Hot Rods mustang brake pedal
Discussion in 'The Hokey Ass Message Board' started by retiredave, Jan 30, 2015.
  1. retiredave
    retiredave
    from florida
    I have a 73' mustang brake pedal I would like to firewall mount on my 50 shoebox
    but I don`t have the master cylinder or booster.....anyone know what would fit? tks
  2. clem
    clem
    '73 mustang master and booster ???
  3. bobss396
    bobss396
    Naw... too easy, must be a trick question...
  4. retiredave
    retiredave
    from florida
    I think there should be something else to fit this besides a 73 .. thanks anyway
  5. HOTRODPRIMER
    HOTRODPRIMER
    Probably just about any Ford master cylinder or booster will work with a little fabrication. HRP
  6. BJR
    BJR
  7. retiredave
    retiredave
    from florida
    wow, why didn`t I think of that
  8. retiredave
    retiredave
    from florida
    Thanks for the napa quote .....thats a good price, I thought a later year would fit and be
    easier to find but I can pick this one tomorrow, thanks
  9. Sometimes captain obvious needs to show the way
  10. Awesome
  11. clem
    clem
    Having hand built my own brake pedal, working out stroke on master cylinder, pedal length, pivot length, mounting positions etc, believe me stick with what is known to work, ie all from one car, or be prepared for a bit of maths and fabrication......
  12. gimpyshotrods
    gimpyshotrods
    I am going to have to agree with the others.
    Your best bet is a '73 Mustang master cylinder and booster.
    Don't go cheap on your brakes.
  13. 48FordFanatic
    48FordFanatic
    from Maine
    Do you have drum-drum or disc-drum and is the napa unit compatible with what you have
  14. retiredave
    retiredave
    from florida
    I still have the original drum brakes, I just want to change to power
    and mount it on the firewall with this mustang pedal I found at a swap
    meet, the pedal comes down on the right side of the column so I`m
    hoping it won`t be to close if I mount it right over the steering column
  15. bobss396
    bobss396
    If the pedal came with all the brackets to mount it and now you have a master and booster that goes with it, it should work well for you.
  16. HOTRODPRIMER
    HOTRODPRIMER
