1952 chevy coupe. This thing kind of fell in my lap. As far as rust, it's a really solid car. Couple small holes on the right front floor board and a roughly 2" area on the left rear floor board. Trunk, 1/4s, rear tail pan are all solid. No gl***. Rear seat and front seat are there although the front seat springs are shot. Would have to replace with foam. Dash is all complete but has over spay on it from some dummy who primed the car. Springs on the car have been heated to lower the car, I didn't do that either. The engine runs if you feed the carb, tank is prob dirty. All trim is there but has dings and dents. Front fenders are loose and the doors don't line up good. Car needs a good panel alignment. Also, whoever did the body work didn't know how to and used more filler then needed. A good blocking and a re prime would go a long way. I'm making the car sound worse then it is but I'm trying to describe it very well. 6502552705 for more questions and pics
