Let's see some sheet metal shaping
Discussion in 'The Hokey Ass Message Board' started by jhnarial, Sep 16, 2008.
  1. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Nice job! Sometimes the little things are the hardest to make.
  2. rcnut223
    rcnut223
    from wisconsin
    Spent the afternoon making inner door panels s for my 32
    Someone decide these were not needed- torched em out
    started with a pattern
  3. rcnut223
    rcnut223
    from wisconsin
    Next I transfer the patterns to sheet metal. Marked and drilled the regulator holes and door remote with 1/8 bit.
    Also made a wood pattern of the raised area on the panel. Taped that to the back side
    Used a rivet set and chisel to trace and chase the pattern into the metal
    Bead roll to make the top relief .
    Next week repair install the panels
    stealthcruiser and loudbang like this.
  4. big duece
    big duece
    from kansas
    Looks good rcnut!
  5. HomemadeHardtop57
    HomemadeHardtop57
    In the process of making a bomber bench seat with custom etched tag for my roadster project. Still in the process, but almost done
    stealthcruiser likes this.
  6. HomemadeHardtop57
    HomemadeHardtop57
    Made a hole flare die out of some wood and a cut down trailer hitch ball for the seat pieces
    ImageUploadedByH.A.M.B.1418005443.386757.jpg ImageUploadedByH.A.M.B.1418005458.102427.jpg
    ImageUploadedByH.A.M.B.1418005514.563823.jpg ImageUploadedByH.A.M.B.1418005526.613834.jpg
    Rastus, oldgoaly, AntiBling and 2 others like this.
  7. BarryA
    BarryA
    Made a quick Model A dash panel.
    Rastus and oldgoaly like this.
  8. willymakeit
    willymakeit
  9. JimSibley
    JimSibley
    Coolest thread ever!!!!
  10. Marty Strode
    Marty Strode
    I am building a motorized bicycle and wanted to build a gas tank that resembled something on a vintage "Speedway Bike". It might be a little OT, but it is metal shaping and welding on aluminum, and this will be my transportation at Bonneville next year. The material is .063 thickness and 3003 alloy. I regret not getting a pic of the tank roller dies and the bead roller, that is how I turned the edges on the sides and main shell of the tank. The Tig filler rod used was 1100 series, it seems to file and sand quite well. IMG_5030.JPG IMG_4998.JPG IMG_5001.JPG IMG_5022.JPG IMG_5024.JPG IMG_5025.JPG IMG_5034.JPG IMG_5033.JPG
    Rastus, b-bop, oldgoaly and 3 others like this.
  11. dusterdave173
    dusterdave173
    Insane Tallent Here in this Thread!!
    I am a poor Rookie!! Never shaped anything but...I did make the cowl for my new Front Engine Dragster--bent it over a drive shfat that was stuck in the vise and just kept "coaxing" it until....
    You guys are amazing!
    Rastus likes this.
  12. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Yup Marty, I did the same thing and also added a faux "oil tank" and some chain guards. But yours is nicer and blends well with your frame.
  13. Marty Strode
    Marty Strode
    I built a Bonneville car for a friend of mine this year. The final touch was an air intake scoop. Here again I used .063 - 3003 aluminum, plenty of pics. IMG_4534.JPG IMG_4539.JPG IMG_4540_1.JPG IMG_4542.JPG IMG_4548.JPG
    Rastus likes this.
  14. Marty Strode
    Marty Strode
    Rastus likes this.
  15. Marty Strode
    Marty Strode
    I was just kiddin ya ! I had a little computer problem. IMG_4551_1.JPG IMG_4555.JPG IMG_4556.JPG IMG_4558.JPG IMG_4559_1.JPG
    Rastus, oldgoaly, AntiBling and 4 others like this.
  16. Marty Strode
    Marty Strode
    Frenchtown, that's a cool bike. Thought you might want to see the tank mounted on the bike. IMG_5163.JPG
    Rastus, oldgoaly and JOYFLEA like this.
  17. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  18. pitman
    pitman
    Gorgeous work! Thanks for showing the steps and rolled edges!
  19. Marty Strode
    Marty Strode
    Dave, That Dragster cowl looks great ! I sorta cheat when it comes to forming cowls and panels. IMG_4203.JPG IMG_4204.JPG
    Rastus, oldgoaly and stealthcruiser like this.
  20. BillWallace
    BillWallace
    very nice work. Your tutorioal is great.
  21. 36 ROKIT
    36 ROKIT
    Dang, you guys are good!
  22. Marty Strode
    Marty Strode
    This is a simple cowl steering bubble I did a while back, you will notice that I got too aggressive when burning off the carbon, during the annealing process. My thinking, was that I was trying to learn this stuff, so I tried to save it. I could have made a hammer form to control the shape, but I pounded it on a bag, and shaped it with a cheap planishing hammer. More pics to follow. IMG_1675.JPG IMG_1676.JPG IMG_1677.JPG IMG_1681.JPG IMG_1683.JPG IMG_1685.JPG
  23. Marty Strode
    Marty Strode
    Part 2, more pounding, grinding, t******* and installation. The hood, along with the scoop, and bulges to clear the blown 4 banger Dodge, were quite a learning experience for me. IMG_1686.JPG IMG_1688.JPG IMG_1689.JPG IMG_1690.JPG IMG_1692.JPG IMG_1762.JPG
    Rastus, lrapso, oldgoaly and 2 others like this.
  24. 55 dude
    55 dude
  25. BangBam
    BangBam
    Great work. Came out real good.
    One truck, one welder, endless possibilities!
  26. bjinatj
    bjinatj
    Well my children start back to school tomorrow from their Christmas vacation. I figured I'd get the creative juices going early and start them off on the right foot today. Education should start an home anyway..
    Rastus, doliak, russellmn and 6 others like this.
  27. MoparFinman
    MoparFinman
    from Okla
    Now that's just awesome !!! teaching your girls how to build things. Shaping metal is a art!
    Are they building a peddle like car?
  28. MoparFinman
    MoparFinman
    from Okla
    by the way bjinatj what steering box did you use?
  29. Marty Strode
    Marty Strode
    Here is another part out of .063, 3003 aluminum. It's a belt drive cover for my motorbike, however if you lay it flat, it could be an air cleaner for multiple carbs. Simple steps, make a pattern of the outline, and roll a 4" wide band to fit the shape. Run both parts through the tank roller die, followed by a p*** with the 1/2" bead, for stiffness. IMG_5262.JPG IMG_5263.JPG IMG_5265.JPG IMG_5267.JPG IMG_5267.JPG IMG_5269.JPG
    Rastus likes this.
  30. Marty Strode
    Marty Strode
    More steps, check for perimeter fitness. Add a couple of dimples, using an old headlight swivel base and the ball on a vice handle. Weld it up and grind to finish. Now I have to build an air cleaner for the tri-power on my 40 Ford pickup. IMG_5270.JPG IMG_5271.JPG IMG_5273.JPG IMG_5274.JPG IMG_5276.JPG
