Body mount bushings-what do you use?
Discussion in 'The Hokey Ass Message Board' started by 55chieftain, Apr 20, 2010.
  1. 55chieftain
    55chieftain
    Is there a cheaper alternative to body mount kits. Just please don't say hockey pucks. I was looking at some of the nylon blocks for like a truck lift, I can get those in 1" . Is there a supplier that sell just the bushings, I already have the bolts I need.
  2. ol'chevy
    ol'chevy
    Use body mount bushings. Call Steele Rubber, they probably have them.
  3. JEM
    JEM
  4. Mr48chev
    When I put my 51 Merc coupe body over on the stretched 75 Monte Carlo frame I used the motor mount biscuits for Tri 5 Chev cars and pickups. Inexpensive and easy to get.
  5. 52 csb
    52 csb
    Hi 55chieftan, i used 1/2" conveyor belt,cut out by radio ch***is cutter to 2", then used a 1/2" hole punch for center. Put a 1/2' SS nut there so it wouldn"t totally collapse. Ran a 3/8 bolt through . There was a washer on top and bottom... Good Luck jim:D
  6. yardgoat
    yardgoat
    I like conveyor belt also,real cheep i bought a 9/16 in thick x34in widex6 ft long for $1.00,stuffs heavyer than you think for size.
    On the other hand...if i had good factory or close ones id use them.......YG
  7. 55chieftain
    55chieftain
  8. You don't want to use a steel sleeve because it will become the frame/body contact point and the pad will just be along for the ride.
    You should use a self locking nut on the thru bolt so tension can be firm but not over tightened.
  9. bryan6902
    bryan6902
    I have all the old ones from my 57, they're in okay shape, usable. Pay for the shipping and I'll send them your way, PM me if interested.
  10. falconsprint63
    falconsprint63
    from Mayberry
    that's exactly what I used, I was able to trim them to exact fit (I had to shiim the frontup a few inches so they werent' necessarily standard lenghts as you go back. worked well and have been in place a decade with no problems.
    QUOTE=55chieftain;5151111]Is there a cheaper alternative to body mount kits. Just please don't say hockey pucks. I was looking at some of the nylon blocks for like a truck lift, I can get those in 1" . Is there a supplier that sell just the bushings, I already have the bolts I need.[/QUOTE]
  11. Master of None
    Master of None
    I've used a section of semi truck rubber mudflaps. They were nice thick rubber ones, used them between the wooden blocks on my brothers truck bed on his 48 Chevy.
  12. humpie
    humpie
    I bought some motor mounts from napa(BK-602-1045)they are 2"round,1" thick with hole for 3/8" bolt.Worked for me:)
  13. koolkemp
    koolkemp
    I used the hard rollers that you put on a boat trailer , so the boat can be rolled on/off supercheap , you can cut em with a handsaw or use the mitre saw any width you want and they already have a 1/2" hole in the middle, with all the grade 8 hardware included it cost me about $30. to build all the mounts to put my 47 Ford body on the frame.
  14. 56don
    56don
    I would use body mounts if available at all. I would not want to go to all the trouble to do a body off build and end up having to do it over because I cheaped out on an important part.Not saying you are cheap,as sometimes you have to fabricate,but if they repop them,I would buy new ones.
  15. I went to my local "rubber supplies" and the guy punched them out of 1" sheet rubber, or could have been neoprene. Cost about a buck each (Repo Caddy were about 15 bucks each!)
  16. 57JoeFoMoPar
    57JoeFoMoPar
    Hockey pucks do work pretty well. :)
  17. 55chieftain
    55chieftain
    Huh? My factory mounts had a metal sleeve in them.
  18. 55chieftain
    55chieftain
    Thanks, mine are reusable as well, but I would like to replace them. I'm not spending $250 for a body mount kit.
  19. bryan6902
    bryan6902
  20. pauls fords
    pauls fords
    Bought a good used tire with lots of tread left $20 cut it up with a sawzall and drilled whatever size hole needed, had plenty left over to double them up or not-or to make them over if the size wasn't right, its steel belted so it wouldn't come apart, worked perfect. If you have a tire already, well you just saved the $20.
  21. AAFD
    AAFD
    from US of A
    thrashingcows likes this.
  22. Thank you for this great info and link....just what I have been searching for!
  23. fordor41
    fordor41
    I needed some mounts and were not available. I bought 2 part castable urethane from Mcmaster-Carr and made molds from plaster of paris. Been on my car for 15 yrs
