Hot Rods Pope RPU
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Dec 25, 2014.
  1. cornfieldcustoms
    cornfieldcustoms
    decided to make this build its own build thread instead of just keep posting it up in my shop work thread. so here it is
    Building this truck for a good friend of mine since high school. it is a 30-31 model a roadster pick up.
    frame in the jig on the table
    start of boxing the rails, we are using our set of boxing plates, one of our flat x members
    mocking up to get a good idea of the look.
    the owner looking pretty pumped with 3 days worth of work in the evenings
    he wanted to add a 32 cowl vent to his cowl top. so i went to work on it
    trimmed out the vent from brookeville
    made a card board pattern of the shape of the panel, and a negative cut out of the vent to make sure i get it where i want it
    scribed the cut line
    all tig welded up
    after some filing, hammering and dollying. and a trip through the planisher it is getting pretty close
    and installed on the car
    then moved on to putting on extended cab corners
    stock corners
    AHotRod and hipster like this.
  2. cornfieldcustoms
    cornfieldcustoms
    stockers removed
    old rear pan taken out and extended rear pan installed
    new sides clamped on
    cut the old rear panel off from the sides, going to but weld them back on instead of flanged so they can be metal finished after welding
    reversed the fire wall and re shaped the bottom of it. wanted to make it look like it was made this way. not perfect but turned out pretty good
    here is where i flipped the fire wall, making patches and patterns to smooth out the bottom of it
    all patched and smoothed out
    here is the back side with a new flange to make mounting the floor easier and a more factory look
    and clamped in the car. just need to spot weld to the sides, weld along the bottom, and drill holes for mounting screws at the top
    started off by making a new floor pan for under the seat bottom. 18 gauge steel, pre stretched the areas the bead rolling would be done to keep it flat.
    then made a cover panel for over the tail shaft of the trans. made from on piece ,no welding was done. still pretty rough, needs a lot of finish work but ran out of time for the day on this one
    making the floor pans and trans tunnel
    floor pans cleco'ed in place
    want to make the trans tunnel as small as possible since room is tight in this one. so i made some blisters in the tunnel for clearance. also had to make a blister to fit around where shifter comes out. so here are the basic steps i took to make the big weld on blister
    blister laid out, the black line is the hightlight or edge line of the blister
    using thumb nail shrinking dies in the recip. hammer. i shrink up to the black line
    all the shrinking done
    after a trip through the planisher
    and all welded on. you can see all the other blisters formed in the tunnel, stills needs to be hammered and dollied and metal finished out, but that will wait until i get all the other panels made and fit up
    starting forming the front part of the trans tunnel
    and made some new upper cowl braces. looks much better
    tig welding up the sides of the body
    after a little grinding and some ****m for guide, and a p*** with the file
    hammered and dollied for a while. then hit it with the high speed sander with 80 grit
    started with the DA on the top half, still need to work on the bottom some more. it is a tough spot to get to since i have to hammer left handed
    AHotRod and lothiandon1940 like this.
  3. cornfieldcustoms
    cornfieldcustoms
    stretched the rear of the ch***is to help support the bed. then mocked up a model T bed to get the idea of the stance on the truck. starting to look pretty good
    then i got a crazy idea to do an all aluminum bed that is a close version of a factory be. here is the p***. side roughed in
    got the rear bed wall roughed in and cleco'd in.
    started working on stake pockets
    here is the over look for the day
    [​IMG][/
    aluminum bed almost all roughed in. not to decide if i should make a new aluminum tail gate, or run the nice original one....... to many decisions
    kiwijeff and AHotRod like this.
  4. cornfieldcustoms
    cornfieldcustoms
    the bed is done minus the actual floor, made the aluminum tailgate with custom script. made extended aprons from aluminum and worked on the last couple filler pieces on the bed. started to make some good head way on this one. just need to get the correct wheels and tires on it for the total look
    made an adapter to run a stock model A steering wheel with a quick release hub
    bent up and dimpled some bed supports/ risers. got them clamped in
    and started making the aluminum version of the 30-31 commercial truck grill shell
    AHotRod likes this.
  5. cornfieldcustoms
    cornfieldcustoms
    rolled the Pope RPU out side for a good distance look. still waiting on the front wire wheels to come back from cleaning, so we used some steelies to roll it around
    started on the 4 piece aluminum hood, all hand made in the shop, hand rolled hinges
    still needs some fine tuning and t*******
    got the correct front wheels back from the cleaner. painted and tires on
    extended the stock running board to meet back up with the fender. added a few louvers to dress up the flat part
    got the upper stantions chopped , welded and smoothed out
    and got the inside of the bed truck bed lined
    more to come in the next couple weeks. it will be in my booth at Cincinnati cavalcade of customs, Indy Motorama 1962 and Detroit
    51 mercules, wingnutz and AHotRod like this.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Impressive work,I'm subscribed! HRP
    lothiandon1940 likes this.
  7. olcurmdgeon
    olcurmdgeon
    hell of a nice RPU! Great craftsmanship.
  8. Sakke
    Sakke
    from Finland
    WOW !!! That is really cool pickup !!! Great stance and heavily chopped windshield makes the right look !!!
  9. GASSERBOB
    GASSERBOB
    from USA
    Beautiful work. You really got your act together.Keep it up.
  10. cornfieldcustoms
    cornfieldcustoms
    thanks for the kind feedback!!!! it is always good to hear good things about something you have been obsessing over for months
  11. TomH
    TomH
    You sir are a craftsman!!
  12. Been watching this on IG, Very cool.
    Great workmanship as usual from you.
  13. walter
    walter
    Very nice build
  14. Dean Lowe
    Dean Lowe
    Gonna' be a hell of a nice RPU........................even if it isn't a '29. ;)
  15. volvobrynk
    volvobrynk
    from Denmark
    That is some impressive alu work, and some impressive work in general. But I do like the alu stuff. :cool:
  16. The37Kid
    The37Kid
    WOW! Nice work, that is going to be really nice. I like the look of the 26-27 bed with the front stake pocket location, guess you'll have a folding top. Bob
  17. loudbang
    Holy **** once again you guys do some fine work.
  18. hipster
    hipster
    Nice! Really nice.
  19. mgtstumpy
    mgtstumpy
    Fantastic skills, I only wish I could possess them
  20. no.scar.no.story
    no.scar.no.story
    Really nice work. I'm impressed all over again with every new pic. That's gonna be killer.
  21. chevy57dude
    chevy57dude
    If the young owner of the car is helping you with the build, the education he's getting is worth as much as the car! Your work looks like it came from an aircraft lab. Amazing work on that car.
  22. cornfieldcustoms
    cornfieldcustoms
    thanks again everyone
    thanks man, he is helping out on the build a lot. we are the same age and is good to be able to help out friends, especially when he can use the skills on more cars later on
  23. lothiandon1940
    lothiandon1940
    Beautiful, beautiful work! You are extremely talented. This truck is going to be outstanding.
  24. Very very nice !!!!
    Every place you look there's even more to see.
  25. rusty1
    rusty1
    ...I'm almost speechless...WOW!...great lookin rpu
  26. Skimmer
    Skimmer
  27. El Hueso
    El Hueso
    Beautiful work!
  28. bmita
    bmita
    i stopped by mikes shop to see the pope rpu, all i can say is WOW! lots of work and craftsmanship put into this hot rod. you really have to see it in person to see all that has been done to it and best of all it is not done. i really cant wait to see it finished. mike you really hit the nail on the head with this one. awesome work.
  29. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Boy is that neat!
    KK
  30. cornfieldcustoms
    cornfieldcustoms
    Thanks everyone. Should have more progress pics today
