Projects ** 1961 Ford F-100 Unibody Build**
Discussion in 'The Hokey Ass Message Board' started by fiveoh108, Dec 16, 2014.
  1. fiveoh108
    fiveoh108
    I just bought a 1961 f100 a few weeks ago and have started a restoration/ rebuild. I'm not sure what I'm going to do yet exactly, but it's a short bed unibody that is fairly rust free.
    When I bought it
    After a little sanding and primer
    Grinding on the bed to make it rust free again
    Mike T
  2. HOTRODPRIMER
    HOTRODPRIMER
    These old trucks are cool,my father in law had one and always intended to hot rod it but he just drove it daily until it was totaled on his way to work. HRP
    fiveoh108 likes this.
  3. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Looks like a good start
  4. Bruskie
    Bruskie
    My daughter has one also but hasn't been able to work on it yet. some day maybe
  5. fiveoh108
    fiveoh108
    It's a 223 straight 6 with a 4 speed and a 6 cyl rear end. I changed the plugs, cap, rotor, oil and filter. I was going to change the points but when i popped off the cap I found it had a mechanical advance pertronix... Score for me. I also cleaned out the crank case EVAC lines and pcv valve, adjusted the carb and wiped everything down. It runs great and shifts good, just gotta find a shifter ball
    As you can see by one of the pics. I got a stock 9" that came outta a 1962 short bed unibody, with the correct shock mounts and all. I plan to clean it up and get installed soon
    Mike T
  6. I'm looking to pick one up for a shop truck!!
  7. fiveoh108
    fiveoh108
    Moved to slick60s
    Mike T
