Hot Rods Let's see your homemade speed equipment
Discussion in 'The Hokey Ass Message Board' started by Robert J. Palmer, Nov 26, 2014.
  1. King ford
    King ford
    from 08302
    Hey Flathead John dose pacific jackrabbits ever paint anything in bright colors?
  2. sik6spd
    sik6spd
    Pacific Jackrabbit's mama is the Easter Bunny!!!
  3. This thread kind of died. I would like to see more!!
    patmanta likes this.
  4. I finally figured out how to resize pictures!!
    Here's what I've built
    -Homemade fuel log
    -Split stovebolt exhaust
    IMG_0486 (Small).JPG IMG_0487 (Small).JPG IMG_0489 (Small).JPG IMG_0491 (Small).JPG IMG_0488 (Small).JPG
    ekimneirbo and tinsled like this.
  5. loudpedal
    loudpedal
    from SLC Utah
    Twin Wico Mag Drive:
    Friction Shocks:
    Bellhousing to mount a Jeep T5 to a Flathead. Also a T5 to torque tube adapter:
    Water-heated Intake:
    Lil'Alb, Deuces, BigRRR and 14 others like this.
  6. oldnuts
    oldnuts
    from nebraska
    Loudpedal. Your work is amazing.
    LongLiveFlathead6 likes this.
    This is a Gotha kit to make a stock 6 cly. Chevrolet intake into a 2 x 1 bbl (N.O.S)
  8. N.O.S. Douglas header flange for blueflame Chevrolet 6 IMG_0500 (Small).JPG IMG_0501 (Small).JPG IMG_0493 (Small).JPG IMG_0498 (Small).JPG
  9. -3 spd shifter in a vintage stock car
    -Left handle 1st rev.
    Lil'Alb likes this.
  10. Inline Buick 8 intake/header I saw at the Return to the milltown show GEDC0652 (Small).JPG
    A 3 carb set up for a flat head six I made. Never finished. I found out The running when parked motor was completely destroyed. So now it's a wall hanger.
  12. raprap
    raprap
    from Ohio
    Bare Intake Side.jpg IntakeCarbs Closeup.jpg IntakeCarbs Front.jpg IntakeCarbs Side 1.jpg th_FinalManifold3.jpg Several years ago, I wanted a unique vintage looking intake for my 292 inline 6. I already had the Offy 3x1 with adapters for a true 3x2 with Holley/Webers on it. It drives really nice.
    So I took an intake gasket, measured it 3 times, and started modeling a new intake on the computer. Sounds a little odd modeling a vintage type intake on the computer. I wanted it to look "home made" so all of the panels for the intake were individuals and tig welded together. I could have had some of the parts bent to reduce some of the welding but I did not go that route. I purchased 7 to mke 5- 84 Strombergs and some cool ram tubes off Ebay.
    After checking for hood clearance (dumb *** me) I would have to cut an opening in my cherry hood or get an extra one. After purchasing a spare hood, one of buddies came over after hearing what I was attempting to do. He talked me out of it and bought the 5 carb intake off of me for his racing altered.
    Bare Intake Side.jpg IntakeCarbs Closeup.jpg IntakeCarbs Front.jpg IntakeCarbs Side 1.jpg th_FinalManifold3.jpg Bare Intake Side.jpg IntakeCarbs Closeup.jpg IntakeCarbs Front.jpg IntakeCarbs Side 1.jpg th_FinalManifold3.jpg
    brEad, Deuces, jaxx and 7 others like this.
  13. saltflats
    saltflats
    from Missouri
    Dang thats pretty slick. Looks like you could have or are working for Hogan.
  14. raprap
    raprap
    from Ohio
    saltflats,
    Thanks but I do not know who Hogan is. It was a work of love and the welding turned out really too nice to grind down. If one wanted to, they could block of two carbs and run three only for the street.
    rdscotty likes this.
  15. saltflats
    saltflats
    from Missouri
    Hogan is the ones that make those sheet metal intakes for lots of race teams.
    Beautiful work man. When I grow up I would like to weld like that.
  16. raprap
    raprap
    from Ohio
    Thanks saltflats. I, as usual, made it to last. All T-6 Aluminum and 3/16" thick. The carb plates & mounting flanges were .25".
    I thought it was a bit overkill but it won't warp!
  17. Wow! raprap you do beautiful work!
  18. dana barlow
    dana barlow
    from Miami Fla.
    There times that I really think homemade is much ***er then store stuff ,if it is done fairly nicely,some even works better then high$ stuff,yet manytimes the hr.s put in are a lot.
    Over these last 57+ years of work I've made many sets headers and some intakes as well. I started a fun little project a few months ago,building a log 4x2 intake for my Y-block Ford again ,it's still just a have fun n something to use 4 of my 94's on. I'll post a pick of so far up this week. No head flanges yet,so after I do those,we'll weld the carb flanges on for best line up,just setting inplace for now and a few parts of the start of home made linkage. I've done a few log intakes over the years. For Ford "Y"s a homemade log can be better then many of the aftermarket big name intakes;Those are made with no divider between intake ports of head. That is bad,as the two front cly of right bank fire next to each other. So I make a divider for the runners from head up to log,plus 1/2 inch into log.
    BigRRR, j-jock, y'sguy and 2 others like this.
  19. Very nice Dana.
    When I built my Chev. split exhaust lots of the guys at work asked "why I didn't just buy a header?"
    When I said "Because it was fun!" They didn't see how work could be fun!
    dana barlow likes this.
  20. More vintage stock car parts 3/4 ton 8 lug to wide 5 IMG_0531 (Small).JPG IMG_0533 (Small).JPG IMG_0535 (Small).JPG IMG_0533 (Small).JPG IMG_0536 (Small).JPG
    brEad, dana barlow and j-jock like this.
  21. This on is more homemade than the rest
  22. 28dreyer
    28dreyer
    from Minnesota
    This may be the pushing the envelope a bit but "home made in the shop" for a 261 Chevy in 1960 (by the resurrector and fabricator of my avatar).
    Not run for 51 years. Presently being rebuilt by him. Cast iron head casting, fabricated cams, cam boxes, manifolds.
    Six Ball, brEad, ekimneirbo and 16 others like this.
  23. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    28dreyer
    Oh, my!
  24. Jet96
    Jet96
    from WY
    Holy cow, that's Cool !
  25. topfuel55
    topfuel55
    from Hebron IN
    ImageUploadedByH.A.M.B.1421551044.260967.jpg ImageUploadedByH.A.M.B.1421551075.979042.jpg
    After the dual cam 261 above, this is almost embarr***ing, but.....
    Here is my four- twos intake. Intake base is a TBI intake, I milled the top plane off welded a plate on top then made carb risers. The linkage is all home built. Saving money to buy carb kits, then to figure where to start with jetting. It's not a isolated runner intake so I just can't jet like a Man-A-Fre set up. If anybody has an idea where to start hit me up.
  26. Jethro
    Jethro
    Hand made DOHC head......WINNER!......totally awesome!
  27. Panel Pete
    Panel Pete
    Not trying to threadjack but WOW loudpedal, that bell housing and torque tube adapter are amazing!!!Are these pieces available to the public for sale? If so I'm readily interested as I have a jeep T5 set aside planed for my next project.
  28. BigDTexasKid likes this.
  29. Hey it's still cool!
    topfuel55 likes this.
  30. topfuel55
    topfuel55
    from Hebron IN
    Thanks bud, I've been working here and there for ever. I made my own extended throttle shafts. And all the linkage. Carb kits next. Hopefully this summer it will make smoke!
    Robert J. Palmer likes this.
