Technical Looking for 3/4" bore push type clutch slave cylinder.
Discussion in 'The Hokey Ass Message Board' started by bobss396, Dec 10, 2014.
  1. bobss396
    bobss396
    Yes, I did do a search.
    I already have a 3/4" bore Wilwood clutch master cylinder. My game plan was to use a Novak slave cylinder kit, but my bellhousing is an older '55 Chevy type (P/N 3704922) which I don't want to cut up.
    So I'm after a 3/4" bore push type clutch slave with approximately a 1.4" stroke. Does anyone have a recommendation? I'd like something off the shelf in a parts house. The bellhousing has 2 mounting holes for a z-bar bracket, which I can use for a bracket to mount the clutch slave. I can make anything up that I need.
    The picture (stolen off the internets..) shows the 2 z-bar bracket holes.
    Thanks, Bob
  2. prpmmp
    prpmmp
  3. bobss396
    bobss396
    Thanks. Do you have anything else on it, bore size and does it come with a push rod?
  4. prpmmp
    prpmmp
  5. deto
    deto
    Our builds are very similar... Were checking all the same stuff off the list
  6. bobss396
    bobss396
  7. bobss396
    bobss396
    I'm into my '59 Ford pretty deeply. What are you working on? I'm now looking at GM Vette and Camaro cylinders. Just way too many on the Summit site to sift through and many have little for description.
  8. prpmmp
    prpmmp
  9. deto
    deto
    I'm in the parts collecting/planning stage of my 49 chevy build.
    I am sorting out my clutch master/slave set up at the time. Trying to get the right pieces so it works as it was designed.
    If I remember correctly you chimed in on my build thread:
    http://www.jalopyjournal.com/forum/threads/road-to-redemption-49-chevy-coupe-build.942709/page-2
    Are you trying to find a slave that will mount to the bell without any modification?
  10. bobss396
    bobss396
  11. bobss396
    bobss396
    I like the way your car is going. I want a slave that is OTC so I can always get another one fast if I need it. I can make up anything to adapt it to the bellhousing. The core group that works on the car is made up of engineers, machinists and professional auto mechanics, so I'm covered.
  12. deuce354
    deuce354
    Go to a NAPA store. look though there picture books of master & slave cylinders. Im sure you can order one that fits your needs. They are the best outlet for old stuff like that.
  13. bobss396
    bobss396
    Thanks, I'll give them a try.
  14. Imperial Kustom
    Imperial Kustom
    An easier route to go, although they can be tricky to find, would be to locate a bell housing, slave, rod and clutch fork from a 1960-62 V8 chevy truck, or a 1960-63 V6 GMC truck. Slave cylinders are readily available at any parts house in 7/8" and 1" bore. '80's GM 1 ton trucks also used a hydraulic setup. I believe the light duty pickups and camaros did too, but I don't have any experience in their adaptability. The truck stuff is as easy as 1-2-3.
  15. bobss396
    bobss396
    I'm trying to use what I have, but will dive into my stack of steel bellhousings for another look. I could probably go as big as a 7/8" slave if I had to. I have a few Dorman 3/4" candidates from Summit that I like and can gamble trying one out since they're dirt cheap.
  16. Eslope T
    Eslope T
    Have a look at a 87 to 90 chev C10 slave cylinder. It is 3/4 inch used on the 4.3 V6 but V8 is probably the same. It is mounted on the p***enger side of the bell housing and has a bleeder screw. I believe the later units do not have a bleed screw . Visit the Rock auto site and have a look
  17. bobss396
    bobss396
    I think I saw one of those from Dorman. I did see a lot of other slaves that obviously mounted on the p***enger side too. Maybe the hose fitting and bleeder could be swapped. I would think that any slave could be bled at the master, since that is the highest point.
    I saw a few good foreign car possibilities, I figure at the worst I'd have to use an AN type adapter if the inlet is metric.
  18. sdluck
    sdluck
    Don't forget Foreign cars,Datsun,Toyota Mazda as well as other imports used slave cylinder.
  19. bobss396
    bobss396
    This is probably the way I'm going to go, saw one from a Lexus that is close to what I want.
