Hot Rods Did Oldsmobile Make a Short Water Pump for the Early Rockets?
Discussion in 'The Hokey Ass Message Board' started by Rusk, Jan 10, 2015.
  1. I have a '54 324 in my '36 Ford that's too close to the radiator to run the stock water pump and fan. An article from a 1956 Car Craft states that they used a '51 Olds water pump to gain enough room to wedge the stock setup in a '40 Ford, but all the pumps I've seen for sale (Kanter, etc.) list the same part number for '49-62.
    Does anyone know if there's a short water pump that will work? Anyone modified one?
    Thanks
  2. vtwhead
    vtwhead
    I am not aware of any OE pump that would be shorter. I might suggest that you contact Tony (Goatroper2) on here as he is always working on Olds engines and has many answers often.
  3. Paul
    Paul
    Editor
    I had a thought..
    lose the rear pulley on the pump and press the flange further onto the shaft
    went out to the pile 'o-motors to see..
    but there is not enough room behind the flange to push it back far enough..
    need about 3/4" to get belt alignment
    but there is only about 1/2" gap behind the flange.
    only very minor differences in pump bodies through the years
    and all appear to be same dimensionally.
  4. Thanks for the responses.
    Hmm....Paul, you got me thinking. I figured I'd have to section or machine a new shaft, but it would be easier if I could just press the flange closer to the pump. I figured I'd have to modify the pulley anyway.
  5. Paul
    Paul
    Editor
    potentially a lot of work for only a fraction of an inch
  6. dan griffin
    dan griffin
    Pumps are the same 49-62.
  7. Frank the Crank
    Frank the Crank
    from So Cal
    I had a '52 Super 88 and when I replaced the leaking original pump I had a similar problem. I ended up pressing the mounting flange back as far as it could safely go to get the pulleys to line up. The belts were still a little off but it worked great. The only difference that I noticed between the original water pump and the replacement was that the original had a retaining clip in front of the shaft bearing /seal and the replacement was strictly a press-in. The overall shaft length was the same but the casting was a little shorter on the original. (due to the retaining clip)
