Projects Finally I get my Flathead powered T Roadster
Discussion in 'Traditional Hot Rods' started by mctim64, Dec 4, 2014.
  1. bone31
    bone31
    Rear plate,tubing for rear plate,front torque tube flange and bearing holder this part is made in two parts. IMG_1056.JPG IMG_1054.JPG The two 3/4" holes in the rear plate are centered in the plate and are 3.000 apart.
  2. bone31
    bone31
    IMG_0207.JPG IMG_1027.JPG rear plate radius being machined on precision rotary turn table, another tool you need in the machine shop business. IMG_1027.JPG
  3. bone31
    bone31
    now to the lathe to bore the large hole which is for the pinion bearings to p*** thru and locate for the welding jig.Small hole for the lower shaft to p*** thru, the counterbore is to locate the lower bearing.These bores are undersize they will be finished later after welding. DSCF0001.JPG
  4. volvobrynk
    volvobrynk
    from Denmark
    I'm a mechanic by trade, worked as a welder for a decade. So I'm not a machinist at all, but to me this is almost like workshops p@rn!
    That is awesome!
    Dident people refer to this kind of work as a welded QC or a banjo QC. As a general that is, this would be known as plain awesome!! :cool:
    Blue One likes this.
  5. Very nice work Mike! I'm glad you are sharing it with us, makes my thread a whole lot more interesting.
  6. bone31
    bone31
    getting ready to set the welding jigs,plates are bolted on to help to prevent warpage,the turned down lip really helps to hold it. IMG_1060.JPG IMG_1061.JPG [/ATTACH] IMG_1062.JPG
  7. bone31
    bone31
  8. bone31
    bone31
  9. bone31
    bone31
    IMG_1066.JPG IMG_1067.JPG jigs installed in order
    Lil'Alb, FlatJan and chryslerfan55 like this.
  10. bone31
    bone31
    A 3/4" shaft is used everything is now centered ready for clamping IMG_1069.JPG IMG_1068.JPG
    FlatJan, chryslerfan55 and kiwijeff like this.
  11. bone31
    bone31
    now the side plates are on and the end jigs ready for welding IMG_1006.JPG IMG_0793.JPG IMG_0794.JPG
  12. bone31
    bone31
    remove end jigs only weld on rib the side plates are still on. This picture was taken later when was cooled IMG_1072.JPG IMG_1070.JPG
  13. ZAPPER68
    ZAPPER68
    from BC
    This has got to be one of the best 'how to' threads ..... ever!
    clem likes this.
  14. pitman
    pitman
    The QC as built. Thanks for these sequence steps.
    The '26-27 is an inspiration, look forward to seeing your build!
  15. Jethro
    Jethro
    Very nice!...Well done!
  16. bone31
    bone31
    I have a very good welder do the welding.When the welding is done let it cool not in a cold place but a warm place.Let it sit for five days, then heat the whole thing to about 400 degrees with a torch just where you cannot touch it.Let it sit two more days in a warm place then remove the jigs.This is a way of removing stress, normalizing.This is the way jig and fixture guys make precision tools, a lot of stress with that much welding.The center section was cast 65 to 75 years ago need to treat it nice give it every chance to be strong and stress free, when it is stress free it will turn smooth forever.
    kiwijeff, spasecadet, RICH B and 4 others like this.
  17. bobo1
    bobo1
    from France
    Very very very nice job bone 31 Thank you for your very interesting experience
  18. I've never cared for quick change rear ends really, but holy **** man i want one of those centres!
    Squablow likes this.
  19. Also, have you considered TIG welding all of it for a smaller, less heat affected zone weld?
  20. bone31
    bone31
    Nick I let the welder do it his way as he can tig weld
  21. crminal
    crminal
    Yeah, I'll call ya weird ;~)
    This project will turn out like all your work....... beautiful.
    Looking forward to it progressing.
    mctim64 likes this.
  22. bone31
    bone31
    while we are waiting to machine the housing,the next thing is to turn and grind the end of the pinion.this is to fit the end bearing in the floating plate.This is one of the hardest things to do as it is about 59 to 62 rc hardness like a coke bottle.Most shops will not touch it or send you to somebody that has a cylindrical grinder, at about $400.00 first rough down with carbide tool bit,must be finish ground or it will not be round plus .000 nothing minus .0001 I have a nice tool post grinder about 60 years old works perfect diamond dressing the wheel. IMG_1044.JPG IMG_1043.JPG
    chryslerfan55 and s55mercury66 like this.
  23. bone31
    bone31
    I have internal grinding quills that will turn 35500 rpm I love this old ****, when we cut the splines I will use a dividing head made in 1933 a Van Norman IMG_1051.JPG IMG_1052.JPG IMG_0359.JPG
  24. bone31
    bone31
    that is .001 minus on the end dim.
  25. rileyrecords25
    rileyrecords25
    Got to see your work at b-ville this year bone31 real nice stuff, I threw the water melon in the back of your coupe! Hope it stays dry for 2015!
  26. bone31
    bone31
    The melon was Oregon sweet very nice thing to do.
  27. Frames
    Frames
    Trans sprint 033.jpg Trans sprint 034.jpg KISS. built 5 of these. 3 are in my own hot rods. NO milling required. used a hole saw. tube welded to the outside of the banjo. does not extend inside. made a fixture off a Halibrand to install the front bearing retainer. my QC gear housing [ my own pattern] eliminates the extremly heavy 7/8" thick plate. foundry charged me $7.00 a pound for casting. i sold the pattern. plans and fixtures to a guy in AZ.
  28. bone31
    bone31
    nice love to see all the ways that do the same things, and how they are made.
    chryslerfan55, volvobrynk and mctim64 like this.
  29. bone31
    bone31
    now we have a solid one piece center section that has been stress relieved the pinion has been installed,the machine work has been finished.Before the machining the head on the mill was indicated to the table within .001 that is one thou. the angle plate to .001 with the table travel, the center section to .001 to the pinion wall.If you work this way it will make things much better none of this a couple of thou. here and there or it is pretty close, as a tool and die maker it must be right.The holes for the pinion bearing retainer,the bearing holder, and the rear housing, have been drilled and tapped. IMG_1089.JPG
  30. bone31
    bone31
    this is the torque tube end ford tube pattern,holes for the bearing retainer, bearing pocket .001 over bearing dia. IMG_1091.JPG
