1952-59 Ford questions on a motor swap in a 54 Ford Customline
Discussion in 'Off Topic Hot Rods & Customs' started by clips221, Jul 16, 2014.
  1. clips221
    clips221
    It's been awhile since I posted in this forum. I have a 54 Club Coupe and am finally getting back around to working on it. I bought a running 302 engine out of a 76 F100 pickup and have a C4 transmission I'm planning on using.
    What have ya'll used for the motor mounts and transmission mounts during this swap? Thanks for any help.
  2. Rui
    Rui
    Cant help, but I do like the car.
    Good luck.
  3. chopd top
    chopd top
    from Florida
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    This will show you what to do: http://www.jalopyjournal.com/forum/media/albums/289-302-351w-swap-mounts.41498/ READ the comment below! DO NOT buy mounts made in India or China because the rubber is so bad mounts are failing in less than a year.I suggest these:http://www.ebay.com/itm/290997379867?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT and this: http://www.jegs.com/i/Prothane/311/6-1605-BL/10002/-1?parentProductId= Both are USA made and contain no outsourced rubber. You can also use these these:http://www.ebay.com/itm/Hedman-8840...Parts_Accessories&hash=item5406c710d8&vxp=mtr You might ask JEG's if they will price match on those ;)
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. clips221
    clips221
    I will post pics of the engine this afternoon. Car had a ford-o-matic transmission originally. I will be using the original rear end for now. thanks for all the help.
  7. clips221
    clips221
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    OK, Good news! looks like the front sump pan is a go,also if you want to save some bucks your manifolds will clear the steering box really well, just toss that canister gizmo on the drivers side. For better clearance on the p***enger side get this: http://www.ebay.com/itm/NEW-Ford-Mi...Parts_Accessories&hash=item1e6d43c98c&vxp=mtr Also it will crank a whole lot better than the old style large starter.Your Ford-O-Matic Column will work with the C-4 too check out this from Don Allen on the linkage mods to hook up your shifter: http://mainlineford.wordpress.com/
  9. clips221
    clips221
    5 months later I've ordered the motor and transmission mounts for this project.
  10. HOTRODPRIMER
    HOTRODPRIMER
    Looking forward to watching it go together,,I thought you sold the car. HRP
  11. clips221
    clips221
  12. HOTRODPRIMER
    HOTRODPRIMER
    I would think that your zip wheel would make quick work with removing the studs,,you don't need them. HRP
  13. JeffB2
    JeffB2
    from Phoenix,AZ
  14. HOTRODPRIMER
    HOTRODPRIMER
  15. clips221
    clips221
    had a friend over today that's gonna help me with the motor and transmission swap. I've gotta change the motor pulleys and my C4 is set up for floor shift.. He's got another set of pulleys as well as what ever has to be swapped in the transmission. He was concerned that the cross bracing under the car would have to be cut out or modified... Is this a concern or should the transmission and engine drop right in. I've bought the good engine and transmission mounts mentioned in the post above.
    any helps appreciated.
    Craig
  16. JeffB2
    JeffB2
    from Phoenix,AZ
    You should not have to cut anything underneath, my '54 has an AOD which is slightly larger than the C4 and no cutting was done.In the past there has been a few cases where the transmission cross member's holes may need re-drilling and this is due to the inaccuracy in manufacturing at the factory,as you have seen on builds done on car shows it's a good idea to do a trial fit by installing engine and transmission as a unit then you can make the adjustments easy.
  17. 59Bisquik
    59Bisquik
    Cool, another 54 coupe! I am in a similar build with mine. I look forward to seeing yours, please keep us updated.
