Art & Inspiration Wide Five Picture Thread
Discussion in 'The Hokey Ass Message Board' started by 55willys, Sep 27, 2014.
  1. flatheadfever
    flatheadfever
    What was the donor wheel?
    That is impressive.
    Thanks
  2. Shaggy
    Shaggy
    from Sultan, WA
    For you guys that are modifying them, there is FACTORY built 5 or 5 1/2" (i forget, i have 2 of them tho) wide 5's, kinda rare, but good stuff
    ALSO there are 6 1/2" x 16 hoops on some late 90's GM p/u's and vans that work perfect, only problem is the front face is stamped as one piece with the rim, so they take a bit of work grinding them to look right. Otherwise they are perfect size hoops, just drop your center in place
  3. 39 Deluxe
    39 Deluxe
    and the spare in the trunk...
  4. Marty Strode
    Marty Strode
    The original 5" wheels have a different looking center than the narrow ones, IMG_3044_1.JPG
  5. '52 F-3
    '52 F-3
    from Central PA
    Ford F250/350 16" 8 lug wheels......
  6. 38 coupe
    38 coupe
    from Texas
    I have a set of the wider (5 1/2 I think) wheels from a 41 3/4 ton. The centers are different.
    Also rare are the factory 15 inch diameter wide five wheels. These were typically found on Marmon-Herrington 4 wheel drive conversions.
  7. 55willys
    55willys
    Hey guys thanks for the tech on shrinking and widening. Jim Ford
  8. 55willys
    55willys
    Here are pics of what I think are early 36 spoked wide five wheels, does anyone know for sure what these are?
    Jim Ford IMG_20141226_180109654.jpg IMG_20141226_180109654.jpg IMG_20141226_180115308.jpg IMG_20141226_180125225.jpg
  9. JOECOOL
    JOECOOL
    A couple of years ago I made these for my RPU. I used 2001 Chev. truck spare tire rims. ( they are 16 inch) Hopefully I can get the pics to come up.I had a friend cut the centers out of the pickup wheels with a lathe,reversed the rim for looks, don't forget to redrill a new valve stem if you reverse.The centers fit in perfect,
  10. 55willys
    55willys
    That is nice to know that they fit right because a lot of 16 rims are too small. How wide are they?
    Jim Ford
  11. gimpyshotrods
    gimpyshotrods
  12. 55willys
    55willys
    Thanks for the info gimpyshotrods. Were there also special wheels for these and what was the purpose? Extra cooling? Jim Ford
  13. gimpyshotrods
    gimpyshotrods
    The wheels were the same. The drum design was for weight and cooling.
    They are more commonly seen in the 5-on-5-1/2" pattern.
  14. King ford
    King ford
    from 08302
    Happy new year 55 Willys and all hambers ...that is a nice looking piece your making there Willys ...but since your using the hamb to sell your parts don't you think you aught to join the alliance?.....
  15. 26 roadster
    26 roadster
    my jaguar wheels had a 13.25 center and I found ford and chevy truck wheels were workable
    5x5 wheels and 5x5.5. I have no exact measurements but they pressed on nicely
  16. 55willys
    55willys
    Do you know if they were ever available to fit 37-39 or just 36?
  17. gimpyshotrods
    gimpyshotrods
    I've only ever seen '36 ones.
    There may have been later ones, but I don't know.
  18. bondolero
    bondolero
    Any source for later ford caps like the ones pictured on the roadster for these wheels other than the 36 caps from Vintique / drake ?
  19. Weird A
    Weird A
    ^ those caps on the coupe are rare as hens teeth! Another option is the Lincon Zepher caps.
    Bill
  20. 55willys
    55willys
    I was waiting for the new year to do that and it is done and when I get my website set up I will be an alliance vendor also. Jim Ford
  21. RainierHooker
    RainierHooker
    from Tacoma, WA
    Bringing this to the top with pics...
    55willys likes this.
    55willys, Tim_with_a_T and treb11 like this.
  23. bigheadbaxter
    bigheadbaxter
    Here's a pair I picked up for 20 bucks. So did these wheels also come on trucks? The ones I have on my car are stamped 1937. These tires are huge, maybe they were on a trailer? ImageUploadedByH.A.M.B.1467247744.539979.jpg
  24. 55willys
    55willys
    Those are car rims, truck rims are wider and have a different center that has 5 small slots as opposed to the artillery style center.
  25. bigheadbaxter
    bigheadbaxter
    55willys what were the difference in withs for? I took the tires off today and noticed the difference, there's a half inch. Thought maybe the narrow ones are for the front or on different cars? I noticed this before on my car, I bought 5 and one was narrower, I used the wider 4
  26. bobbytnm
    bobbytnm
    Great thread
    I'll be running wide 5's on my 26 RPU. I'll see if I have any pics
  27. boo
    boo
    from stuart,fl.
    i have wides on my rdst pu, one of my fronts is 3 1/2'' wide off aV8-60 car, the other is 4'', widened rears to 5 1/2''. truck rims are 5 1/2'' but different looking inners.
  28. 55willys
    55willys
    What he said^^^^^
  29. RainierHooker
    RainierHooker
    from Tacoma, WA
    Yep, just to reiterate the original sizes available from Ford:
    16x3.5" - V8-60 (Ford Standard) P***enger Car
    16x4" - V8-85 (Ford Deluxe and optional Standard) P***enger Cars and 1/2 Ton Pickup
    16x5" - Optional on 1/2 Ton Pickups, Standard on 3/4 ton and larger Trucks
    18x4" - Optional "High-Clearence" Wheel on Trucks
  30. RainierHooker
    RainierHooker
    from Tacoma, WA
    PS: If anyone has a pair of the 16x5" truck wheels that are collecting dust, I'm looking for a pair...
