Technical Why Cant I Get This Door Hing Pin Out?
Discussion in 'Traditional Hot Rods' started by Mark Jenny, Jan 3, 2015.
  1. A hammer and drift pin is many times more likely to bend the sheet metal the hinge is attached to. An air hammer is a better choice.
    Heat is going to do the trick getting the pin out almost every time. It's also guaranteed to **** up the paint 100% of the time. Here's the thing to consider though, if you heat carefully and protect surrounding areas you just need to repaint the hinge. If you twerk a hinge or supporting structure you multiplied the amount of work exponentially.
    Hard to say what you have there, but the flange should not be on the bottom.
    Do not try to drive the knerls thru the hinge. If someone installed the pin bottom side up and you drive it the other way you'll really be hating life.
  2. flux capacitor
    flux capacitor
    Joeycarpunk brings up a good point. The wax trick is pretty amazing, recently a customer of mine had some bulldozer pins froze solid not even hinting of coming out. He heat & beat in them for hours on end. Not wanting to be made fun of by his pals, he waited until they left then lit some candles on the ****ers , let them melt down soaking with wax ..... Low & behold he is a believer every single one came out easy!
  3. Nailhead Jason
    Nailhead Jason
    I had the same problem with the sloted hinge screws on my A . Some pb blaster and a 10 dollar impact driver from harbour freight got them all knocked loose. Give that a try if you end up having to take the hinge off. Beats having to drill them out.
  4. i.rant
    i.rant
    I have a hinge removel tool,used once. PM me if you would like to borrow it if all else fails.
  5. jamesd1502
    jamesd1502
    from san diego
    I had the same issue on all my door pins. I had to grind off the tops, lots of heat(cautious to paint or pannels) and a air hammer. Good luck!!!
  6. tedley
    tedley
    from canada
    Pain in the *** is what it is.
  7. perk30
    perk30
    I used the Bob Drake tool to get my pins out. Cranked the tool down after hitting it with PB Blaster and let it work overnight. Cranked it down some more the next day and finally got it out. The tool broke just as I was getting my last pin out but I did get them all out using that method over a period of a few days.
  8. 5window
    5window
    Here's what my '31 coupe hinge pins looked like after we go them out. The top two, I'd already drilled out with a 12" long 1/4" bit for hing pin mirrors. Note that Model A original hinge pins are NOT 1/4" OD
  9. Rusty Cheese
    Rusty Cheese
    Plan candle wax. Don't know why it works but it does. Got the idea on the HAMB...
  10. HOTRODPRIMER
    HOTRODPRIMER
    You must have a darn good one,I managed to break the one I got from Bob Drake. HRP
  11. Larry W
    Larry W
    from kansas
    Heat and wax, It works .
  12. gbones32coupe
    gbones32coupe
    I thought it would be easy too but it took me 8 hours to do all four of my pins and hinge bolts it was a nightmare I drilled them then air hammered and I had to drill and tap all of my flat head counter sunk screws then had a hell of a time getting the plate out you want to knock them out from the bottom and out the top when drilling make sure you step the bit from small pilot to a larger hole but keep it strait it is hard to do with the door on the car then punch it out with some heat and a crayon heat it and sweat the crayon in like your sweating solder in a pipe then it will pop out You can use it for bolts too I know you may not want to heat it but sometimes you just have to. I whish I wasn't so cheap I should have just bought new hinges but I like driving my self insane with an air hammer
  13. 60 Belair
    60 Belair
    been stated already but this is what I did works great weld old craftsman's chisel to air hammer bit, I also like to heat and melt anti-seize in to pin area kinda like the wax trick. Andy
    belair likes this.
  14. Mark Jenny
    Mark Jenny
    Well...after many hours of drilling and using the tips I got here, I now have a mirror!!...yay!!!....never had so much trouble adding a mirror!!...first I tried a '"peep" mirror..but they wont work on these early fords...just no room in the jamb to accept the bracket...anyway..thanks to everybody here for the help and support!!...cant wait to remove them all to paint the coupe...yuck..:)''''enjoy the process...right?.thats why we do this....I think
  15. Mark Jenny
    Mark Jenny
    one more pic
  16. Mark Jenny
    Mark Jenny
    think I'll just buy 6 new hinges when I paint it :)
  17. timwhit
    timwhit
    Now you can tell someone else how to do it!!!!
  18. Mark Jenny
    Mark Jenny
    I want to try that wax trick...sounds cool!
  19. Mark Jenny
    Mark Jenny
    This particular pin had no mushroom shape at the top of the pin...it was cut off flush with the top of the hinge...the bottom had a slight flange to it..not from pounding on it in the past, but a machined lip...a couple of my 6 hinges have this scenario, the others have standard mushroom tops as seen in your pic that you posted
  20. Mark Jenny
    Mark Jenny
    brings up another topic/question...my graffiti coupe in my avatar has two door hinges..the full fender white coupe has 3...both are ***led as 31's...w***up with that?..is it because of the chop on the grey coupe?
  21. dan31
    dan31
    Because of chop. They cut out area of third hinge.
  22. Mark Jenny
    Mark Jenny
    Thanks Dan..solves that mystery..one thing though..seems like I;ve sen coupes chopped that still have 3 hinges???
  23. pat59
    pat59
    regarding buying all new hinges. When you see the price of 6 new hinges, ya might just wanna get that drill back out. LOL
    -Pat
    barett likes this.
  24. Mark Jenny
    Mark Jenny
    are they super pricey Pat?....
  25. So how do you figure that pin went in?
  26. Mark Jenny
    Mark Jenny
    I have no clue 31 Vicky...I'll try and remember to take a shot of the other door , it has a hinge with the same type of pin...then 4 hinges have the mushroom shape
  27. pat59
    pat59
    Mark,
    I think that I saw a set at around 400.00. They're all custom made. nice but steep.
    -Pat
  28. dan31
    dan31
    It just depends on how they decided to to the chop. My 31 is chopped and has 3 hinges. The doors are light enough and the hinge area strong enough that two is fine.
  29. Mark Jenny
    Mark Jenny
    Wow!!..you werent kidding Pat!!!..guess I'll salvage my hinges best that I can :)
  30. Mark Jenny
    Mark Jenny
    Thanks for the info Dan.....
