Technical Model A Front Spindle, Brake Backing Plate Sanity Check Please
Discussion in 'Traditional Hot Rods' started by Charlville, Jan 25, 2015.
  1. Charlville
    Charlville
    Hi All
    On my 29 Sport Coupe front end I currently have the following:
    37-41 round back spindles
    39-42 backing plates (horrible rusty :))
    46-48 hub/drum ***y's
    I have a nice set of 42 - 48 backing plates to replace the rusty 39-42's
    As far as I can tell these will bolt up to the 37-41 round back spindles without any modification?
    On the rear I also have another pair of rusty 39-42 backing plates which will also be replaced by a set of 42-48 backing plates, which I'll modify as per the instructions from Dennis Cling to clear the spring perch.
    Any help most welcome :)
  2. Charlville
    Charlville
  3. alchemy
    alchemy
    Sure the backing plates will interchange just fine. But make sure you get the correct year shoes and pivots as they are particular to the two versions of backing plates.
  4. Charlville
    Charlville
    Hi Alchemy
    Thanks for sanity check , I think (hope :)) I've got all the bits.
