Hot Rods 1949/50 Plymouth windshield question
Discussion in 'The Hokey Ass Message Board' started by tailpipe47, Jan 14, 2015.
  1. tailpipe47
    tailpipe47
    Does anyone know if a windshield from a 49/50 Dodge will fit a 49/50 Plymouth. They look the same,but don't want to spend the moneys until I know.
  2. Rusty O'Toole
    Rusty O'Toole
    If you need a windshield any auto gl*** shop can make one and they are not very expensive. The gl*** is flat, they only need to cut it to size.
    To answer your question there were different models of Dodge and Plymouth and some used the same windshield.
    It is recommended to use new gl*** if possible. No matter how good it looks old gl*** is always more or less pitted and scratched. It may look ok but wait till you are driving into the sun.
  3. bct
    bct
    I redid both sides of my 51 this summer . $40 per side. cut and arrised
  4. Rusty O'Toole
    Rusty O'Toole
    If cost is an issue, you can cut laminated gl*** if you know how. The technique involves cutting each side then cutting the plastic in the middle with a razor blade or pouring alcohol into the seam and lighting it on fire to melt the plastic.
    We used to buy school bus windshields in the junk yards because they were the biggest. Then cut them down to fit our cars.
  5. tailpipe47
    tailpipe47
    Thanks guys. You got me covered and I give you many thanks.
  6. CRZNDUCK
    CRZNDUCK
    Some gl*** shops have the old style laminated gl*** with the tinted stip along the top. I opted for this when I did my 49 and if I recall correctly did a 5" tint.
