Hot Rods Need help with electric wipers for a 39 Ford Deluxe sedan.
Discussion in 'The Hokey Ass Message Board' started by genosslk, Jan 16, 2015.
  1. genosslk
    genosslk
    What is the trick setup for wipers for a 39 Ford Deluxe Sedan with the original tilt out windshield? I tried Newport Engineering's setup but didn't like how it fit... bulky and it would make the windshield header look terrible. I have all the original vacuum stuff and tried to get the vacuum motor to work but couldn't. Not sure my engine makes enough vacuum anyway. I looked at Specialty wipers for their setup but not sure if the cable will clear the stock windshield hinges.
    So far...Rain X is the winner.....
    Thanks guys!
  2. bchra guy
    bchra guy
    Just got my 39 on the road and used Newport's cowl mount kit for 39 open cars......electric setup incl a delay wiper feature......talked with several 39 owners before making wiper mount change and their comments were "don't try to run with the hinged windshield setup" as they all ended up permanently installing and taking out hinged feature, due to wind noises and water coming in.....seems 39's with hinged windshields were never designed to run down the hwy at modern speeds ......late decision to change wiper setup was after paint work done, so simply made 2 stainless ****on head "plugs" and bolted in stock wiper locations, with body color paint which "fade into the background"......installation was simple and wipers work great......
  3. genosslk
    genosslk
    I'd like to keep my stock tilt out windshield as it fits perfectly... doesn't leak and no wind noise. I found a guy that make new crank gears that work great and helps keep the windshield closed tight. I went through three rubber seals until I got one that works. I'm pretty sure that none of the stock wipers were designed to work above 30 mph! I ran the Newport wipers in a rain storm and at 50 mph they were nothing more than a smear on the window. Out came the Rain X.....
  4. fordor41
    fordor41
    Try lubing the vac motor or replacing. I use a small vac pump to run mine on my '41
  5. I have used the Specialty Power wiper unit in a 36 Ford truck, a 38 Coupe and a 39 sedan. I installed them in stock holes on both the 38 and 39. I drilled the p***enger side hole on the 36 where it should have been if it had been there. All 3 still had stock roll out windshield and no issues. On all 3 of these cars I mounted the motor on the p***enger side behind the kick panel. To date no issues, they work just fine. Also the 51 in my avitar, I have there unit in the stock wiper bezel and there switch mounted in the stock dash hole with the stock 51 knob. I have also installed 5 other of there units with good operation in all cars. I'm currently doing one in a 34 Chevy Standard Sedan with there br*** bezels that are a hand fit to your car. I'm mounting this one on the cowel instead of overhead. It's a good all around unit and they stand behind there product.
    The Wizzard
  6. genosslk
    genosslk
    Fordor41.... what vacuum pump did you use? I'm interested in how you set yours up. I'm sending my vacuum motor to Ficken's wiper rebuilders for a freshen up. He guarantees the wipers to run on 13 inches of vacuum and are fully tested before they are sent back to the customer.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Don't they make a cable driven windshield wiper motor? HRP
  8. OLDSMAN
    OLDSMAN
    Years ago on my 39 Deluxe coupe, I used a motor from a volkswagen beetle in that cat. I had to build brackets and modify the linkage, but the wipers always worked great.
  9. rfraze
    rfraze
    I found a vacuum collector under the hood of an 80s? VW (maybe cabriolet) that has worked for me on a couple of applications. It is square and looks like 2 plastic egg cartons face to face. 2 hose ******s are cast in and it "collects" vacuum in these chambers. You will probably have to find some place to hide it, but they "worked" for an auto manufacturer and for me.
  10. olscrounger
    olscrounger
    Just had one done by Ficken for a 4o std-excellent-engine pulls 18" of vacuum==works very well thus far--have done it before and added a little vac reservoir for a ford of some type--looks kinda like a little hand grenade
  11. fordor41
    fordor41
    I bought mine off ebay. believe is off a Toyota 4 runner. A lot of newer cars cars use vac pumps. Do some searching on the internet then try a junk yard.
  12. X38
    X38
    That's what Speciaty is. Basically a copy of what lots of English cars had. And they know about rain.;)
  13. ems customer service
  14. studebaker46
    studebaker46
    actually a lucas motor from british-Leyland cars are what the spec wipers are patterned after only betterbuilt. lookon e-bay mg triumph jaguar land rover etc
  15. genosslk
    genosslk
    I wish I had that kind of room in my header panel. My Newport wiper stuck out about 1 inch when installed. I made a header panel and it looked like **** from the bulge. I sent my vacuum wiper motor to Ficken Wipers in NY to se what they can do. Worth the $100 to see if it will work.
  16. spooler41
    spooler41
    Genosslk, You might try to contact ,Western Pacific Design, they are in
    Port Townsend ,Washington and do wiper conversions. Sorry I don't
    have a direct link.
    ................................. Jack
  17. genosslk
    genosslk
    wish I had read that before I sent them off yesterday! I'll put that in my roll-a-dex, Thanks!
