Hot Rods 57 chevy truck power steering
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Jan 27, 2015.
  1. tb33anda3rd
    tb33anda3rd
    what have you guys used? is the CCP kit any good.
    the box on this truck is a mess so i prefer to change it. truck is also getting sbc and 700r4.
    Thanks
  2. squirrel
    still running manual steering on my 59, 38 years later. It's not hard to find a good deal on a used steering gear, and if you buy a few of them you can usually find one that is pretty nice, although even the nice ones need the pitman shaft bushing replaced, which isn't a real big deal.
    If you can show us a picture or part number of the kit you're thinking of buying, we might be able to offer some ideas. But if there is no picture of it, I wouldn't buy it
  3. tb33anda3rd
    tb33anda3rd
  4. squirrel
    That particular kit is not worth buying, the geometry is wrong. I've seen some guys try to use it...
    If you can find a kit that puts the new steering box where the original was, then it would probably work fine.
    The kit pictured here would be a good way to do it, but apparently it doesn't exist?
    http://www.chevytalk.org/fusionbb/showtopic.php?tid/290533/
  5. oldcars.acadia
    oldcars.acadia
  6. squirrel
    Ah, you found the picture. I had a lot of trouble navigating their web page. That might be the way to go, then.
  7. tb33anda3rd
    tb33anda3rd
    thanks squirrel and oldcars.acadia that the type of info i need.
  8. oldcars.acadia
    oldcars.acadia
    Their web page is near impossible !! :confused:
  9. tb33anda3rd
    tb33anda3rd
    is cpp a good company to work with?
  10. tb33anda3rd
    tb33anda3rd
    they had me confused too. speedway has their stuff and when i did a google search other companies sell their stuff.
  11. oldcars.acadia
    oldcars.acadia
    A friend has had good experience with them and there products have been very good. I plan to use the 400 kit on my 57 Cameo.
  12. 1959apache
    1959apache
    I have a 350 with a 700r4 ****** ps and pb. I have the 76 chevy truck gear box and a 78 Chevy van tilt column. I can take pictures if you want
    If I were to do it again I would just go with stock steering or do the Toyota gear box conversion. The pitch that you need for the steering column to input shaft is ridiculous. That is the only reason. I figured it out finally but I need to clean it up.
  13. tb33anda3rd
    tb33anda3rd
    thanks, i would like to see a picture anyway.
  14. tb33anda3rd
    tb33anda3rd
    thanks. if i go this route i will let you know.
