the temp has to be rather high before applying : Now that Winter is here in Minnesota and the temps have been around zero to 25 degrees and my shop is not that well insulated with too small of a furnace, can I still lay bondo at around 50 to 60 degrees ?
  11. Autodave
    Autodave
    from Menifee,Ca
  12. David Totten
    David Totten
  13. David Totten
    David Totten
    As said Rage gold is a premium bondo one of the best. The best economy bondo is Zgrip. Just my opinion.
  14. 41GASSER
    41GASSER
    Rage, I have found that cheap fillers will load your paper when you begin sanding. All fillers do this to some degree however rage seems to need a light scuff then sands nicely. Used it for years and no issues.
  15. indyjps
    indyjps
    Using evercoat products now, what a difference, this stuff is worth the money.
    Blazedogs, if you're working in a colder shop, don't be tempted to bump up the hardener, just mix as directed and it will cure, may take longer, a drop light on a stand with a heat bulb is useful, it will heat the filler and surrounding metal, slow temps changes, don't go after it with a heat gun.
  16. JOYFLEA
    JOYFLEA
    Went to a sheet metal cl*** with Gene Winfield last mounth and asked this ? Gene said , if he's not leading he always uses gl*** reniforced bondo over weld .
  17. tedley
    tedley
    from canada
    I use napa brand. Same as rage but cheaper. Same as the glaze. I never use any kind of fibergl***. If you need to do a deep fill then maybe. Over 40 yrs in the trade here.
  18. OLDSMAN
    OLDSMAN
    I use 3M Platnum Plus. This filler sands super easy, and has virtually no pin holes like a lot of cheaper fillers have. It costs more, but I found I used less to get the job done
  19. joeycarpunk
    joeycarpunk
    from MN,USA
    I've always liked anything by Evercoat but really didn't see a big difference using rage over z grip for the cost difference.
  20. loveoftiki
    loveoftiki
    from Livonia,Mi
    Ding ding ding.....we always put a fibergl*** reinforced filler over all welded panels....
  21. ago
    ago
    from pgh. pa.
    Go to David Mann"s site (roadsters .com) and read about body filler from a man that sold it for years. I believe his last name is REED.
    ago
  22. ago
    ago
    from pgh. pa.
    Using body filler, by Reed Overson on Roadsters .com
    Ulu likes this.
  23. chopolds
    chopolds
    from howell, nj
    I don't know. I see lots of guys who swear that this and that product is the best, but I've been using all sorts of different brands for over 35 years, and except for ease of sanding, or less pinholing, I dont' see any difference in long term durability of any of the major brand fillers. As long as your metalwork underneath is good, any of the major players will work, and work well. It does help to seal the backsides of any welding with a good rustproof coating ( I use POR 15 or Master Series), in case there's an imperceptible pinhole. I really think the fibergl*** stranded stuff is a big waste, unless you only tack weld stuff together, or are real sloppy with your metalwork, same with "all metal" fillers waste of money and takes longer to sand out.
    And yeah, I've got cars out there I did over 30 years ago that still look good where I repaired them.
    49ratfink likes this.
  24. tedley
    tedley
    from canada
    I totally agree chopolds. I never use that butcher bondo either. It'a band aid.There is adhesion problems down the line. Fibergl*** and metal makes a poor bond.
  25. rocketsled59
    rocketsled59
    Short strand fibergl*** reinforced filler over weld seams. Or metal filler like all metal. And wire wheel that weld seam first. Rage gold is really good but I recently started using USC pro gold. **** kicks *** and cost less than rage gold. And they all pinhole. Gonna have to glaze pinholes. Or squeegee with filler again.My .02 Over thirty years experience. Good luck! RS59
  26. raymay
    raymay
    I learned from body men years ago that an aggressive reinforced filler over welds works best. I am definitely not a pro but I have had good results with products like USC All Metal, the Evercoat reinforced fillers and I am now kind of liking the U-Pol Fiberall product. It is much easier to work with than the old Tigerhair products I thought were great in the 70's.
    Once I get the establish level or shape needed with the reinforced filler, I use the lighter weight fillers for the final finish.
  27. Rusty O'Toole
    Rusty O'Toole
    You can apply filler at 50 - 60 degrees especially if you warm the work area with a radiant heater or quartz work light.
  28. Boeing Bomber
    Boeing Bomber
    Yep. That's what us proffessionals use.
  29. 66gmc
    66gmc
    another one for 3m platinum plus, its definitely worth the extra money. It takes less sandpaper to knock it down, and doesn't require a full skim coat of putty to get rid of pinholes.
    Rage gold was probably the best filler 10-15 years ago, but there are much better products on the market now.
    I have never used much of the fibergl*** filler, but i have seen it crack and lift when put over top of bad metalwork just as easily as regular filler.
    After welding something I like to shine a light in behind the weld to check for pinholes, if I find any they get welded up before the filler process starts. If possible it doesnt hurt to run a bead of seam sealer on the backside of the weld too.
  30. Boeing Bomber
    Boeing Bomber
    If you buy cheap bondo (or the like) you may save a bit in the price, but the cheap stuff will fill your paper a LOT more, and you'll be replacing your sand papaer a lot more. The price may look good, but the cost will be more than if you spent a bit more for the good stuff in the first place.
    slack likes this.
