Throttle rod boot
Discussion in 'The Hokey Ass Message Board' started by Dennis D, Oct 6, 2010.
  1. Dennis D
    Dennis D
    Due to the location of the Moon gas pedal in my '32 that I am building I am going to have the rod for the carb to pedal linkage running through the firewall. I have been looking for a "boot" to seal the hole where it will come through. I'm guessing at this time about a one inch hole for a 1/4" dia. rod should be enough for the rod not to bind on the firewall. Any ideas where a person could look for something like this? Kinda new at this old car thing and I don't remember a car that the throttle rod was installed like this. If the pedal could set off to the left of the trans tunnel I could run linkage off of a 60's car, but there is no room. Thanks again for any help. Dennis D
  2. How about a boot from a old style master cylinder?
  3. Dennis D
    Dennis D
    That's an idea. Wonder about finding one with a small enough hole to seal the rod. Dennis
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I have what sounds like a simular set up for my linkage ..i was also looking at the master cyl. boot..
  5. Blue One
    Blue One
    from Alberta
    The boot from the master cylinder as mentioned above is what I am going to use.
    The hole is 3/8" diameter, which is perfect for a 1/4" rod.
    You don't want to "grab" the rod with the boot and interfere with the action of the throttle.
    I have one off a 72 Maverick donor car I parted out.
    It has the larger end and a 3 stage step down bellows style going from the larger to the smaller size. Has a nice lip that makes it stay in a properly sized hole in the firewall nicely too.
    I have a buddy who uses one on his 27 roadster.
    A small sleeve of vac*** hose over the 1/4" rod makes it almost seal perfectly yet still move.
    Just make sure you have a good return spring so it doesn't hang up.
    Any Ford from the 70's should have one, you won't get one from the parts store ,they used a rubber cap with a hole now if you buy a replacement master cylinder.
    You have to go the wrecking yard route, which is OK as the one I took off the Maverick was in brand new condition from being buried inside and under the dash away from sun and weather.
  6. Bitman
    Bitman
    from Eureka, CA
  7. Kerrynzl
    Kerrynzl
    try a boot from a Jap diesel pump [eg mitsubishi montero ], they look like a "mini motorcycle fork boot"
  8. BJR
    BJR
    54-55 Buicks used one, find one at a Buick repo parts dealer.
  9. 51farmtruck
    51farmtruck
    HI: Look at drag race supply co. like Jerry Bickell or Quartermaster,they sell them in different sizes. CHRIS
  10. 57tailgater
    57tailgater
    from Georgia
    Good topic! Been working putting a Moon pedal in my truck hooked up to a stock linkage that has a rod going thru the firewall. The stock set-up had a felt seal around the rod that needed to go. I was wondering what to use and found this thread - this will work great! This site is awesome! :cool:
  11. nunattax
    nunattax
  12. HOTRODPRIMER
    HOTRODPRIMER
    NAPA usually has all different sizes available. HRP
  13. Jakesrocks
    Jakesrocks
    Military aircraft surplus dealers. Small boots were used around lots of control rods & cables. I may even have a small boot out in my storage shed that would work. When I was a kid building my first rod, I practically lived in salvage yards.
  14. mustangsix
    mustangsix
    If you're looking for a small bellows or accordian boot try a bicycle or motorcycle. They usually have those on cable ends to seal them up. The bike ones are pretty small, but the motorcycle ones might be the right size.
  15. BJR
    BJR
    47-71 Jeep uses a boot like you need.
  16. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Product Summary
    Product Name Accelerator Rod Boot Bellow, 1949-54 requires slight modification for hole in floor
    Details: RUBBER/WEATHER STRIPPING, INTERIOR RUBBER PARTS, GEARSHIFT & ACCELERATOR KNOBS/BOOTS & BELLOWS
    SKU: C519357R
    Price: $14.38
    Year: 1949-1957
    www.pontiacparts.net
