Projects 1962 Mercury Monterey Custom Wagon
Discussion in 'The Hokey Ass Message Board' started by FrozenMerc, Jan 18, 2015.
  1. FrozenMerc
    FrozenMerc
    Over the last 5 years, I have posted many pictures of my 1962 Mercury Monterey Custom Wagon build. But, I have gotten numerous requests to post a build thread and compile everything in one spot. So now is time to do one on the HAMB. I have had a realtime running build thread on the Suedes Car Club board since 2009, so if you want, check it out.
    http://www.suedescarclub.com/smf/index.php?topic=2952.0
    This project started back in 2007. After recovering from the shop fire in 2006, we were moved into a new home / shop and ready to start another project. My wife and I have always liked wagons, and we started searching for one that would work. This particular car was listed in the MSRA Linechaser for sale, and was only 60 miles from home. We went to look at it on a cold January Saturday in 2008. It was parked in a tree row, buried in snow up to the windows. I got the shovel out, and felt around the car the best I could. I could tell there was some rust issues, and the little old lady who owned it, made sure to tell me that it ran great when it was parked in 1975. Nice, but I ***ured her it would not run now. Anyways, the price was right and I promised her that I would return in the spring and pick it up. I figured for $800, I could always part it out if it was too rough and get my money back on the FE and big 9" rear if nothing else.
    I brought the car home in July of 2008 and got to work on tearing it down and seeing what was left to work with. The original plan was to build a nice driving mild custom that we could pack the family into and cruise across the country if we wanted.
    Teardown Begins
    kiwijeff likes this.
  2. FrozenMerc
    FrozenMerc
    By now it was starting to get quite obvious that rust was pretty extensive. The car had sunk into the dirt and the bottom 8" or so between the firewall and rear axle were heavily corroded and damaged. Not unusual for a Minnesota car. At that time, I had more time then money, so I figured I would give it a go to see if I could bring this thing back.
    I started with the ch***is. Please forgive me, but I did not take very many pics of this process. The plan was to repair the frame, build a triangulated 4 bar for the rear, and convert the front to rack-and-pinion power steering and disc brakes. I also repaired the center sections of the frame, and ground out and re-welded the center joining weld along the frames entire length as it was rusted, cracking and starting to seperate in many places.
    The rear 4-bar mocked up. I used the original spring and shock mounts to keep it simple, and fabricated my own bars using a universal bushing kit from Energy Suspension.
    Painted Frame
    Front suspension with rack and pinion.
    For you '62 Merc fans, you know about the Anti-Harsh front suspension that Mercury used on these cars. The lower control arm has a special set of inner bushings that allow it to move laterally as well as pivot to help absorb hard impacts. This is the one place where the ch***is differed from a Galaxie. Since these bushings are very expensive to replace, I decided to convert the car back to the much cheaper Galaxie setup.
    I made a set of weld-in plates that would support the Galaxie bushing.
    Completed Ch***is
  3. FrozenMerc
    FrozenMerc
    By this point, it was time to get motor tore down and off to the machine shop. The FE turned out to be a fairly generic 220 hp, 2 bbl 352. The plan was to convert it to 4 bbl, and build it up with an emphasis on low end torque. The wagon is a big heavy car, and I wanted the power down were I could use it. Also, there was talk of maybe using the car some day to pull a nice camper.
    Dennis Roy in Grand Forks, North Dakota started the engine work. Dennis was an old time Ford guy and had built more FE's in his life time then I could imagine. If you walked into his shop, he had a 410 FE on the stand in the doorway that you had to squeeze around just to get into the place.
    Cylinder #1 needed to be sleeved due to some rust that would not clean up at 0.030. Other then that, the block was in good shape.
    Unfortunately Dennis ended up having a m***ive stroke and p***ed away a few months later. My engine was now stuck in legal limbo as his children went through the business and tried to figure out were he had left stuff. Dennis was the type that kept everything in his head and never wrote anything down, so this took awhile to figure out. Finally I got the dis***embled, motor back. Cylinder #1 still needed to be sleeved, and the block needed to be relieved to fit the rather large valves Dennis had stuck in the heads. So I brought the parts up to Hultgren's Engine and Machine in Hallock, Minnesota so they could finish the work. Gary and Stephen finished up the machine work, and discovered that the heads had been ported too far to fit the large valves, they would not be comfortable running them and recommend replacing the heads. So, a set of Edelbrock heads were ordered.
    Iron heads with the stainless 427 MR valves.
    With the machine work done, I brought the motor home and did the final ***embly.
    Completed and Ready to Run
    Finally, by April 2012, we got the motor on Hultgren's pump and broke it in.
    Final Combination
    1962 352 FE
    Bore: 4.030" Stroke: 3.5"
    9.5:1 Compression - Silvolite flat top pistons.
    Elgin 966P Hydraulic Cam
    FPA headers
    600 cfm Holley Four Barrel Carb
    Edelbrock Heads and Performer RPM intake
    Petronix Distributor and Ignition
    325 Hp, 375 ft-lbs of torque, with over 300 ft-lbs from 2500 rpm to 5500 rpm
    Hnstray, Sparked and kiwijeff like this.
  4. FrozenMerc
    FrozenMerc
    While the engine was away at Dennis's Engine Shop, I figured I had better get started on the body as there was ALOT of rust repair to do.
    There was no way I was going to tackle the floor repair on this big of a body with out a rotisserie. Once again, I was a bit short on funds, and I wanted a big heavy duty rotisserie, so I designed and built one.
    Now, I could get the body stripped and see just how extensive the rust was.
    Sand blasted clean.
    As can be seen, new rockers, quarters, and a floor were in order.
    Piece by piece, it came back together.
    Hnstray and kiwijeff like this.
  5. FrozenMerc
    FrozenMerc
    Eventually I got the floor, rockers and quarters replaced and was able to get the body back on the ch***is.
    Using the ch***is to stabilize the body, I could now replace the windshield and tailgate headers that were rusted out from mice nests. I ordered a rust free roof from a junkyard in Arizona and got to chopping.
    This is what the original windshield header looked like. Not good. The tailgate header was actually worse.
    All Better now.
    With the headers replaced, it was time to start fitting up the motor, trans, and other under the hood components.
    Hnstray likes this.
  6. FrozenMerc
    FrozenMerc
    Motor in for fit up.
    Steering Clearance
    Accessories mounted. The wife wanted air-conditioning, and I didn't want a big old ugly compressor sitting up were it was the first thing you saw when the hood was opened. So, I mounted it in the original generator location and put an alternator above it. Now the compressor is down low and out of view.
  7. FrozenMerc
    FrozenMerc
    The original fuel tank was a study in corrosion, so it had to go. The problem was that wagon tanks are not reproduced. 2 or 4 door, no problem, lots of options, wagon - not so much. So I decided to make one.
    The original suspect.
    Top and bottom.
    Flanged
    Bead Rolled for stiffness.
    Sides
    Welded.
    Finished and ready for paint and interior coating.
    At the same time, I also ordered a trans from Broader Performance. I have a rule about building cars, and I never build one with out an Overdrive transmission. So, Broader built up this AOD with the original Cruis-O-Matic bellhousing specifically for the Merc.
    Final Fit up.
  8. FrozenMerc
    FrozenMerc
    With the final fitup complete, the body came back off so I could finish the rolling ch***is. 2.5" stainless exhaust, new drive shaft, and all the plumbing.
    Rear suspension
    A Roller.
    The body went back on the rotisserie for under coating and firewall paint.
  9. FrozenMerc
    FrozenMerc
    I knew this project was starting to get out of hand after I found my self cutting and polishing the firewall and rad core support over my holiday break.
    Time to finish up the plumbing.
    By this point, the car had a date with the painters and I need to finish up the doors and front fenders. A little sand blasting, some more under coat and paint, and the wagon was starting to look like a car again.
    In June of 2013, I dropped the Merc off at Northern Muscle in Reynolds, North Dakota for final body work and paint.
    The plan was a two-tone panel paint job inspired by Watson and few of the other greats of the early 60's. Interior Sealed and Fat-Mat applied
    Filler being applied.
    Hnstray likes this.
  10. FrozenMerc
    FrozenMerc
    Masking and Primer
    We used the guide coat to start laying out ideas for the scallops, and two-tone
    Color Time.
    Pearl White Base Coat
    Door Jambs
    More Masking
    The roof
    Let the fun begin
    Paint Complete.
  11. FrozenMerc
    FrozenMerc
    I brought the car home Feb 2014, and started final ***embly.
    Bellflowers, of course
    Stainless all polished and ready for gl***. It also needed a new set of shoes. 15" Supremes and pinner white walls should fit the bill. At the same time, JR Plating in North Branch, MN was working on all the pot metal, replating it and getting back to perfect.
    The end was getting close, but the interior still needed to be finished. In July of 2014, I brought the car down to Stich ***** Upholstery in Stillwater, MN for the deluxe interior treatment. The interior pattern would follow the original patterns, but with colors to match the car.
    Headliner (prior to t*******)
    Carpet and Floor mats.
    Door panels.
    Back Seat.
    Cargo Area
    By October, Stich ***** had worked her magic, and I hauled the car home for one last time. It still need the dash and grill to be finished up.
    Stainless tube grill.
    Dash
    Cooon, whoodooman, Murphy32 and 3 others like this.
  12. FrozenMerc
    FrozenMerc
    And here we are, present day, lots of snow on the ground, and I am waiting for it to warm up a bit so I can take it in and get the front end aligned and AC charged. I have driven the car a bit, for shake down and to burnish the brakes. So far, it drives really nice and should be a fun cruiser this summer. I will keep this thread going as the last few things get updated.
    Murphy32 likes this.
  13. 76ironhead
    76ironhead
    Awesome build love the wagon that is a great color. The car turned out great
  14. oldrelics
    oldrelics
    from Calgary
    Love it. Good job.
  15. 2manycars2littletime
    Love it. Great color!
    Those Merc taillights are so cool.
  16. Un ****in believable!!! Bruce.
  17. James D
    James D
    Wow! What a result.
  18. FrozenMerc
    FrozenMerc
    Thanks guys, '62 was an off year for Mercury, and the Monterey's are fairly rare, with the wagons being even more so. Even though they share alot of components with the Galaxie's, there is still alot of Mercury specific stuff, and on numerous times, the good people of the HAMB pointed me in the right direction.
    2manycars:
    Your right about the tailights. Most customs have the taillights changed, but I just couldn't do that with these lights. They were a '62 Monterey only tailight and changing them would have been a crime.
  19. motoandy
    motoandy
    from MB, SC
    Great post, and great wagon. Thanks for sharing. Pure determination.
  20. HOTRODPRIMER
    HOTRODPRIMER
    Holy Cow,this wagon is amazing,beautiful work. HRP
  21. loveoftiki
    loveoftiki
    from Livonia,Mi
    Any tips on making that grill? Great car
  22. rob-redm
    rob-redm
    nice 62 Wagon ! had a 62 Monterey 2 dr hardtop....
    Bondo Slinger likes this.
  23. WOODEYE
    WOODEYE
    What Bruce said X two! You sir are a tr
  24. Kustom Komet
    Kustom Komet
    There is Nothing... Not a thing... None of the things... that I don't like about that wagon.
    -KK
  25. Amazing results considering what initially started as what most woould consider barely a rusty parts car, or less.
  26. FrozenMerc
    FrozenMerc
    Nominal likes this.
  27. FrozenMerc
    FrozenMerc
    Pulled the Merc out of the garage this morning and loaded it into the trailer. I brought it back down to Northern Muscle for a final detail job before it's first show in a couple of weeks. I am going to display it at the Duluth Motor Head Madness show and then 3 weeks later in Grand Forks at the Prime Steel Car show. It was a nice cool morning, so I also snapped a few pics and took her for a drive around town before loading it. -15 deg. F makes sure nothing is melted and the car stayed clean.
    Duluth Motorhead Madness
    http://motorheadmadnessmn.com/
    Prime Steel Car Show - Grand Forks
    http://www.primesteelcarclub.com/annualshows/
  28. Eagletucky
    Eagletucky
    So freakin awesome!!!
  29. No_Respect
    No_Respect
    from So-Cal
    WOW make me want to work on my 63 country sedan. The Merc turned out awesome
  30. vwdave30
    vwdave30
    Love it man i had a 63 colony park wagon
