Technical lowering 52-54 ford customline
Discussion in 'The Hokey Ass Message Board' started by corvairsixtyfour, Dec 8, 2014.
  1. corvairsixtyfour
    corvairsixtyfour
    from Pomona ca
    i have a 53 ford customline and i want to lower the rear first, whats the most i can lower the rear with out tunneling or notching? i was thinking for 4 inches? any one have pics of lowered 52-54 fords and how many inches they were lowered?
  2. greaser 35
    greaser 35
    from FRANCE
    My '54 dropped 4 inch block rear & aerostar coils front [​IMG]
  3. JeffB2
    JeffB2
    from Phoenix,AZ
  4. 39 chevy kustom
    39 chevy kustom
    My 53 ,4inch blocks on the rear and if I remember correctly 1 turn cut off front coils. Flathead, fordomatic. It is for sale
  5. 4 inch blocks with aerostar coils up front.
  6. CaseyB
    CaseyB
  7. CheatersPete
    CheatersPete
    Hello, Here is my frame, with rear notch , full air bag set up..., I will have to use dropped spindle to lower the front even more...
  8. 29tudor
    29tudor
    ImageUploadedByH.A.M.B.1426559675.506703.jpg ImageUploadedByH.A.M.B.1426559704.256144.jpg
    Here's my 52, Aerostar springs up front, lowered 6 1/2 inches in back (Jamco 4" drop springs n 2 1/2" steel drop blocks) I had to do some clearance work on the tunnel and c notch the frame. You shouldn't have to cut anything as long as you only do 4". Good luck!
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    We have had guys in the Social Group have tunnel issues with a 4" drop in the rear IF they had p***engers in the back seat,none with 3".
    61Lancerwagon likes this.
  10. Chevydeuce
    Chevydeuce
    2" dropped spindles up front
    2" blocks on worn out original leafs springs in the back
    750-14 tires
  11. Jeff Bohmann
    Jeff Bohmann
    Beautiful job.
  12. Jeff Bohmann
    Jeff Bohmann
    I know this is an older post. Just became a member to research ideas on building my 54 Customline project that I am just starting. Need much help, but this is exactly how I wanted to do my project.
  13. Jeff Bohmann
    Jeff Bohmann
    Do you still own this car?
  14. 54vicky
    54vicky
    you are better off sending him a PM
  15. Dan Brock
    Dan Brock
    Does anyone put in mustang 2 suspension? I have a 52 Customline I just started on and I have an entire mustang front end with cross member but it seems like everyone coverts to ball joints for $2k. I can find almost nothing on a mustang 2 suspension conversion.
    Do I even need to convert to ball joints for that matter? This isn't going to be anything but a rat rod to screw around in with an EFI 5.0 with a nice custom cam grind I've used on several cars and maybe a supercharger. I chopped it this weekend and built a carson top that needs to get upholstered now (roof was in bad shape).
    Any recommendations? Disc and power brake conversion? Do something with the steering? Aerostar springs for the front? I have a selection of blocks for the rear (I'll try for 4").
    I just don't want to re-invent the wheel on this one with trial and error. I want to get it done before it gets 8000 degrees outside and while I made a ton of headway in 2 days after I took it off the trailer and let it sit 4 years ago (no more girlfriend = more productivity).
    I have the back gl*** if anyone wants it (not sure what it would cost to box it up and ship it). I managed to remove it with no damage all by myself with my bucket truck.
    I've attached a picture for reference of this ugly pig. I cut and pasted in microsoft paint to get the drop I'm looking for and colored in my carson top (you can see the frame in the shadows on the seats).
  16. dan31
    dan31
    Check out some of the build threads on here and kinda look around the site. You aren't gonna find any rat rods .Hell, most guys will jump on ya for just saying that term [just say beater] . Tonnes of info on the best /most traditional ways to lower without breaking the bank or getting your project bogged down time wise. Have you considered white primer and full wheel covers ,would look good.
  17. Richard54shoe
    Richard54shoe
    What size wheels and tires?
  18. greaser 35
    greaser 35
    from FRANCE
    She run with a 15 inch and Firestone 670/15!!;)
