History Motor Mounting Madness: Hurst Catalog 1960
Discussion in 'Traditional Hot Rods' started by Jive-Bomber, Dec 11, 2014.
  1. Jive-Bomber
    Jive-Bomber
    MODERATOR
    Jive-Bomber submitted a new blog post:
    LOU WELLS likes this.
  2. 53OlderThanMe
    53OlderThanMe
    I sure wish some of the mad fabricators on here would repop some more of this stuff like the SP-150 Spacers and AD-75 Anti-Chatter. Sign me up if you do.
    Great article, thanks
  3. 504640
    504640
    Yeah! Sign me up too! I like your idea! I never tire of looking at these old articles and advertisments.
  4. kidcampbell71
    kidcampbell71
    I remember some of those ads not really that long ago.......amazing. I sure wish my mirror made me look the way my memory recalls. Just a young pup then....
    volvobrynk likes this.
  5. jjsound
    jjsound
    53OlderThanMe, do you have a link to any of those pieces? What kind of market would there be?
  6. Magnus
    Magnus
    from Sweden
    I can remember finding american car Magazines, occasionaly not often, at the local Tobacco shop and checking out the adds , to try to find some cool Sellers. Ordered Honest Charlies's t-shirt and decals, waited like forever, and got a (too small, guess I grew during waiting...) and was king at school. The letters said something like " Can please have tskjorta in large, here is five dollar"
    The Magazines were very hard to find, I saved mine for many years but guess they disappeared someway along the way.
  7. Inked Monkey
    Inked Monkey
    "Wide stance Sea Leg" I love it!
  8. hugh m
    hugh m
    from ct.
    Not boring at all, plus it's good for all the kids to see the olden days.
  9. bowie
    bowie
    I love old catalogs ,keep posting them up. I would think, there'61 book would be the start of the Dual Pattern line. Thanks for sharing.
  10. von Dyck
    von Dyck
    Any engineering reason for '62 and older Corvettes having a very high front motor mount location? Provide less ch***is roll during cornering?
    BTW sea legs in stiletto heels???
  11. RichFox
    RichFox
    I bought and used Hurst mounts for a Chrysler/53 Stude swap. Worked great for me. I would use them now if I was doing a swap.
  12. Bruce Lancaster
    Bruce Lancaster
    The early Corvettes used a '53 Chevy ch***is with engine set back...this put engine way behind the crossmember where early style V8 p***enger would have mounted, and there was a lot of crazy '53 steering linkage there too. I think the raised-Hurst looking mount was simply a way to get the legs over to the framerails with simple bracketry that didn't require real ch***is mods. Sure does look like Hurst thinking.
  13. ago
    ago
    from pgh. pa.
    The old style front motor mounts put more strain on the bell housing (aluminum) when you use a trans crossmember that is toward the rear of the tailshaft.
    Ago
  14. plym49
    plym49
    from Earth
    Used them to put a SBC into a 48 Willys station wagon. Worked better than perfectly.
  15. plym49
    plym49
    from Earth
    Never had a problem with that.
  16. ago
    ago
    from pgh. pa.
    The longer the distance between motor mount ends the more the engine-trans is trying to break in half. A lot of the early old motor trans combination had shorter 3 speed ******s. You might not have a problem, but I read somewhere that the heavier the engine- trans combination it could be an issue. On another issue, I read in Circle Track mag years ago that a Lakewood style bellhousing (steel) would oil-can flex more than a stock GM cast aluminum bellhousing. I know it doesn't seem to make sense, but that is what was recommended.
    Ago
  17. SimonSez
    SimonSez
    Definitely not boring - thanks for posting!!
  18. flamingokid
    flamingokid
    I never get tired of the catalogs,keep 'em coming :)
  19. Kail
    Kail
    from Austin, TX
    i love this stuff please post as much as you can.
  20. plym49
    plym49
    from Earth
    It's the few inches between the front of the motor and where the side mounts are. Not that much more weight being suspended in between. If the vehicle was a wheeler with a transfer case and the entire thing was suspended end to end, maybe. I'm just not seeing it and having done it with no problems it is hard to reach a conclusion to the contrary based upon what someone said.
  21. ago
    ago
    from pgh. pa.
    Hey If it works for you fine and good. I'm not arguing with you. Don't shoot the messenger. I don't know if info was right or wrong just saying.
    ago
  22. titus
    titus
    nos hemi hurst adjusta-torque motor mount set up i used in my 34 coupe, i love little details like this, have had a few people noptice but not many.
    hurst motor mount with the sp150 u shaped spacers on a customers model A roadster
  23. CalGasser
    CalGasser
    Speedway Motors makes a Hurst style mount for SBC at $80.00. Don't know if they make them for any other engines or not. I've used this mount for over 25 years with a Lakewood Bellhousing, M21 and never had any problems.
  24. deto
    deto
    What does the tensioner bolt press against? The vertical motor mount bolt or the rubber?
  25. U-235
    U-235
    my buddy reproduces the hurst style motor mounts for both the olds and the Y-block Ford. They even come with the old instructions (reprints)....
    nochop, sko_ford and volvobrynk like this.
  26. titus
    titus
    it presses against the motor mount itself, they have a larger hole where the cushion mount comes thru, dunno how it really works or if it does but its a neat detail
    jeff
  27. treb11
    treb11
    Lots of good information in the "hints" section as well.
  28. Bruce Lancaster
    Bruce Lancaster
    Speedway produces obvious replicas of some of the Hurst line.
    They have the '49-53 Ford and Merc frame mounts, I think early Chevy ones, and instead of A-28 early Ford ones they make a cut-down version that would only work on a boxed frame. They make the spacers but not the ant-chatter parts, but those are so simple you could probably fabricate a set while standing in the fastener aisle at Home Depot...Just a strap bent into a tight U with 2 holes drilled in it.
    I don't remember what engine brackets they have beyond Chevy. The pictures at least look to be direct copies of Hurst.
  29. bobss396
    bobss396
    Or wide-stance ear warming....
    Inked Monkey likes this.
  30. Randy Routt
    Randy Routt
    Got any pics of that car?
