Customs 3x2 SB fuel injection
Discussion in 'The Hokey Ass Message Board' started by birds4ever, Dec 11, 2014.
  1. Ol Six Shooter
    Ol Six Shooter
    Wow, I'm glad I stumbled across this. I've been trying to find a similar setup for an old Buick. I was thinking I would have to go with a carb intake like one from Taper, and then have to make adapter plates and rig up the lines and linkages to the trottle bodies myself. I wonder if one of these guys could or have built a 3x2 EFI setup for Buicks...
  2. gimpyshotrods
    gimpyshotrods
    I cannot believe that this blasphemy is still a running thread!
    I am building a EFI turbo system for my Falcon daily driver. Electronic spark control, knock sensor, wide-band O2, and everything.
    With today's variable fuel quality and blends, I'm getting tired of seasonal and al***ude jetting.
    I am waiting on a sonic check to see of there is enough meat in the short runners into the head to take a screw-in injector boss, or if I'm going to have to braze.
    I have a spare head, so I will investigate the prospect of milling off the entire integral intake manifold.
  3. gimpy. . .
    You would not be the first to mill the intake off of one of those heads. if it were mine and I was going to go high tech with it that would be my first option. While you're in there a little port cleanup may also be in order. ;)
    I am not a big fan of EFI just because I am not, at least not as far as a traditional ride is concerned. But if someone is then they should go all out with it. Like gimpy . . . suggests here with his little project.
    gimpyshotrods likes this.
  4. '51 Norm
    '51 Norm
    from colorado
    nukeman,
    That is the kind of thing that I am thinking about doing with the tri power that I have. I have the same concerns that joey7508 has though. Of course on a Pontiac intake if there was ever a fuel leak at least it wouldn't fill up the oil pan.
  5. larry k
    larry k
    I guess I just don't understand ????????? Anymore !
  6. gimpyshotrods
    gimpyshotrods
    That's okay. It happens to a lot of older folks.;-)
  7. gimpyshotrods
    gimpyshotrods
    I can get E0 heads for $60, so I don't mind having at one, and seeing how far it can go.
  8. Ol Six Shooter
    Ol Six Shooter
    Just got off the phone with a representative from Borla. Super helpful and knowledgeable. He was able to answer my questions, and help me find more than one possibility for my Buick. I would definitely recommend to give them a ring if you're trying to find something.
