Technical Baffles for hot rod Megaphone exhaust?
Discussion in 'The Hokey Ass Message Board' started by underwk@hotmail.com, Jan 20, 2015.
  1. Hi,
    Does anyone know someone who could make or someone that sells baffles to fit a 2inch to 4 inch Magaphone exhaust pipe?
    Thanks Karl
  2. BillyG
    BillyG
    Google "Car Chemistry Automotive products" they sell baffle kits and individual components. I've made my own as well as using part of the internals of cherry bomb mufflers. They both did an adaquate job.
  3. scrap metal 48
    scrap metal 48
    Cut a gl***pac in half, shove each piece in a megaphone, drill hole in bottom for a set screw, finished the end for looks and go for a ride...
    1927graham and da34guy like this.
  4. 37hotrod
    37hotrod
  5. KiwiGlen
    KiwiGlen
  6. Martin Harris
    Martin Harris
  7. da34guy
    da34guy
    X2
  8. Don's Hot Rods
    Don's Hot Rods
    from florida
    I made a set of baffles for the 350 sbc in my 23, and it took an afternoon to do it all. They did drop the sound level about 50% and didn't hurt hp very much.
    First I bought a set of header gaskets to fit my flange and then I cut some flat steel to the same shape to act as my cap:
    Then I cut a couple of pieces of exhaust tubing from Advance Auto in half and punched a bunch of holes in each tube. I inserted a punch into each hole and used it to make each hole into a little scoop shaped deal:
    Then I welded the tube to the plate and bolted it on:
    We did the same thing with the 455 Olds in my Son's car, but he had no flange to bolt to, so we drilled a hole in the bottom of his cone and put a bolt through a tab we welded on his baffle. It dropped the sound level of that car way down too.
    We tried packing fibergl*** inside, even wrapped in stainless steel mesh, and it all blew out the first time we got on the car, so we pulled all that out and just went with the steel tubes. The fibergl*** also really hurt performance a lot.........car was stuffed up sounding too.
    Don
    The G00SE likes this.
  9. Just Gary
    Just Gary
    Don,
    How long are the pieces of exhaust tubing?
    When bolted in, do they extend all the way back up to the #7 and #8 cylinder exhaust tubes?
    Thanks!
  10. tikiwagon13
    tikiwagon13
    If you don't want to make some Google Empi stinger exhaust, I found some for $20
  11. Don's Hot Rods
    Don's Hot Rods
    from florida
    As I remember, they only went up to the furthest back exhaust tube so as not to block the flow and cause overheating of that cylinder, but I did them maybe 8 years ago, so I kinda forget.
    Don
  12. Kerrynzl
    Kerrynzl
  13. unkledaddy
    unkledaddy
  14. Thanks everyone there are great ideas. I'll let you know how things turn out.
