Technical what year 8 3/4?
Discussion in 'The Hokey Ass Message Board' started by speedo1, Jan 8, 2015.
  1. speedo1
    speedo1
    I am confused as to what year rear end I have. I am Not sure what vehicle it came out of. Every chart I have looked at is not helping, here are my measurements: inside flange to flange, 55 3/8". Perch-perch center, 46". Axles, 30 3/8", open diff., 742 case. Every measurement gives me a different year and body. my measurements were taken with my trusty tape measure :). Any help?
  2. DRD57
    DRD57
    With a 742 case, if it has tapered axles, it's 64 or earlier.
  3. Texas Webb
    Texas Webb
    Are you asking about Mopar?I found a chart some months ago.Try google.
  4. Dads426
    Dads426
    from Olney, MD
  5. speedo1
    speedo1
  6. speedo1
    speedo1
    I've read every damn table , that's why I'm confused.
  7. Frankie47
    Frankie47
    from omaha ne.
    Proffessionally narrowed?
  8. speedo1
    speedo1
    No.
  9. speedo1
    speedo1
    I thought, based on housing width, maybe 64 b-body. However, axle length isn't right.
  10. partsdawg
    partsdawg
    from Minnesota
    Castle nuts on the end of the axles?
  11. stillrunners
    stillrunners
    from dallas
    what partsdawg said......and 8 3/4 mopar rear ends go back into the 50's....my 56 currently out of my Fury...... fury 1.JPG
  12. bigjoeb
    bigjoeb
    sounds like it could be a 67 to 69 imperial
  13. speedo1
    speedo1
    No.
  14. speedo1
    speedo1
    I'm only really concerned because of brake hardware. They are 11x 2 1/2, however, while some hardware, wheel cyl., etc., crosses years and body type, some don't. FYI, this rear will be going under a 52 Plymouth.
  15. 50dodge4x4
    50dodge4x4
    If your measuring over top of the "hump" with your tape measure, your measurement could be askew. Axle length and center case # are the only 2 things your sure of, and nothing says the center is original to the housing. Axle length adds up to over 60", so that will pretty much eliminate anything older then 70, and 74 was suppose to have been the last year for the 8 3/4. Given the measurements of the axle length, and the spring perch center to center, your looking at a 70-74 E body, with a different center section. I think I would be getting 11x 2 1/2" brakes parts for an e body if the brake shoe size is an option. Usually the choice in brakes for Mopar was 9" or 10" or 11". I suspect most 11" brake stuff between 70 and 74 will interchange. Gene
