Projects Rob Bobs 1932 truck part 2
Discussion in 'Traditional Hot Rods' started by rob bob, Nov 14, 2014.
  1. rob bob
    rob bob
    from Canyon TX
    So the ch***is is getting closer to being finished I just needed to take the time and to finish some of the smaller aspects of the build. First order of business Was to get the rear
    spring u bolts squared away, I had to extend the lower model A knuckle's that go under the spring (at least I think that's what there called) so I cut some 1/4 plate to size and tig welded it into place. ImageUploadedByH.A.M.B.1418088454.123377.jpg
  2. rob bob
    rob bob
    from Canyon TX
    So next I fabricated the upper and lower shock mounts I used Pete and Jakes chrome shocks to match the front. ImageUploadedByH.A.M.B.1418088784.447989.jpg
  3. rob bob
    rob bob
    from Canyon TX
  4. rob bob
    rob bob
    from Canyon TX
    Then I fabricated a t style bracket for the lower shock mount.
  5. rob bob
    rob bob
    from Canyon TX
    117harv likes this.
  6. rob bob
    rob bob
    from Canyon TX
    Here's the finished bracket before I weld it to the rear housing.
  7. rob bob
    rob bob
    from Canyon TX
  8. rob bob
    rob bob
    from Canyon TX
    Here's a picture with everything tacked into place. ImageUploadedByH.A.M.B.1418089444.375579.jpg
  9. gordspeed
    gordspeed
    from Oregon
    I just keep Salivating........ Looking Good! :)
  10. loco_gringo
    loco_gringo
    Really, really nice work so far... Subscribed.
  11. iddragracer
    iddragracer
    Very nice work, you got skills and good taste.
  12. rob bob
    rob bob
    from Canyon TX
    Not much to update just a few pictures of the panhard welded in place, this was the last of the ch***is fabrication I needed to do. ImageUploadedByH.A.M.B.1419463488.117938.jpg
  13. rob bob
    rob bob
    from Canyon TX
  14. rob bob
    rob bob
    from Canyon TX
    Now the panhard bar welded in place. ImageUploadedByH.A.M.B.1419463635.482836.jpg
  15. rob bob
    rob bob
    from Canyon TX
    That's a wrap on the basic ch***is I'm about to start fabricating the exhaust system and a few other details but it's getting close! ImageUploadedByH.A.M.B.1419463837.845796.jpg
  16. rob bob
    rob bob
    from Canyon TX
    While I was held up on parts I had a moment to put the body and bed back on the frame and for the first I was able to stand back and look at the truck as a whole, I'm pretty happy with everything but I will be changing a few small things first is the front spring so I can get the ch***is a little lower to the ground, second is to swap out the front tires for something a little bigger. That's all for now more updates coming soon. ImageUploadedByH.A.M.B.1419464598.099603.jpg
    kiwijeff, Muttley and Max Gearhead like this.
  17. krylon32
    krylon32
    from Nebraska
    Starting my 4th deuce PU. So far I've had 2.5/4/and 3 inch chop. Just for curiosity how much is your chopped? Are you going to shorten the bed from stock? Your project is looking really good.
  18. rob bob
    rob bob
    from Canyon TX
    The truck was chopped when I bought it but I think it was around a 4 inch chop, the bed will be shortened to around 60 inches, its a 35-36 bed so I'll have to move the wheel wells forward so everything will look right, I know its a little unconventional to use a 35-36 bed on a 32 truck but once I'm done it will look pretty good (at least it does in my head)
    Runnin shine likes this.
  19. waxhead
    waxhead
    from West Oz
    Looks really nice so far. Keep up the good work and keep the updates coming.
  20. Roger53
    Roger53
    Very nice hot rod truck. Roger
  21. Really great work, I'll be watching.
  22. Mthewrench
    Mthewrench
    from Colorado
  23. DeLuxe 32
    DeLuxe 32
    I know Larry will want to know...so what size tires are you running at the moment ?? And what will you put up front instead ??
    3wLarry likes this.
  24. rob bob
    rob bob
    from Canyon TX
    The tires on it now are 5.00 I'll probably run some 6.00's.
  25. El Hueso
    El Hueso
    Nice work! I really dig the headlight mounts and bar!
  26. rob bob
    rob bob
    from Canyon TX
    Also I'd like to throw this out there I would really like to run fenders on this truck so if anybody knows of a good pair of fenders send me a pm or you can email me ballardkustoms@gmail.com
    Frankie47 likes this.
  27. krylon32
    krylon32
    from Nebraska
    Good rear fenders other than gl*** are like hens teeth. I ended up using Brookville fronts and shortly after the first of the year United Pacific is supposed to have rears? (they had a sample at SEMA)
  28. 117harv
    117harv
    Very nice work, thanks for sharing...perfect stance/ride height.
  29. rob bob
    rob bob
    from Canyon TX
    Yeah I figure on buying new fronts if I can't come up with any and I'm still not sure about the rear fenders since I'm using a 35-36 bed, I hope I'm not to far into the build to change my mind.
  30. krylon32
    krylon32
    from Nebraska
    I looked in my Mack Hills catalog and their drawing showed the 32/34 radius between the fender bead to be 34.5 inch's and the 35/36 to be 37 inch's
