Technical Transmission can someone explain
Discussion in 'The Hokey Ass Message Board' started by bigtumtum, Jan 16, 2015.
  1. bigtumtum
    bigtumtum
    i have a transmission its a 4l60e
    Now its also a number on it 37
    Can anyone explain what that means?
  2. bigtumtum
    bigtumtum
    Maybe this picture is better
  3. Abomination
    Abomination
    I have also seen this mysterious "37" on the side of some 4L60E transmissions. Does anybody know what this means?
    The speedometer gear has 37 teeth, but I sincerely doubt that's it. :/
    Any help solving this mystery is greatly appreciated!
    ~Jason
  4. 50dodge4x4
    50dodge4x4
    Since its cast into the housing, I suspect it may be a, casting number, mold number or core number, as in "Grab the mold for casting 37 and run another batch." I worked at a foundry that cast transmission cases for tractors for a short time. There were 4 or 5 different transmission cases they poured, and each case had a reference number ***igned to it. It would not have surprised me if the reference number was cast into the part.
    I would think if the number was concerning something inside the case, it would have been stamped numbers on a machined pad. Gene
  5. stimpy
    stimpy
    dodge is probably right as , they make several versions of this trans or it can be a mould Id as moulds wear out or get damaged or its a revision and a quality control issue would arrise and and it make it easier to id the mold that has the problems ..
  6. gimpyshotrods
    gimpyshotrods
    Which computer are you going to use to run that?
    I have had good luck with the TCI ones.
  7. bigtumtum
    bigtumtum
    Thanks for the answers. .
    The ****** will be a backup for my 1997 chevy tahoe.. but because there was a different casting number i believe 52 i wasn't 100% sure it would fit..
  8. There should be a tag number on the trans itself. You might go over to chevytalk.org and go to the 88-98 truck section and make a post. There's a lot of one year only goofy stuff on the 95-00 trucks. For instance I learned the hard way that 95 4L60E trucks have a one year only transmission and one year only computer. But that's the last OBD-I year.
  9. bigtumtum
    bigtumtum
    Thanks newyorker.
