1940 Mercury Eight **Pics**
Discussion in 'Traditional Hot Rods' started by Boots89, Dec 30, 2014.
  1. verde742
    verde742
    also look under rear end,bumper, behind b some people put a release pull or push, for opening trunk.
    could look like loose stiff wire... might be inside gas flap too.!!
    looks like a 49 Plymouth bumper to me..
  2. Boots89
    Boots89
    Thank you for your response!!! We will have to check it out thus week!
  3. Boots89
    Boots89
    Any pictures of what we should be looking for greatly appreciated
  4. Kraco is not original
    Posted using the Full Custom twig in the sand App!
    lothiandon1940 likes this.
  5. I would put that thing straight in my garage and tell everyone else to **** off if they want to sell it.
    It looks like SUCH a good base for as above, a nice tail dragger. Think '40s era custom. A lot of tacky **** is on it but that can all be changed.
    lothiandon1940 and Boots89 like this.
  6. Boots89
    Boots89
    "I bought this in June of 1960. I STILL HAVE IT!" Written on the back
  7. Boots89
    Boots89
    I rotated the picture
  8. Super Streak
    Super Streak
    from Florida
    You should go over to Fordbarn and ask for pictures of what the interior looked like original. They would probably be able to help you with that part of it.
    I knew a guy years back that had a stock '40 Merc, it didn't have any wood on the dash from what I recall. Good luck with it.
    Boots89 likes this.
  9. birdman1
    birdman1
    please leave it the way he built it. No need to "modrnize " it, it is a true early 60's HOT ROD. the wood dash is awsome, and clean up the wheels and use them.
    Boots89 likes this.
  10. Boots89
    Boots89
    The plan at the moment is to get the brakes working, motor running and get it movable. I've noticed looking at pictures the tail lights are shaved?
  11. Boots89
    Boots89
    Me and my uncle are going up to work on it later this week. We are going to clean all the pine cones and needles up. The floors seem to be intact but I'd like to pull the carpet up to check.
    Here in ny it's winter and the way the car was stored outside, the ground below the car was dry Sandy dirt. It was soft, as it sunk in the car wasn't exposed to damp wet ground. It was odd on how loose the dirt was under the car. We practically dug the vehicle out with our hands. Almost was like silt...
  12. Slopok
    Slopok
    The bucket seats & armrests also are not original interior items.
  13. Boots89
    Boots89
    My question today is what rear end would this merc have if it wasn't swapped out? I found 2 rear ends outside one looked like a Ford rear end. Looks simular to the picture. No brackets or brake ***embly. Just a bare axle housing. The other axle I couldn't get a good look at but I saw it had shoes
  14. Slopok
    Slopok
    It would've had a torque tube originally.
  15. lucas doolin
    lucas doolin
    Go to the BING search engine, type in "1940 Mercury convertible - images" for reference pictures.
    Concerning value - Your Mercury is a great find, but ultimately it's worth only what someone is willing to pay for it. Yes it's desirable and yes it's rare but several running and driving 40 Mercury convertibles have been offered for sale recently in the $40,000.00 range and they looked like nice original cars from dry states.
    Good luck keeping it.
  16. Boots89
    Boots89
    Anything anyone would want me to take pictures of when we go back to work on it I'll take pics.
  17. Texas Webb
    Texas Webb
    Try to convince the family of the history and memories and that it would be better kept in the family.Sad when money takes the lead upon one's p***ing.
    Boots89 likes this.
  18. Boots89
    Boots89
    I agree 100% 4 out of 5 want to keep everything. I have no say in anything, but I been convincing to the ears
  19. rotorwrench
    rotorwrench
    The early Merc rear axles were almost the same as the Ford banjo axles except they had a one piece pinion/driveshaft set up where the there was no coupler. It just went all the way from the u-joint to the ring gear. A 37 thru 42 Ford or Mercury rear axle can be made to fit. Mercury cars were longer wheel base but it was all in front of the firewall. Ford & Mercury side shift transmissions were all the same from 1940 thru 1948. Any Ford 59A flathead engine would fit but it would be nice if your uncle put the old one under a bench somewhere. The 99A engine has very thick cylinder walls and can be bored out to 3 3/8" for a Big Bore engine.
    Boots89 likes this.
  20. Boots89
    Boots89
    We are hoping my great uncle kept the flat head, that's if the flat head was in the merc when he bought it in 1960. A lot of information was never p***ed down and it's becoming a mystery that were trying to solve. Thank you for your input.
    All of this information is helping us out greatly. Thank you
  21. Mart
    Mart
    The parts of the dash that are wood are not original. The metal parts are, but things like the glove box lids may be missing. The steering column, seats, shifter and pedals are not stock. There is a chance the engine was fitted to the original gearbox with an adapter, and the original rear axle was retained. What is probably more likely is that the engine, box and axle were changed. The bolt patterns on the hubs will provide a clue to what has been kept and what has been changed.
    I like the 5 spokes and the bias plys.
    Mart.
    Boots89 likes this.
  22. Boots89
    Boots89
    The lid for the glove box is their. The wood is mounted to it.
    We opened the glove box and found the registration and insurance from 1996.
    The owners Manuel for the radio and a home from a critter
  23. lothiandon1940
    lothiandon1940
    Just found this picture for inspiration. Not mine.....only wish it were.:D header.jpg
    kidcampbell71, Boots89 and i.rant like this.
  24. Boots89
    Boots89
    That Is one sweet looking car!
  25. 1946caddy
    1946caddy
    from washington
    Why don't you just buy the car from the estate? Take a bunch of pictures and put it on E-Bay with a huge reserve and when the auctions over, pay the highest bid amount to the estate. Sounds fair to me.
  26. Rogue63
    Rogue63
    from New York
    Sorry about your family's loss,great find, perpetuate your uncles love for cars and get her back on the road.Hope money doesn't enter on doing the right thing.
  27. Yes......that's a 1949 Plymouth rear bumper (has the "ripples"). Those have been a popular item on
    custom cars over the years. The seats appear to be covered in velour or crushed velvet.....originals would have either been leather or probably a gray or tan fabric.
    Here are links to a couple ads of 40 Merc converts for sale.....you can see what an original dash and interior would look like. http://www.hemmings.com/cl***ifieds/dealer/mercury/unspecified/1327998.html
    This one is a resto-rod...........http://www.hemmings.com/cl***ifieds/dealer/mercury/unspecified/1675900.html
  28. mr.40ford
    mr.40ford
    Nothing better than a 40 ford except a 40 Merk.Lots of luck with it.
    Boots89 likes this.
  29. smw24tea
    smw24tea
    Nice old Merc, I have one like it, if you find that you need any infro. or small parts ,please contact me, I'm sure that I can help you get it back on the road.
    Boots89 likes this.
  30. Boots89
    Boots89
    Thank you. Haven't had a chance to this week, planning on Monday if the weather is good to start playing
