Projects THE FRYSLER MY BUILD 29 5W FROM PU pic heavy
Discussion in 'The Hokey Ass Message Board' started by jdownunder, Aug 11, 2014.
  1. 1929desoto
    1929desoto
    Its so wrong, its right! Looking good. Will keep watching this one, its giving me encouragement to keep going on my 29 Desoto coupster...
  2. Lookin surprisingly good man! All that welding and metal work.. i gotta say i'm impressed.. cause i know i couldn't be fucked doing all of that haha.
    Brookville really does make you lazy now that i think about it.. I suppose i did still have to assemble it all..
  3. jdownunder
    jdownunder
    I reckon you've either got money or time,but seldom both at once and I love to weld
    1929 desoto you've just gotta keep at every spare waking minute
  4. That frysler is going to be great.
    Who you calling a mind fuck :) have you seen what YOU have going on here ? :p
    jdownunder likes this.
  5. jdownunder
    jdownunder
    I laughed my ass off
    I thought you might see it like that
    Cheers justin
    Opinions are like assholes every has one
  6. jdownunder
    jdownunder
    So after a two week break I'm back working on the coupe.
    I only had the right hand door frame swinging on its hinges. So here is a pictorial of how I did the left side.
    I'm only using two hinges which is handy because a couple of them ImageUploadedByH.A.M.B.1413955554.818846.jpg ImageUploadedByH.A.M.B.1413955604.700714.jpg ImageUploadedByH.A.M.B.1413955642.767826.jpg ImageUploadedByH.A.M.B.1413955674.930438.jpg ImageUploadedByH.A.M.B.1413955718.233336.jpg ImageUploadedByH.A.M.B.1413955742.264815.jpg ImageUploadedByH.A.M.B.1413955760.854134.jpg ImageUploadedByH.A.M.B.1413955782.242429.jpg ImageUploadedByH.A.M.B.1413955804.214596.jpg
    were badly rusted so I was able to repair them . Every time I pick up tap they seem to break,so I opted to weld nuts to the back of the hinges.
    I then had to grind them down so they would fit
    When every I weld nuts to things I try to put the bolt in to keep the thread in shape and I add some anti spatter paste to the thread to keep the weld berries from sticking to them
    I used 8mm counter sunk hex heads
    I didn't get a pic of the finished product but I did get a cold beer from the fridge as its beginning to warm up here
    J
  7. tub1
    tub1
    from tasmania
    great work there mate ,I will catch up with you soon was down you area other night
  8. jdownunder
    jdownunder
    Come and check out the progress if you like,see how your going for time
  9. Cool, quite the transformation you got going on here. I'll be watching this one. Cheers.
  10. jdownunder
    jdownunder
    Here is the reversed firewall installed
    It's screwed in because it'll have to come out again
    ImageUploadedByH.A.M.B.1415256082.808363.jpg ImageUploadedByH.A.M.B.1415256112.941962.jpg
    So someone gave me this homemade
    Folder which I used to make the rear panel under the back window
    ImageUploadedByH.A.M.B.1415256344.067288.jpg ImageUploadedByH.A.M.B.1415256405.404907.jpg
    I've also tacked the resized backed window in dont looked too hard or you'll notice that I stuffed up cutting it in oh well big gaps to weld
    Nailhead A-V8 likes this.
  11. scrap metal 48
    scrap metal 48
    WOW!! Go man go....
  12. Inland empire hot rods
    from so cal
    Justin, thanks for the kind words on my build, Im glad I found your thread, not sure how I missed it, but it looks familiar to me ;) lots of metal work, and its looking good!!!
  13. Good to see your momentum back.
    Keep up the good work !
  14. nice work mate, but I wonder, why you don't grind the metal clean, before welding.??? I see this a lot on the hamb..was I taught wrong.?..been grinding clean for 50 years..? just wondering....
    49ratfink and loudbang like this.
  15. ROBERT JAM
    ROBERT JAM
    Nice ! I think you just enjoy welding .hehe
  16. jdownunder
    jdownunder
    I know I should grind then weld Porosity and all that I'm just always in a hurry
    I plan on getting it blasted at some stage hopefully sooner rather than later
    J
  17. Super cool!
  18. jdownunder
    jdownunder
    So it's been awhile since I've updated but life has been in the way
    And now that world ends on the 25th of December and every Body wants it
    Done by then I suppose I'll have less time on the rod
    It's funny how we look at things for a while and over complicate them
    That's what happened on the rear here but once I picked up the tools it seemed to flow for me.
    The bottom piece is a bit of 40x40mm square that I cut 3 sides out of on the ends to curl the round ImageUploadedByH.A.M.B.1417570643.984592.jpg ImageUploadedByH.A.M.B.1417570664.117342.jpg ImageUploadedByH.A.M.B.1417570683.600739.jpg
  19. jdownunder
    jdownunder
    Welded up and ground
    bowlingball likes this.
  20. oldrelics
    oldrelics
    from Calgary
    Looks good.....but.....I think you need to clean your metal better before welding, I think you will get much better results.
  21. jdownunder
    jdownunder
    Cut three sides of some square tube
    And bent it to the shape of the rear
    To create the inside trunk channel
    It ain't pretty but it worked ok for me
    Best of all it was super fast ImageUploadedByH.A.M.B.1419040262.265500.jpg ImageUploadedByH.A.M.B.1419040285.316598.jpg ImageUploadedByH.A.M.B.1419040305.525779.jpg ImageUploadedByH.A.M.B.1419040327.873199.jpg
    As you can see I cut one edge out once it was welded in place
  22. King ford
    King ford
    from 08302
    Nice worksmanship , really like the square tubing along and around the bottom......worked well for the trunk opening too!
  23. jdownunder
    jdownunder
    Thanks king ford
    I'll have to tweak it a bit but that's not bad for a day's work ImageUploadedByH.A.M.B.1419051647.740611.jpg
  24. This car is the proverbial pigs ear being transformed into a silk purse...nice works! HRP
    volvobrynk and jdownunder like this.
  25. MickD
    MickD
    You've been busy since I was last there Boy! I'd better get down next week. You should run a couple of pics on the FROD Mark 2. That'd cause a bit of chatter on the thread.. !
  26. Pinstripe_Chuck
    Pinstripe_Chuck
    This is very cool. This is how all my builds have to be too, a frankenstein. since Im not good at saving enough money to purchase a good starter vehicle. But in the end if they are done right, which it looks like yours is, most people cant even tell that it is really 3 or 4 cars put together. Which is pretty cool if you ask me.
    hipster and jdownunder like this.
  27. jdownunder
    jdownunder
    Thanks for the encouragement guys
    As for the frod m11 that would be considered OT on this forum and I would be beaten with a big stick for posting pics of it here old boy
    Although it does have relevance because when it sells it will fund stage two of the build
  28. jdownunder
    jdownunder
    I created a sunken number plate area
    It's back 1" or 25mm
    I can hide a plate light in there
    A word of warning.if you're like me and work fast it's easy to make mistakes,when cut the area out to sink it I cut the corners at 90 degrees then stood back and realised they needed to be curved to match the rear window. I should have drilled first.
    I fixed it by cutting a piece of 3/4" tube into 1/4's and welding the pieces in.then filled in the gap with the mig.ive still got to clean up the trunk line but that won't take much doing
    Had to blend the belt line from under the rear window to the trunk area
    I just double skinned it and ground down the weld ImageUploadedByH.A.M.B.1421120553.042202.jpg
    Finished welding up the drivers side
    Roof areas
    Hope you all had a merry Xmas
    And are having a good start to the new year
    Justin
    Nailhead A-V8, loudbang and Squablow like this.
