Technical SUN TRANSMITTER TACHOMETER
Discussion in 'The Hokey Ass Message Board' started by flathead 37, Jan 4, 2015.
  1. flathead 37
    flathead 37
    my dad was parting out this old f7 truck and I noticed the cool vintage tach in it. now that tach would go perfect in my traditional half ton truck im building, so I asked him if I could have it and to my surprise he said yes! so I was wondering if anyone else has got one of these in there hot rod? it looks really simple to wire. the terminals are labeled. what I found really interesting when I opened it up was the size D battery inside. I also question its accuracy when I do hook it up. any input?
  2. The 41Dude
    The 41Dude
    Not sure that is a Battery. Maybe some sort of other electrical component?
  3. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    You SURE it was a D battery? The batteries in these are often oddballs.
  4. prewarcars4me
    prewarcars4me
    from Bhc, AZ
  5. If there's actually a "D" battery in there, it isn't original. Probably a shade tree repair.
  6. flathead 37
    flathead 37
    well I found this old ray-o-vac flashlight battery in this cylinder than is part of the cover. than in the cover at the end of the cylinder there is a br*** sheet that connects to a screw connector that was screwed on to a wire that connected to a component in the box. here is what it looks like WIN_20150104_191612.JPG WIN_20150104_191713.JPG
  7. stillrunners
    stillrunners
    from dallas
    I've got one of those tach's....thought it was off something military.....
  8. dan griffin
    dan griffin
    How old is the truck that it came out of?
  9. flathead 37
    flathead 37
    it was an old 1945ish f7. not 100% sure.
  10. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Its not the correct battery. If it does work, it will be the wrong voltage and read incorrectly.
  11. wbrw32
    wbrw32
    The transmitter boxes are marked for their specific use,,,,AE,,8 cyl,6 volt---8 cyl,12 volt---and etc..the battery is special to them also,,,Williamsons in Chester,Ark is the best to repair these old units.
  12. flathead 37
    flathead 37
    this tach was being used on a big f7 truck with a 337ci flathead. in my truck I just got a little 221ci. will it still work?
  13. flathead 37
    flathead 37
    the tag says model e-1, 6 volts, 8 cylinders
  14. wbrw32
    wbrw32
    It will work providing you are running 6 volts and the batteries inside the EB1 box are correct,,and still good
  15. I am running the 6 cylinder version of that sending unit in my 53 Chevrolet.
    Williamson's changed it to 12 volts and eliminated the battery. It works great!!
  16. gwhite
    gwhite
    SUPER MODERATOR
    Yes, the D sized battery is correct. You have the earliest style Sun transmitter (E-series)...very rare. Later transmitters (EB series) used the oddball batts.
    Your transmitter should show the specifics on cylinders and voltage.
    Here's my old transmitter (also used a D sized battery);
  17. flathead 37
    flathead 37
    how could I check its accuracy? just hook up one I know is accurate at the same time I run this one?
  18. gwhite
    gwhite
    SUPER MODERATOR
    Yeah, that might be the best way...My tach (identical to yours) was off a couple hundred RPMs. Ran it like that for years, then realized that under the light bulb 'pod' there is an adjustment wheel - uses a flat blade screwdriver. Not sure how much adjustability is there, but worth a shot.
  19. dan griffin
    dan griffin
    Early 60s Chevy truck shop manual shows how to check accuracy using a battery charger. Later units used 1.30 volt batteries AA batteries are 1.6 when new. run them down to 1.35 volts and install they should last a year.
  20. Muttley
    Muttley
    As suggested by wbrw32, send it to Williamson's Instrument Service and have them give it the once over. They do fantastic work and can convert it to function properly with any ignition and without having to use a battery.
    wbrw32 likes this.
  21. deuce354
    deuce354
    They do great work. Hope your not in a hurry thou!
  22. gwhite
    gwhite
    SUPER MODERATOR
    I'd try it with the D-cell battery before sending it out for modern guts to be installed. Mine worked, tach just needed adjustment.
  23. flathead 37
    flathead 37
    so the other day i mounted the tach and the box and started wiring but i cant figure where to hook the distributor stud to. where on the distributor is it? i know its not the same one that you count the ignition.
  24. Muttley
    Muttley
