Projects "Hot Rods to Hell" Corvette build finale
Discussion in 'The Hokey Ass Message Board' started by Utahvette, Nov 11, 2014.
  1. So-cal Tex
    So-cal Tex
    I love that you are using cast off Corvette restorer parts to build your car on budget!!
    guthriesmith and 62hotcat like this.
  2. hemi
    hemi
    Cool movie, and a great job on the car so far! It's *****in...
  3. Utahvette
    Utahvette
    The upholsterer did a great job. They look like real Corvette seats! We're going to trade for a little paint work on his wifes Yukon . The seats fit snug in the cavities. To adjust seating position I just stacked dense foam rubber behind the seat to get the right leg room. They are much softer and therefore more comfortable than stock ones . I also fabricated the all important roll bar. I welded some mandrel bends together and attached it to the original soft top frame mounting points. 175.JPG 176.JPG
  4. moparnate
    moparnate
    from minnesota
    those seats look great, fit just like the originals, and saved you a ton of $. Great build.
    volvobrynk likes this.
  5. volvobrynk
    volvobrynk
    from Denmark
    When looking at your posts, its hard to see that should be a budget build! It looks like a million bucks, its awesome!
    And beautiful!
    Keep at it! :D
  6. SicSpeed
    SicSpeed
    from Idaho
    My daughter and I are going to be in SLC Christmas week visiting my son.
    I hope to see the Vette terrorizing the SLC area
    Posted using the Full Custom H.A.M.B. App
  7. Chaz
    Chaz
    Not only is the build beautiful, but the entire thread is done superbly! Nice photos, good spelling, fast paced, organized and interesting... I'm taking notes...
  8. F-head
    F-head
    well done sir
    lets see some action photos
  9. dreracecar
    dreracecar
    from so-cal
    thCAVDSAZ0.jpg Are any of the original actors still around? would make for a great photo, The thing I missed (couldnt get it set up) on the IVO deal was to get a current shot of Prudhome with a paint gun in the booth with the repop
  10. lewk
    lewk
    from Mt
  11. Holy **** man! So good!
  12. Utahvette
    Utahvette
    I was in a bit of a quandary about what to do for front turn signals since the whole lower section that normally houses the lights is now in the back yard against the fence. I got on Ebay and found these small motorcycle lights. After I painted the housings semi-flat black and test mounted them just above the control arm outboard of the frame , the lenses were still pretty noticeable. To make them blend in with the ch***is I sprayed a light coat of gloss black across the lenses .The gloss black is opaque with one light coat. That looks much better, almost invisible and because they are LED lights they still shine through brightly . $T2eC16FHJHEE9ny2p)6iBQB9mIR7zg~~60_12.JPG CIMG9617.JPG
    loudbang and volvobrynk like this.
  13. Utahvette
    Utahvette
    Finished shot of the engine compartment, I used the hydraulic clutch set up from the Camaro the five speed came out of. Economical, simple ,smooth operating and easy to adapt to the Corvette fire wall. The master cylinder is there next to the brake cylinder. You can easily push the clutch in with your hand. 173.JPG
    AHotRod, guthriesmith and volvobrynk like this.
  14. Rocky
    Rocky
    Classified Editor
    Great project............don't forget to install oil injection in the mufflers so the car blows blue oil smoke out the exhaust on acceleration like the old movie car.
    SicSpeed likes this.
  15. chevy57dude
    chevy57dude
    Or let me run the **** out of it. I'll loosen her up!
  16. winger59
    winger59
    from Indiana
    Nice job...could you share more info on the seats.... build a 53 replica Corvette and facing the same seating problem. Seats just sitting in place or bolted in? Thanks for the build write up....watched the movie on Netflix this week.
  17. Utahvette
    Utahvette
    It's pretty much done here. I may tweek a few details later. The rear tires might need to be a little wider and I might have the pin striping around the flames made a bit bolder. Over all I think it has a pretty good look to it. While it's not an exact copy I don't think many will miss the resemblance . After all, how far do you carry replication? 6 cylinder sound, smoke out the left side? Do I really need to play chicken? (maybe) I've got some great glamor shots for tomorrow . CIMG8304.JPG CIMG8301.JPG
  18. dreracecar
    dreracecar
    from so-cal
    ****, did you clock all the Phillips screw heads and line up the cotter pins while you were at it???
    Its perfect
  19. elgringo71
    elgringo71
    Grand slam home run
  20. SicSpeed
    SicSpeed
    from Idaho
    Killer
  21. Baron
    Baron
    You are one talented young man. Not many could have pulled this Corvette together. Great work.
  22. Rocky
    Rocky
    Classified Editor
    It'd be hilarious to grab a buddy and a blonde chick, scream up and down the streets of Woods Cross. Maybe drive it to B'ville speed week and drive it up and down the access road with your "crew"...I wonder how many guys would get it.
    volvobrynk and SicSpeed like this.
  23. Bruce A Lyke
    Bruce A Lyke
    Great build, you really are to be commended for your skill and resourcefulness.
  24. jimdillon
    jimdillon
    I may be in the minority but I was never a fan of the car nor the movie but I have to admit you did a good job capturing the look of the car, especially in the way you did so. I think even the purists may appreciate it since you did not "destroy" a good car in the process.
  25. LAROKE
    LAROKE
    Dana Andrews would be scared ****less.
  26. bowie
    bowie
    That ought to piss off some of the NCRS boys! Great job! Have fun, haul ***!
  27. AHotRod
    AHotRod
  28. Dan Hay
    Dan Hay
    I love this build!!!! I especially love how you started the thread after it was finished so we didn't all wait around for 2 years.
  29. enloe
    enloe
    from east , tn.
    You knocked this one out of the park so what's the next one?
  30. 327Eric
    327Eric
    beautiful job.
