1959 Ford F-100 Custom Cab LWB The body is in amazing condition the cab has zero rust through! The only rust through on the whole truck is several little spots on the bed. The interior is fully intact. All the lights and gauges work. Truck runs and drives great. Will need tires to be driven a whole bunch due to some dry rot but they hold air and don't leak down. It has a Y-Block 292 v-8 engine and a 3-speed on the tree transmission. This is a great truck to buy to restore or to just drive as is (the patina is great looking!). The following are the parts that have been replaced since I bought it a month and a half ago. Brakes: All three rubber lines all steel lines replaced all four wheel cylinders shoes front and rear all four rotors turned master cylinder is good electrical: new battery new points new distributor cap and rotor new spark plugs cooling: reman water pump radiator checked by radiator shop fuel: new fuel pump carb rebuilt clutch: slave cylinder clutch line master cylinder is good I'm sure I missed something. I'm having trouble uploading pictures. Will get them up as soon as possible. I have good pictures on my phone that I can text or email easily. Call text or email for more info. Thanks, Cameron Michael ctmichael27@gmail.com 706-818-8667
Bump reasonable offers welcome! Would consider trade for a nice model a coupe or roadster body/ project! Posted using the Full Custom H.A.M.B. App!
