Projects Cadillac Flathead FED Build- The FlatCad Too!
Discussion in 'Traditional Hot Rods' started by 38FLATTIE, Sep 7, 2013.
  1. wrenchbender
    wrenchbender
    Well been awhile since I've had a chance to work in the ol digger but I've made a skosh o progress I've got a fuel pump drive bracket made and got the belt drive attached then made the rear x braces and tacked them in set the seat in granted I'm not a big fan of this fibergl*** deal but it's what I have and for now it's just gonna have to work for now also I have located the brake handle next up throttle pedal clutch pedal and fuel tank mount anyhow here are a few pics
    ImageUploadedByH.A.M.B.1415338141.009812.jpg ImageUploadedByH.A.M.B.1415338159.709878.jpg ImageUploadedByH.A.M.B.1415338173.975715.jpg ImageUploadedByH.A.M.B.1415338195.242993.jpg
  2. roseville carl
    roseville carl
    Go gettum!!!!!!!!!! summer is approaching
  3. wrenchbender
    wrenchbender
    Made a skosh more progress throttle pedal, clutch pedal, brake handle, master cyl mounted and the front X in the frame for support and fuel tank mount unfortunately a sweet moon or eelco tank and brackets are not in the budget so I'm gonna have to use the hand me down homemade tank in the pic however if anyone has a tank that they would let go at a real deal I would be intrested because that would sure make the digger that much better
    Anyway here are a few pics
    ImageUploadedByH.A.M.B.1415819786.356139.jpg ImageUploadedByH.A.M.B.1415819809.570815.jpg ImageUploadedByH.A.M.B.1415819832.871774.jpg ImageUploadedByH.A.M.B.1415819846.854015.jpg
  4. roseville carl
    roseville carl
    Hey Randy 180 days till Eagle 15
  5. Get moving Randy - we all want to see this ****er run! Hell - count me in to 'crew' with yah if we can workout some dates. Dale
  6. wrenchbender
    wrenchbender
    Well folks I haven't had much time lately to work on the dragster hopefully after the holiday stuff I will have time to get busy however I did get a early Christmas present from Santa Carl lol here are a couple pics
    ImageUploadedByH.A.M.B.1418787149.510458.jpg ImageUploadedByH.A.M.B.1418787164.276134.jpg
    Thanks Carl !!!!!!!
    mctim64 likes this.
  7. roseville carl
    roseville carl
    hope it works for you Randy...............
  8. wrenchbender
    wrenchbender
    carl it will work perfectly especially once I put the old style bearing plate on the rear of the blower From all of us at the flatcad ranch thanks again
  9. Nice work Carl!
  10. speed v8
    speed v8
  11. wrenchbender
    wrenchbender
    Been awhile since I have posted an update basically cause I haven't had much time to work on the digger however I have made some progress and things are starting to slow down so I can spend more time on this thing and get it ready to race anyhow I now have a shifter that functions and started on body panels I have 5 panels made but only have two dzues fastened on hopefully lll have the others attached in the next few days things are shaping up and not much setup left to do then the finish work begins you know the progress that shows nothing for awhile then blam it's done anyways here are a few pics
    ImageUploadedByH.A.M.B.1424117371.054509.jpg ImageUploadedByH.A.M.B.1424117420.402303.jpg
  12. roseville carl
    roseville carl
    Coooooolllllll Randy think ya might wanna take a few kinks out of the linkage?
  13. ronnieroadster
    ronnieroadster
    Go easy shifting with that linkage :eek:
  14. wrenchbender
    wrenchbender
    Actually the pic doesn't show how solid it is it's made out of 1/2" solid barstock and it has to be bent like that for it to work and clear everything I've beat on it real good trying to bend it and it just works also I won't have to shift it much probly won't even have to use first at all probly just a 2-3 shift once I do appreciate the thoughts though I always am open to better ideas
  15. Moto Moto
    Moto Moto
    from Krum, TX
    Damn it. Between you and Carl, I'm in trouble. Really want to build a FED now.
  16. wrenchbender
    wrenchbender
    Thanks moto Carl is a bad influence between him and Kerry I didn't stand a chance lmao
  17. roseville carl
    roseville carl
    nothing better than a Flat Fed!!!
  18. wrenchbender
    wrenchbender
  19. Hey Randy, great to heat that you're putting some work into the old girl! Keep me posted on progress and any potential events where you need a "crew" to help out. Keep on humpin on it!
    Dale
  20. roseville carl
    roseville carl
    Randy Eagle is coming up fast............get to work
  21. wrenchbender
    wrenchbender
    Thanks dale and I'll keep ya posted. Carl as much as I wanna make eagle probly not gonna happen this time but it is on the plan to make eagle field at some point I would love to come out there and leave your digger in the dust lol.
    Anyways more progress has happened I finally got the other body panels fitted I gotta say that top panel was a real sum ***** to make with my primitive tools lol but after countless hours I have got it pretty good first time I have worked with aluminum sheet metal and it is way different than steel definately a learning experience with a little more t******* and m***aging it will be just fine also tacked up the headers I wasn't sure about how the weed burner style would look but I kinda like it not to mention I think it will be safer to tune the engine than a straight up zoomie style
    ImageUploadedByH.A.M.B.1425360140.984202.jpg ImageUploadedByH.A.M.B.1425360159.417266.jpg ImageUploadedByH.A.M.B.1425360182.066933.jpg ImageUploadedByH.A.M.B.1425360193.084340.jpg ImageUploadedByH.A.M.B.1425360207.817193.jpg ImageUploadedByH.A.M.B.1425360243.400350.jpg
  22. roseville carl
    roseville carl
    Kinda looks like a spider. Paint it black and call it the Black Widow....... I like it Randy!!!!!
    PS if ya ever get out this way ya have a place to stay!
  23. wrenchbender
    wrenchbender
    Thanks Carl plan is to paint it red think I'm gonna call it medusa lol
  24. roseville carl
    roseville carl
    Ok Randy whats up with this ?????? need updates!!!!
  25. wrenchbender
    wrenchbender
    Been on the backburner for awhile but stay tuned motor has went to the machine shop and should have the axles I ordered Monday been gathering parts still need a chute to mount and a few odds and ends but progress is in the works just nothing showable yet
    loudbang and mctim64 like this.
  26. fenderless
    fenderless
    from Norway
    Looking good Randy :) Keep up the proggress :) Carl's suggestion on the spider theme sounds catchy though ;)
  27. Keep after it! I may be able to pit crew for you yet! :)
  28. roseville carl
    roseville carl
    Just 115 days till Eagle Field Randy,........ get to work!!!
  29. Kerry
    Kerry
    Glad one of us is getting something done on their digger.
  30. roseville carl
    roseville carl
