Projects My First Model A Hot Rod Build
Discussion in 'The Hokey Ass Message Board' started by Camsore, Jul 5, 2014.
  1. Camsore
    Camsore
    from Las Vegas
    20130524_140326.jpg 20130529_151200.jpg 20130529_151233.jpg 20130526_153205.jpg Working this week on center section and mockup of SBC and transmission.
  2. ChopTopJimmy
    ChopTopJimmy
    Camsore, It looks great. Keep up the good work. CTJ
  3. Camsore
    Camsore
    from Las Vegas
    [/ATTACH] 20130629_135141.jpg Got a lot of mockup done this week, motor mounts finished but I am not sure if the steering shaft will clear the headers. Also may be to hot for the coupling joint.
  4. OFT
    OFT
    Is steering box mounted a little high? Use a flat pitman arm (to move box lower) instead of what appears to be a dropped pitman arm in first picture.
    I use a similar set up using a 525 manual box on the OFT for past 8 years (with SBC). With lakes style headers and a BBC the 6 years before that.
  5. Lad_RoadDevils
    Lad_RoadDevils
    I agree on dropping the steering box by using a flat pitman arm. Also, great choice on the Transmission. I got my 700R4 from Monster and it's been bulletproof.
  6. WelderSeries
    WelderSeries
    Alliance Vendor
    Nice work! Thanks very much for your business.
    dw
  7. Hot Rod Rodney
    Hot Rod Rodney
    from USA
    Ditch the block huggers. Use lakes-style out the sides. Or if you absolutely must have under-car exhaust consider ram's horns. Easier than relocating steering.
  8. Camsore
    Camsore
    from Las Vegas
    20140816_102740.jpg Thanks for all of the ideas. I do have a flat pitman arm. I lowered the box a little and ground a small notch in the exhaust flange and it works.
  9. Camsore
    Camsore
    from Las Vegas
    20140602_104206.jpg 20140602_104219.jpg I had to rebuild the B post, it was in bad shape on the bottom.
  10. inkstain27
    inkstain27
    I like it, keep up the good work
  11. Camsore
    Camsore
    from Las Vegas
    20140416_105915.jpg 20140416_133901.jpg 20140416_133954.jpg Progress update, Working on the dash. Welded the top of the 29 dash to aftermarket bottom.
  12. Camsore
    Camsore
    from Las Vegas
    20140416_134213.jpg 20140416_134256.jpg 20140317_162039.jpg 20140416_134326.jpg 20140318_154309.jpg Progress update, Working on a new top. I will be covering the outside and will leave the inside as shown.
    Hotrodmyk likes this.
  13. 26 T Ford RPU
    26 T Ford RPU
    I haven't checked in for a bit but you have been busy !! Nice work ! JW
  14. AHotRod
    AHotRod
  15. passngas
    passngas
    Looking good.. Btw I like the pictures of the vineyard!
  16. OFT
    OFT
    Good thought on looking at inside wood for top. Beat's looking at chicken wire by a long shot!
    Earl
  17. Camsore
    Camsore
    from Las Vegas
    20130912_143203.jpg Update, Brake pedal mounted and some brake lines finished. I also incorporated a steering support mount. 20130911_104740.jpg 20130911_104720.jpg
    AHotRod likes this.
  18. bjinx
    bjinx
    Where's all the pics?
  19. Really nice work man! Keep up the great progress.
  20. banginona40
    banginona40
    Wondering what parts you used on the front end besides the Welder series crossmember.
    I need a similar setup.
  21. Doodlrodz
    Doodlrodz
  22. Camsore
    Camsore
    from Las Vegas
    Hello Banginona40,
    I got all of the front end parts from Kenny's Rod and Kustom. The axle is a Super Bell and GM disk brakes.
    They gave me a great package price and were great to deal with. Let me know if you need anything else.
    Larry
  23. A really great start, good luck.
  24. jimcolwell
    jimcolwell
    from Amarillo
    Are you sure this is your first build?
  25. Camsore
    Camsore
    from Las Vegas
    20140413_072303-1.jpg 20140413_072320-1.jpg Took the car for a short drive to get the bugs out. All went well, the SBC ran great. I think I have enough power for this little car. I plan on driving it 500 miles for testing. I want to make sure I like it before I tear it down for paint.
  26. Camsore
    Camsore
    from Las Vegas
    20141122_103431 (2).jpg 20141122_103444.jpg 20141122_100648 (2).jpg The frame was painted today and I am happy with the color. I looked am many different reds and had a hard time choosing one.
  27. mad mikey
    mad mikey
    I like the RED, LOL!:D
  28. Camsore
    Camsore
    from Las Vegas
    20141227_125405.jpg 20141227_125421.jpg 20141230_132451.jpg 20141230_132507.jpg 20150103_163911.jpg I have been busy doing the ***embly. Posting some photos of the progress, going well but slow.
    Larry
  29. Camsore
    Camsore
    from Las Vegas
    20150126_134235.jpg 20150126_134250.jpg IMG_20150122_151801.jpg IMG_20150122_151819.jpg 20150126_134302.jpg 20150126_134219.jpg
    More ***embly completed and most of the wiring done.
  30. 26 T Ford RPU
    26 T Ford RPU
    What a job you've made of that !! Cool :D JW
