Projects Guernsey boys model A coupe build.
Discussion in 'Traditional Hot Rods' started by Guernsey boy, Feb 1, 2011.
  1. daddylama
    daddylama
    you're killin' it!
    (i mean that in a very good way)
  2. nickk
    nickk
    Still loving this build, over the last few nights I've been channeling my 30 ford coupe and used your idea just kinda made it my own, but worked great and super clean!
    moparob likes this.
  3. Thanks again for kind words! I'm always amazed at how many views and replies my silly little car gets on here!
    I pulled the body off the frame (hopefully for the final time) and flipped it upside down with the help of my brother and my mate Steve (thanks) to tidy up a few loose ends underneath.
    first job was to fabricate a 1" return lip on the cutout i made to clear the rear axle and spring.
    It would have looked weird if i'd have left the raised rib that ford pressed into the wheel well like that so i cut a small pie cut in it, and beat it flat with a hammer and dolly to terminate the rib a few inches higher up.
    One side done, one more to go!
    catdad49, Stogy, AHotRod and 2 others like this.
  4. nickk
    nickk
    Hell yeah, this is also my next process, good idea, I don't think I'll have to cut out so much but time will tell.
  5. jfg455
    jfg455
    from NH
    Just read the entire thread...amazing work.
  6. mad mikey
    mad mikey
    Love this build! Really nice work!
  7. neilswheels
    neilswheels
    from England
    Great Project, a lot of great work. I'm after an alternator that will look right on my 40, what have you used for yours?
    catdad49, Stogy, Strittan and 2 others like this.
  8. 1952B3b23
    1952B3b23
    from Western MA
    Just read through the entire build, very great work and the car looks awesome!
  9. Voh
    Voh
    Who's alternator is that? I like the looks of it!
  10. krkx93
    krkx93
    Just scrolled through this entire thread. Your quality of work is great and inspiring man! Keep it up!!
    volvobrynk likes this.
  11. Lukydevl
    Lukydevl
    from Arizona
    X-2 on the alternator???
    Killer skills on this build.. I dig it!!!
  12. nickk
    nickk
    have any pictures of the floor?
  13. nickk
    nickk
    or what you have so far?
  14. jamie34
    jamie34
    Think Neil used a powermaster alternator but took it apart and machined the casing down have to go back a few pages to see it. (Page13)
  15. Binger
    Binger
    from wyoming
    I have been watching this build for several years and I always am amazed at the beautiful fabrication work. I only hope to make parts that look this good.
  16. Lytles Garage
    Lytles Garage
    VERY NICE WORK !!!!!! Chris
  17. neatoldclassics
    neatoldclassics
    from Montana
    Outstanding skills and ideas!
  18. nickk
    nickk
    What size tires are those, looks like 7.50 on rear and 5.50 up front?
  19. KustomCandy
    KustomCandy
    from Australia
    Every so often you come across a build where a dude has the at***ude of "**** it, I'll build my own".
    Limited space, Limited tools, limited skills/experience (Dare I say time?). Hell Yes!
    Thats what I love about this Hobby (lifestyle).
    Seriously following.
    Dan
    RodNoc and yblock32 like this.
  20. Its a long GM style powergen that i took apart and shortened.
    I have a few loose ends to tie up on the floor so i'll get some pics soon.
    The fronts are 4.50-4.75 x 16, the rears are 7.00 x 16
    Thanks! And i do very often find myself saying "**** it, I'll build my own". mainly because it's literally impossible to buy any kind of hot rod parts or early ford parts on the island that i live on. There aren't even any shops here that sell imperial stainless bolts! Almost all of the stuff that i need i have to import from either mainland UK or USA which can be very expensive, difficult, and time consuming so i end up making a lot of parts. It's also a lot more satisfying that way.
    catdad49, Runnin shine and volvobrynk like this.
  21. i took my ch***is for a drive to my mate nicks place for him to sand blast so i could finish weld modifications.
    One of the wishbone mounts finish welded
    After i'd welded up all those pieces and god knows how many redundant holes i took it back to nicks for a good thick coat of black epoxy primer. Once i had it back at mine i spent an age flatting the primer back and putting a very light skim of filler on the rails to correct a few slightly low spots.
    I made a make shift paint booth for a few topcoats of black 2K (after priming the filled bits)
    Sneaky peek at the topcoat-
  22. Nick spent this morning blasting and priming my axles, torque tube, and wishones (cheers mate)
  23. In between the big stuff, i've been doing all the little finicky bits like radiusing the ends of both leaf springs and prepping all the little pieces which are now at the powder coaters. I can't wait to get them all back and start bolting stuff together!
  24. I have no idea if this upload will work or not, but hopefully its a short video of a MIG weld on one of the wishbone mounts.
  25. Welderboy60
    Welderboy60
    Cool....[emoji41]
  26. YJ4000
    YJ4000
    Very nice work. The frame looks fantastic. Did cleaning up the springs take a long time? That is a neat detail.
    Ryan.
  27. pearl31
    pearl31
    Great work, everytime I see this thread it makes me want to go to the garage and fab something.
  28. bucketmouth
    bucketmouth
    from Australia
    Great work,every time I see this thread it makes me want to go to the garage and refab something better.
    Cool build I like it.
  29. Not really, probably 15 mins per leaf.
  30. Got my first batch of parts back from the powder coaters
    But for these other parts i stripped all the old paint off with a wire wheel in a grinder and sprayed them with 2 part epoxy.
    I used a s**** piece of stainless to cut out some new shackle plates with my grinder because the old galvanised ones looked ****. Then i cleaned up and buffed them
    catdad49, Stogy, AHotRod and 5 others like this.
