Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. gimpyshotrods
    gimpyshotrods
    Nope. No reason to.
  2. loudbang
    Hey not fair you have been calling yourself a burntoutold mechanic........... But it looks like you are also a burntout ELECTRICAL GOD in reality. :rolleyes:
    But really nice work from a mere mechanic. (we know that mechanics can do ANYTHING.)
    BurntOutOldMechanic likes this.
  3. Evilfalcon1961
    Evilfalcon1961
    from Ma
    Sanderson headers in my 63.. trans is not attached just testing they are close !
  4. Evilfalcon1961
    Evilfalcon1961
    from Ma
    Driverside
  5. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Hard to see in the pic, but I suppose it clears the steering box okay?
    Ordered my 289-302 based/AOD set last week.
  6. Evilfalcon1961
    Evilfalcon1961
    from Ma
    Yes clears it just fine , don't knoW if the steering box for the six is smaller but you should be very pleased
  7. cage66
    cage66
    from reno
    Been a while. I finally put on my tru-spokes that I got from Got louvers they look great but they are wider than the stocks and I am having a hard time figuring out my options.
    I can fix the front as I am planning on narrowing my control arms. But the rear is giving me problems. I am running 3" blocks and 195/75 14s
    I just clear the lips on the fender wells but there is an inner tub I am rubbing on. I noticed the drums have 3 raised bumps that where hitting the mounting plate so I ground those down and gained maybe 1/4" I can't use a smaller spacer because the drum will just hit the mounting plate on the wheel.
    I could try smaller tires but I am afraid the hearing may be off if I do.
    I have a 170 with a 2 speed auto. What size tires would work best? It originally had 13s
  8. cage66
    cage66
    from reno
    ImageUploadedByH.A.M.B.1420853935.620512.jpg ImageUploadedByH.A.M.B.1420854053.104646.jpg
  9. cage66
    cage66
    from reno
    Does scarebird sell a 4 lug disc swap for the rear also?
  10. gimpyshotrods
    gimpyshotrods
    No. You don't need discs in the rear.
  11. cage66
    cage66
    from reno
    Okay, I was just seeing if there was a kit. Does anyone have any info on what tires may help me out or any other suggestions on getting more clearance for my tires with the set up? Thank you
  12. gimpyshotrods
    gimpyshotrods
    You may have to build mini-tub outers.
    That's what I need to do.
  13. cage66
    cage66
    from reno
    Thank you I was thinking that may be the best fix. I already need to make the spare tire holder and fix the rusty wheelwells might as well do it all at one time. It would be nice to build tubs for something other than VW buses. Here's what I do on the side. ImageUploadedByH.A.M.B.1420862577.326914.jpg
  14. cage66
    cage66
    from reno
    Sorry about the non falcon content.
  15. gimpyshotrods
    gimpyshotrods
  16. cage66
    cage66
    from reno
    Thank you, still learning.
  17. gimpyshotrods
    gimpyshotrods
    We all are. Every day is a school day.
  18. cage66
    cage66
    from reno
    Oh and I did end up making 2" drop spindles. Still haven't tested them on the car. I may need to modify them but I will know better once I start the disc swap. ImageUploadedByH.A.M.B.1420874810.313480.jpg
  19. gimpyshotrods
    gimpyshotrods
    Did you have those Magnafluxed?
  20. cage66
    cage66
    from reno
    Yes, I had them tested for stress cracks and porosity. I work in a structural shop so I used our bad*** dual shield welder that we use to weld 3/4 steel no problem. And after welding I tossed them in kitty litter for 4 hours to cool slowly.
    The welds aren't cosmetic but strong as hell, I also added more material than I took away. They are defiantly over engineered. I wouldn't offer them for sale just because liability is scary but I am 100% confident that my family is safe in the car.
  21. gimpyshotrods
    gimpyshotrods
    That's the ticket!
  22. mcnally351
    mcnally351
    from boston
    very cool good job on those!
  23. cage66
    cage66
    from reno
    Thanks guys.
  24. cage66
    cage66
    from reno
    Well as much as it saddens me to say it. I just put my 1961 falcon wagon on eBay, if anyone knows anyone looking please let them know. ImageUploadedByH.A.M.B.1421781469.736091.jpg
  25. gimpyshotrods
    gimpyshotrods
  26. cage66
    cage66
    from reno
    It's for the best. I bought a 59 VW doublecab. And have to pick which one stays. For me it was an easy choice.
  27. gimpyshotrods
    gimpyshotrods
  28. cage66
    cage66
    from reno
    Falcon is on its way to Japan. I need some help on something else.
    I bought these from someone on here hoping that I could make them work for the falcon. Maybe someone can help me figure out what they're for. I would need to modify them a LOT to make them work for the wagon.
    ImageUploadedByH.A.M.B.1422235727.647610.jpg ImageUploadedByH.A.M.B.1422235780.154717.jpg ImageUploadedByH.A.M.B.1422235807.038834.jpg ImageUploadedByH.A.M.B.1422235836.528224.jpg
    In the 2nd to last picture you can see how much would need to be trimmed to work for the wagon.
    I ***ume they are fox craft the last pic is the stamping on the lip. ImageUploadedByH.A.M.B.1422238561.010363.jpg
  29. cage66
    cage66
    from reno
  30. cage66
    cage66
    from reno
    The falcon is on its way to a custom chopper shop in Yokohama Japan. I maybe able to see it again in a few months as I will be there for vacation. Thanks everyone for your help.
