Projects 28 model A Coupe build--first time
Discussion in 'The Hokey Ass Message Board' started by reyn, Jan 25, 2015.
  1. reyn
    reyn
    First let me say it is impressive the amount of information here. I Joined the hamb in 06 and it didn't take long before I came to realize I needed to have a model A. Finished my Impala in 2010 and started collecting a few "A" parts. A few years ago I bought a 28 sedan body. last spring I found a 28 coupe which is what I really wanted. I started out thinking I can take my time building this coupe, but the further along I get the faster I want to get it done so I can wear it out. I've been putting a lot of miles on the 60 even though these summers are short. Now I will be able to drive later into fall and earlier in spring and in adverse weather with a solid roof and a heater.
    This is what I have been doing this last year since I retired.
    Making everything I can and buying what I can't make. Pure fun.
    Poured and machined adapters for the back and spacers for the front. 4.jpg 4a.JPG 4b.JPG 5.JPG 6.JPG 7.JPG 8a.JPG
    Cut 35 wire wheels down to 15" 8b.JPG 8c.JPG 9.JPG 9a.JPG Made a jig, dropped the axle 3". 9b.JPG Reversed spring eyes 9c.JPG 28 axle and spring, 48 Merc Spindles and wishbones which were flipped. 56 f100 drums 10b.jpg 10c.jpg 11.JPG 11a.JPG
    Ever since seeing flthd31 build a 32 frame, I knew I had to try it, although not quite as pretty as his. Added a 3" bleed sweep. 12.JPG 12a.JPG 13.JPG 13a.JPG 14.JPG 14a.JPG 14b.JPG 14c.JPG 14d.JPG
  2. Mr cheater
    Mr cheater
  3. reyn
    reyn
    Made 1/4 elliptical rear suspension out of 48 merc front spring. Made top arms and brackets and turned some bushings. 14f.JPG 15c.JPG 15d.JPG 15e.JPG
    Was going to build a 283, but a friend had one all ready rebuilt. Mated it to a nv3500 overdrive 16a.JPG 16b.JPG 16c.JPG
    Starting to look like a hot rod now. Going to have to cut the rad down quite a lot. 17a.JPG
    I like the adjustable rear suspension 18a.JPG 18d.JPG 18e.JPG 18f.JPG 19.JPG
    Trying to fit a clutch and brake pedals and exhaust, a little tight. 22.JPG 23.JPG
    That is about where I am now. I"ll post more as I go if your interested.
      203 KB
      236.4 KB
  4. gnichols
    gnichols
    from Tampa, FL
    Post away. Nice job on your ch***is. Gary
  5. pecker head
    pecker head
  6. scrap metal 48
    scrap metal 48
    Wow!! You've done a lot of work there.. Keep it up...
  7. mike bowling
    mike bowling
    A" Metal-Master " for sure-real nice work. Don't believe I've seen anyone on here make their own custom wires ( although I'm sure they have).Thanks for the pics- good stuff!
  8. captainjunk#2
    captainjunk#2
    you do some beautiful work , your very talented ,
  9. sharpmark
    sharpmark
    great work and great pictures !
    on that pcv adapter you made is that a proper pcv valve that screws in horizontal or is it hollow.?
    been thinking about doing the same to my 283
    thanks mark
  10. reyn
    reyn
    Thank you all for the compliments.
    As far as the pcv adapter thing. It just replaces the draft tube. The actual pcv valve will come out of the rear carb base. This is just a tube to hook the hose on.
  11. AVater
    AVater
    Wow--Nice work!
    1927graham likes this.
  12. bengeltiger
    bengeltiger
    Wow! You have skills! Subscribed, please keep posting. What year truck was this from?
  13. LTM75110
    LTM75110
    Looking good,Great build..
  14. reyn
    reyn
  15. reyn
    reyn
    It is from a 71 ford half ton. I think they were the same from around 69 to 76. Not exactly sure. It is long enough that I should not have to extend the shaft to make it through the cowl.
  16. missysdad1
    missysdad1
    Great project! Keep it up. I'm subscribed!
  17. rusty rocket
    rusty rocket
    You have some talent.
  18. oj
    oj
    I really like your approach and workmanship, 15" wires are incredible.
    You might want to rethink your quarter elips, I had similar, They really do need a shackle and lower control arm, the spring itself really can't act as the control arm. I do realize it is similar to the MG suspension but theres' lots of differences and right now is the time to evaluate. Have a look at Posies' kit, see what they did and why.
  19. modelacitizen
    modelacitizen
  20. reyn
    reyn
    Thanks for the kind words.
    As for the rear suspension, it is patterned after one in Malcolms build here on the hamb. I have been following it. He has been driving his roadster for the last couple years and I don't think he has had any issues at all with the rear suspension. The top arms being at an angle to the springs really keep the rear end stable with no sideways movement. If they were parallel there would be a problem. I have done a few things over on this project, there will be more. I am trying to research as much as I can as I go. Thank you for the input.
    Tim likes this.
  21. daddylama
    daddylama
    hot damn! pouring and machining, frame built from flat... awesome work so far!
    I've been planning on building a '32ish frame from flat for years... have the metal sitting on a shelf. that's as far as I got to date :)
  22. reyn
    reyn
    I took the frame off the jig for the last time and put the suspension back on. 33.JPG 34.JPG Shortened the driveshaft, painted it and installed the drivetrain. 35.JPG 36.JPG 37.JPG Made some motor mounts. they ended up 1/2" lower than planned. Might have to change them or shim them. 38.JPG 39.JPG 40.JPG 41.JPG 42.JPG 43.JPG 44.JPG Made some weld on adapters. not sure if that is the right name. 45.JPG 46.JPG 47.JPG 48.JPG 49.JPG Guess that is it for today.
  23. simplestone
    simplestone
    You're having WAY too much fun there! Wow, cool stuff and great workmanship.
  24. Oldbill51
    Oldbill51
    Very nice, I am working on a 29 roadster and using a 283 and a NV3500 as well. However I'm going with a Model A frame. Looking forward to seeing yours come together.
  25. Mike Colemire
    Mike Colemire
    Very nice build, your talent is amazing.
  26. King ford
    King ford
    from 08302
    Very nice....good photos too! More please!
  27. Corn Fed
    Corn Fed
    If everything is too tight on the left side for the pedal ***embly and exhaust, you might want to consider swinging the left exhaust pipe under the engine and running both pipes down the right side of the car. I did that on my '29 Coupe and it made things much easier.
  28. reyn
    reyn
    You know I never thought of that. It could work, although it is going to be a tight fit on the other side by the starter also. I just put it all together today and I will be working on the pedals next. I will have a better idea this coming week. Thank you for the input.
  29. manyolcars
    manyolcars
    Post three, the rear axle control arms. What happens if one rear wheel runs over a 4X4?
    Will the control arms break?
  30. reyn
    reyn
    I don't think so. What is your answer?
    Randall likes this.
