Hot Rods 30 ford coupe subrail diagrams???
Discussion in 'The Hokey Ass Message Board' started by brainfreeze, Dec 1, 2014.
  1. brainfreeze
    brainfreeze
    just wondering if anyone has a diagram of original subrails? I've found ch***is diagrams online, surely there are detailed subrail plans?
    thanks
    sam
  2. GordonC
    GordonC
    I saw this somewhere on the net and grabbed a copy. Is this what you are looking for? Not sure if it is for 28/29 or 30/31?
    Gordon
      53.9 KB
  3. brainfreeze
    brainfreeze
    thanks, it may help a bit, i plan on getting a local shop to fold me up new rails already raised for a channel, rather than buying a set and chopping them up
  4. GordonC
    GordonC
    If you need any pictures of the rails in a car I have a 31 roadster which I am building. Right now I have the empty body sitting on the ch***is so it would be easy to get pictures of the rails in the car.
    Gordon
  5. brainfreeze
    brainfreeze
    thanks mate, but i already have that now, just a bit hard to get decent measurements, i want to get a new subframe built before i completely pull the body apart, plan is to soak the complete panels in citric acid to remove the rust but keep all the original paint, wipe it down with phosphoric acid to seal it, then when its finally done... flat clear coat... or i strip it at the end and paint it some rad colour
  6. 80WTI
    80WTI
    Just watch how long you leave it in the citric acid as i recently did it to a model t panel and most of the paint then flaked off very easy, the paint looked good up until then.
  7. brainfreeze
    brainfreeze
    Thanks bud! I'll keep that in mind, check it every Arvo probably, I done some very badly rusted falcon control arms a few years ago and they only took like 2 days
  8. brainfreeze
    brainfreeze
    If I were to fold up my own set of sub rails, what thickness sheet would people reccomend using? Same as Stock or thicker?
