Technical Shoebox Ford with a 700r4..which speedo cable to use??
Discussion in 'The Hokey Ass Message Board' started by ab_51Ford, Jan 22, 2015.
  1. ab_51Ford
    ab_51Ford
    I would like to run the stock 1951 Ford gauges with speedometer. I was wondering what speedometer cable I needed to go from a SBC with a 700r4 to the original speedo?? Iv read that with a T350 you can run an original cable and was thinking the same could be done with the 700? Iv tried getting ahold of Chris at ShoeboxFord but no answer. Any help would be greatly appreciated
    Thanks fellas
    -Andrew
  2. squirrel
    probably depends what 700R4 you have? If it has the mechanical speedo gear in it, then you can treat it just like a TH350. and use a typical 1950s GM type speedometer cable.
  3. bobwop
    bobwop
    from Arley, AL
    I know the original cable works with a THM350. I am in agreement with Jim.
  4. e1956v
    e1956v
    Alliance Vendor
    Both transmission end nuts are 7/8-18 so yes it will work on a 700r4.
  5. paleot
    paleot
    from louisiana
    I used the original cable from my 51 F1 hooked to th 400 Gm trans, same threads. Only problem is speedometer registers correctly odometer runs backward!
  6. Kiwi 4d
    Kiwi 4d
    There is a guy on epay that offers mechanical speedo conversions and tell him your tyre height and diff gears and he will set you up.
    So the thought is we can run the original shoe box cable then?
  7. ab_51Ford
    ab_51Ford
    Thanks fellas, I really appreciate it!!
  8. Jalopy Joker
    Jalopy Joker
    used stock one in '51 with AOD but, needed a high mph speedo.
  9. paleot
    paleot
    from louisiana
    My cable was square, the GM adapter had a slip on plastic spline like a key. Slipped right over my cable like it was made for it. For reference if you need the cable adapter my trans came out of a 1989 GMC 3500 1 ton truck.
  10. famous59
    famous59
    from dallas, tx
