Send your Model A Hot Rod pictures
Discussion in 'The Hokey Ass Message Board' started by Kellys Hot Rod Parts, Dec 16, 2009.
  1. A Boner
    A Boner
    You nailed the stance.....what size are the tires, front & rear?
    Rich B. and Hotrodmyk like this.
  2. DIXON
    DIXON
  3. Lowbuckboz
    Lowbuckboz
  4. brett4christ
    brett4christ
    Boz, I'm still dreaming about the banger in your roadster! Nice car!
    Posted using the HAMB app on my iPhone.... How's that for traditional!?!?
    Lowbuckboz likes this.
  5. Lowbuckboz
    Lowbuckboz
    Thanks man! You should've asked me for a ride!
  6. leroux
    leroux
    from SoCAl
    1930 coupe. 1930 banger all Thomas speed equipment
    knucklepower likes this.
  7. hd1084
    hd1084
    louisb likes this.
  8. sharpmark
    sharpmark
    my 28 a roadster - current project
    and my 30a pickup
    Hotrodmyk and louisb like this.
  9. David Knapp
    David Knapp
    First 31 still building
  10. A Boner
    A Boner
    Stretched body, with Tudor doors!
  11. A Boner
    A Boner
    Same builder as above coupe.
    D-Russ and Hotrodmyk like this.
  12. A Boner
    A Boner
    Well thought out model A rdstr pu.
  13. A Boner
    A Boner
    How to get an A sitting on an A frame low....put the front spring behind axle, mounted off split wishbones......Rolling Bones style!
  14. pdunn10
    pdunn10
    The above nails something a lot of people seem to not worry about and that is fitting the tires to the wheel wells. The only thing i think that would make it better would be an original grill shell, instead of the shaved 32. I guess it goes with the one piece (stretched?) hood.
  15. daddio211
    daddio211
    Just FYI, Model A Tudor doors aren't longer they're taller. To use a stock Tudor or pick-up door on stock coupe you have to chop it 1".
    I don't recall hearing that body was stretched.... you sure about that?
  16. tobyflh
    tobyflh
    from Peru il
    They don't get much better than this.
  17. yngrodder
    yngrodder
    Sedan doors are longer, I do not believe (not sure) that there is any difference on height (30/31) 28/29 is taller then 30/31 though. I believe windshield frames interchange from sedan and coupe..
    coupe door is 26 7/8" long,
    a roadster is 23 7/64" long,
    and tudor sedan is 28 1/2" long.
    verde742 likes this.
  18. mgtstumpy
    mgtstumpy
  19. mgtstumpy
    mgtstumpy
    Davies- 28.jpg Gary WRIGHT.jpg Tom Shilloto 30 Coupe.jpg A coupe drug car.JPG Davies 28.jpg
    Hotdoggin DaddyO and volvobrynk like this.
  20. Par34
    Par34
    31 Model A hot rod.
  21. A Boner
    A Boner
    As I remember reading, the bottom of the body was toast. When rebuilding the bottom of the body, extra metal was added to make the body taller, and I thought the Tudor doors were added and the roof and sills lengthened to accommodate the longer Tudor doors. Whatever, it sure has the "look".
  22. A Boner
    A Boner
    No paint needed.....out in the high desert anyway.
    UNCLECHET and Hotrodmyk like this.
  23. daddio211
    daddio211
    Say what!? Your facts seem to trump my memory, guess I learned something new... :confused:
    It's a *****in' car for sure, and the Elmer's are a damnit talented bunch. Nice guys too!
  24. clem
    clem
    the blue one would be my preference ,as to me the 32 rails finish it off better,and the blue is refreshing.
  25. 26 T Ford RPU
    26 T Ford RPU
    Clem, they are both really nice in different ways but the red one isn't as busy and i dislike Moon tanks on street cars, they look wrong IMO. JW
  26. cm30
    cm30
    my 30 after some paint
  27. bucketmouth
    bucketmouth
    from Australia
    During some interstate driving.
    Hotdoggin DaddyO likes this.
  28. volvobrynk
    volvobrynk
    from Denmark
    Not my cars, but wish they where:
    ImageUploadedByH.A.M.B.1431202989.394371.jpg ImageUploadedByH.A.M.B.1431203021.110801.jpg ImageUploadedByH.A.M.B.1431203115.654894.jpg ImageUploadedByH.A.M.B.1431203157.617910.jpg ImageUploadedByH.A.M.B.1431203292.795065.jpg
  29. 26 T Ford RPU
    26 T Ford RPU
  30. 26 T Ford RPU
    26 T Ford RPU
