Projects My First A, mostly traditional
Discussion in 'The Hokey Ass Message Board' started by wdglide, Oct 17, 2013.
  1. wdglide
    wdglide
    Well, I've lurkin, learnin and buildin for the past few months. Its my first traditional hot rod. I am shooting for a 60's era. I'm trying to use nothing newer that mid 60's. However, there will be a hyd clutch and the 9" is probably a '70. But being that I've never done this before, I don't have a yard full of parts or the connections. But I believe firmly in making what I have - work - and doing it myself.
    Life is getting in the way, so I'm hoping that this thread motivates me.
    The plan:
    30 Coupe body
    Chopped 3"
    Possibly a small channel??
    Flipped firewall
    1959 283
    Weiand/Stromberg 3 deuces
    1960 T-10
    Modified "A" frame
    Dropped "A" Front axle (not aftermarket)
    Split "A" front wishbone
    Reversed Eye Front "A" spring
    F1 front Brakes
    Wishboned 35/6 Radius Rods
    40 Front spring in the rear
    Early Bronco 9"
    40 front rims
    F1 rear rims
    Firestone Bias big/little
    I try to take photos when I think of it.
    NOW:
    THEN:
  2. wdglide
    wdglide
    A FEW MORE...
    BradinNC, kiwijeff, texkbc and 3 others like this.
  3. tfeverfred
    tfeverfred
    Very interesting build.
    volvobrynk likes this.
  4. landseaandair
    landseaandair
    from phoenix
    Even though it's just a 283 I wouldn't have so much faith in those rear bones taking much abuse. All their original purpose was is to act as stringers to beef up the torque tube which took all the rotational force, all 85 h.p. worth. You could add struts from the top center of the axle housing to the ends pretty easy and two poly bushings or tie rod ends up front may not be a bad idea too.
  5. patmanta
    patmanta
    from Woburn, MA
    Your work looks nice and clean! How are the pie-cut front bones working out?
  6. wdglide
    wdglide
    Thanks. A torque arm/bar is in the works. As are a LOT of details.
    The more I do, the more I gotta do!
    Stogy, volvobrynk and hipster like this.
  7. wdglide
    wdglide
    So far so good. I left it tacked in case I need to make last minute changes. Thanks!
  8. Looks good, nice and clean.
  9. scrap metal 48
    scrap metal 48
    Looks good so far.. I like the 3 pedals and the direction this build is going...
  10. joeycarpunk
    joeycarpunk
    from MN,USA
    Good looking project, traditionally inspired and no apologies needed for utilizing what you have for the rearend. Very clean looking build so far.
  11. wdglide
    wdglide
    Thanks.
    Started the firewall flip yesterday.
    30tudor, Stogy and volvobrynk like this.
  12. Corn Fed
    Corn Fed
    The way the OP has brought the wishbones together and attached them to a ball is the correct way to run bones with an open drive. Keeping them split with tie rod ends or bushings is wrong and will bind. Adding a strut form the center of the axle to the front near the pivot point would be a good addition.
    In my 28 PU, I am running a setup very similar to what the OP has shown. I wish I had added a strut in the center. I did add a plate at the front as well as some gussets right before the axle. It has held up for numerous miles over the past 7 years as well as a few trips down Mokan and I have had no problems. This is with a mild 312 Y-block and a 4 speed. I don't run it real hard, but I don't totally baby it either.
  13. HellsHotRods
    HellsHotRods
    X2 !!! those 36 bones will bend for sure under torque
    Sure, the OP did the bones in the right pattern with the ball,,,,but without a torque bar or tube you are asking for trouble.
    You need a 3rd bar so the axle doesn't twist, that's what a torque tube was for.
  14. wdglide
    wdglide
    Well, good thing I have a torque arm.
    Anyway..... Back to my build....
    Working on the firewall, tunnel and floor. I'll get some pics up in tomorrow.
  15. 26 T Ford RPU
    26 T Ford RPU
    What a cool build !! will follow this for sure. JW :)
  16. wdglide
    wdglide
    Some update photos.
    I spent a day working on the inner fender. A lot of work and I could have bought a panel for $30, but it's just not the same.
    ImageUploadedByH.A.M.B.1384957593.148100.jpg ImageUploadedByH.A.M.B.1384957607.661539.jpg ImageUploadedByH.A.M.B.1384957635.266788.jpg ImageUploadedByH.A.M.B.1384957652.913822.jpg
    kiwijeff, Stogy and volvobrynk like this.
  17. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Looks great so far! The patch panels on the wheel wells look great as well! How did you end up puttin the bead in?
  18. brady1929
    brady1929
  19. wdglide
    wdglide
    Thanks.
    Just finishing my first gas welding adventure. David Gardiners video motivated me to try it over MIG. Not as easy as he makes it out, but it definitely is easier to planish out the wrinkles.
  20. wdglide
    wdglide
    Sorry, missed your question...
    I used my trusty Harbor Freight part stamper. I have a thread on that in this forum.
  21. I like this build a lot! Nice job with the gas welding.
  22. crminal
    crminal
    Looks like a nice plan and should come out great at the rate you're going. Nice work.
  23. hipster
    hipster
    Another dead end... wonder what happened?
  24. Maybe he's so busy working on this, that he just don't have time for cyber rodding :D
    Least I hope so, I'd like to see it completed.:cool:
    26 T Ford RPU likes this.
  25. 26 T Ford RPU
    26 T Ford RPU
    Last seen on the HAMB in April 2013 !! Nice build and would be cool to see it to the end. JW
  26. fortynut
    fortynut
    Dang. I was looking forward to a 'Happy Ending' with him smoking the tires into the sunset. Oh well. Anyone know any more than is posted? It had all the right stuff by an obviously bright and motivated builder.
    kiwijeff likes this.
  27. wdglide
    wdglide
    I'm still here. I've lost some interest in the hamb after they changed the format/layout.
    I'm still working on the project but it's moving slow. Most recently I've got some help reinforcing the rear wishbone. I'm starting to plumb it now.
    I'll try and get a couple photos added. Thanks for the interest!
    volvobrynk, kiwijeff and patmanta like this.
  28. Binger
    Binger
    from wyoming
    This car is looking great! I had missed this one earlier. Subscribed!
  29. wdglide
    wdglide
  30. 26 T Ford RPU
    26 T Ford RPU
    Glad you are back and looking good( the car that is). JW:)
