Hot Rods Top molding Model A
Discussion in 'The Hokey Ass Message Board' started by pecdaddy, Jan 1, 2015.
  1. pecdaddy
    pecdaddy
    Is it even possible to bend the 2 piece top molding that I got from Snyders? Not too thrilled with the thought of using hide-em.
    Also I did do a search.
    Thanks for the help.
  2. pecdaddy
    pecdaddy
    Any help out there?
  3. Speed~On
    Speed~On
    Post a pic. There are a ton of us on here that have Model A's. I'm sure we can ***ist. Let's see what piece you are referring to.
  4. woodiewagon46
    woodiewagon46
    from New York
    Yes, post a picture. If it's the molding I'm thinking of, I would fabricate some sort of bending fixture out of plywood, to mimic the profile. They kink very easily and I don't know if I would try to bend it by hand.
  5. pecdaddy
    pecdaddy
    I will get a real pic today. This image is from the Snyders web site. As you know it will have to make some sharp and compound bends. The tack strip part is hella difficult.
    Thanks
  6. pecdaddy
    pecdaddy
    Part# a-47301-s
  7. millersgarage
    millersgarage
    why would you need it to make sharp bends?
    It won't.
  8. pecdaddy
    pecdaddy
    Along the side and across the rear.
  9. pecdaddy
    pecdaddy
    Here is a real pic.
  10. Yes it will bend to fit. No, it's not easy. DO NOT try to bend it by hand. What I have done and that worked well is make a plywood buck. I'd make it the Exact profile of the inside radi. Then screw the Buck to another piece of Plywood larger than the piece you just made. Clamp the trim strip at the bottom of your part and gently pull it around the buck keeping the trim flat against the larger piece of wood. Take your time, be careful, trust me it works. Here is a photo of a buck I made to do a rear wheel well opening out of square tubing. Just one of many jobs I've done using this method. Yes I've done that exact top job this same way.
    The Wizzard
    P.S. You should Not need to use any heat to do your job. On the job in the photo I used heat to stop the recoil in the Square tubing. Same project, different job for you.
    fxstc127ci likes this.
  11. pecdaddy
    pecdaddy
    I will give it a shot.
    Thank you
  12. insomniacshotrods
    insomniacshotrods
    I bought a video from the diablo A's showing how to put on the top material on a model A and they used a oxy torch adjusted real sooty , ran it over the trim and bent it by hand.
  13. pecdaddy
    pecdaddy
    Thanks. I will check that out.
  14. If your new moldings are Alum. and you have never annealed anything before I highly suggest "not" practicing on them.
    The Wizzard
  15. pecdaddy
    pecdaddy
    They are steel.
