Projects Got a real 32 roadster
Discussion in 'The Hokey Ass Message Board' started by Johnyeyeball, Jun 12, 2012.
  1. Drivers door with a new jam
  2. And patch
  3. timwhit
    timwhit
    First time I've seen your thread. Like what your doing. Tim
  4. Stovebolt
    Stovebolt
    I really dig the route you're taking with this build.
    Where'd you get these shockers from?
  5. kidcampbell71
    kidcampbell71
    Five years !! MUCH respect man !!!!! Good for you. That looks awesome. I love it.
  6. They are old indi friction shocks I got from a good friend Ernie Harmon
  7. Stovebolt
    Stovebolt
    I don't suppose he has any more?
  8. Fixed my cowl
  9. P***engers door fixed
  10. At vintage hammer
  11. seatex
    seatex
    Yummy, you're livin' right
  12. brady1929
    brady1929
  13. hotrodA
    hotrodA
    I used a LB '32 stock top on mine, and it's chopped 3".
    I installed it around the tack rail first, then trimmed the 3" extra off at the rear top bow. The rear panel has the stock gypsy curtain, and it comes with no window cutout so you can center and place your rear window frame. They also sell the chopped window frame. It's a VERY nice, complete kit with easy to follow instructions. The ONLY problem was some of the screw-in rail snaps were easily ruined screwing them in, even with predrilling the holes. LB gladly replaced them. Tip: don't use their tacks, they are hard to install and don't hold. I used a pneumatic stapler, and it worked perfectly.
  14. Thanks so much for the info I need to know about their products
  15. HellsHotRods
    HellsHotRods
    No Pre-war roadster had an open drive shaft, especially if you are running with 36 wishbones in rear. You might want to re-think the direction you are headed with that. People will see that and wonder what you were thinking.....
    Just my .02
    (is the back half of the car Brookville?)
  16. Yeah that was the old set up. I'm running a full 34 rear end 39 gearbox with a 34 21 stud closed driveline. aluminum heads
  17. The rear quarters are and the subrails are Brookville . Every thing else is real
  18. This is what the roadster looked like 4 years ago when I bought it as you can see the doors are laying up against the Rhino to the right this is all I had to start with and the ch***is by the way is real with clear numbers it is now registered as a 32 roadster in California with 32 plates and cleared 32 numbers
  19. 5 days before lars
  20. 4 days
  21. 3days
  22. 2 days
  23. 1 day
  24. Day of my reveal
  25. Today at the antique nationals it's finally done and it was absolutely worth the wait
