Lowering a 50 Chevy
Discussion in 'Traditional Customs' started by Andrewcooke, Jan 4, 2015.
  1. Andrewcooke
    Andrewcooke
    Hi guys ,long time since I been on here , I have a question about rear lowering blocks on my 50 Chevy .I have fatman dropped spinnels on the front , looking at 3 inch blocks on the rear , is this too much as I am still running the standard rear and powerglide ******. Looking a nice ride and with our roads here in Ireland and speed bumps not too low! Thanks for any help.
    Would like to have a slight drop to the rear. ImageUploadedByH.A.M.B.1420387144.846930.jpg
  2. dan31
    dan31
    That should work.
  3. bigdaddy13
    bigdaddy13
    My avatar is my '51 with a 2" block in the rear and dropped uprights up front.
  4. Hellfish
    Hellfish
    We used a 3" blocks on my wife's '51 and cut coils in the front. 53/54 3-speed trans & torque tube rear end. Worked fine.
    JennSeay32 and flyin-t like this.
  5. 48 Ragtop
    48 Ragtop
    Go For It Should work out fine.
  6. butcherted
    butcherted
    from hagerstown
    When I first lowered mine I cut the front coils and 3" blocks in the rear.
  7. kennyg1931
    kennyg1931
    my 54 has 2 inch lowering springs and 2 inch blocks in the rear , nice ride !
  8. kennyg1931
    kennyg1931
    my 54 has 2 inch lowering springs and 2 inch blocks in the rear ! it rides good .
  9. Gleid
    Gleid
    from Norway
    How many turns did you guys cut the coils? I'm looking for similar drop as Mr. Hellfish here.
  10. cosmic12
    cosmic12
    Stock coils in frt but 2" A-arm drop with 2" spindles and 4" blocks in rear with reverse leafs.
  11. Hellfish
    Hellfish
    If you have dropped spindles, the amount of spring cut is irrelevant. My wife's car kept the stock spindles and we cut 1-1.5 coils off (I forget).
  12. Gleid
    Gleid
    from Norway
    Thanks, I know that dropped spindles would rend the cutting somewhat irrelevant, but cutting the coils is all I can afford at the moment :-(
  13. dan31
    dan31
    I would cut 1 coil off and try it, remember if your coils are old they probably lost a little height already. You can always cut another 1/2 coil off if needed. It's in pain in the *** to do it twice but it's the best way.
    Gleid likes this.
  14. King Karl
    King Karl
    from N.C.
    The car itself will not be too low. You'll just need to watch your clearance on the exhaust. On my 50 it gets pinched between the rear end and the trunk floor when going over heavy bumps. Rides great otherwise. I plan to reroute the exhaust soon but could live with it if need be.
  15. JennSeay32
    JennSeay32
    Mine is 2 coils cut in the front and 3 inch lowering blocks in the rear. Mine rides fine except when I have more than 3 people in the car. Hellfish I LOVE your car!
  16. JennSeay32
    JennSeay32
    Ps-I'm planning on putting air shocks in the rear to fix that problem.
  17. Gleid
    Gleid
    from Norway
    Thanks for the tips guys. I've just put on a fresh pair of coils as the old ones was cut way to much. I live in Norway and they are very fond of crazy *** speed bumps over here. So I couldn't drive it while it was that low. I'll go for 1-2 turns.
