Technical 4 speed shifter on 3 speed trans ??
Discussion in 'The Hokey Ass Message Board' started by Scott, Jan 14, 2015.
  1. Scott
    Scott
    I have a good Saginaw 3 speed and a good Hurst compe***ion plus shifter with the correct mount. I don't see why this couldn't be done. Has anyone done this before? I may go to a 4 speed in the future.
  2. yes, you will have no need for the reverse rod
    Scott likes this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Bingo! HRP
  4. Scott
    Scott
    Good enough for me fellas :)
  5. Move the reverse lever to one end and tie it off so you don't accidentally get into the wrong position at an inopportune time.
  6. Scott
    Scott
    got it,(I was wondering about that)
  7. Commish
    Commish
    from NW Ok
    I ran the same combo for several yrs. and never tied anything off. Never had a problem. I don't guess it would hurt anything, but don't think it is necessary.
  8. Scott
    Scott
    Works great!
  9. bobss396
    bobss396
    I saw 4-speed shifters used on stock car 3-speeds quite often.
  10. Uncle got a good deal on a car that had a "bad" transmission once. Turned out it had a four speed shifter and knob on a 3 speed. Seller kept trying to shift according to the pattern on the knob and it would be of course reverse instead of 1st.
    Texas Webb likes this.
  11. 56sedandelivery
    56sedandelivery
    I've seen 3 speed shifters used on 4 speeds in drag cars years ago; it makes missing 2 gear less likely as the levers ARE moved through the reverse "notch". A separate lever has to be fabbed up for reverse, and you want to be careful not to have it in first and reverse at the same time (BOOM!). Just the opposite of what you're using/setting up. No reason it should't work; maybe you could even make the reverse lever part of the starting circuit with a switch, that could also serve as an anti-theft device if a 3 speed shift knob/ball is used to confuse a thief. I am Butch/56sedandelivery.
  12. BamaMav
    BamaMav
    from Berry, AL
    Saw one like that myself on a 64 Chevy one time. They used a cut off lug wrench for the reverse lever. Looked goofy, but it worked.
