Projects "Pea Green" the '29 Tudor build
Discussion in 'The Hokey Ass Message Board' started by '52 F-3, Sep 14, 2014.
  1. 340HilbornDuster
    340HilbornDuster
    Dang Dude....you're like a Hot Rod Renaissance Man!
    You're widdling out (Really Cool) brackets, welding, drilling, engines, machining, painting, upholstery (checked your page) and all while watching football!...
    (Totally Dig Your 38 & the F-3!)
    Keep on Widdlin' & thanks again for the inspiration - Tommy
    '52 F-3 likes this.
  2. '52 F-3
    '52 F-3
    from Central PA
    finished rear brake scoops, decided to make on larger than previously drew.
    i uploaded some in process pics of the making, after cutting out football shaped 3/16" thick aluminum footballs, i hammer away until shape desired, it takes alot of test fits, but the aluminum shapes pretty easy. i then filed and sand (50 grit) 95% of the tool marks off, a few more test fits drilled and taped some holes etc...... later i sanded with 80, 100, 220 and red scotchbrite before polishing.
    55Deso, Stogy and fauj like this.
  3. Hotrodmyk
    Hotrodmyk
  4. 340HilbornDuster
    340HilbornDuster
    S'more Awe!
  5. '52 F-3
    '52 F-3
    from Central PA
    thanks for the compliments.
    finished rear plates, same as the front ones......... i know, kind of boring
  6. ROCKER77
    ROCKER77
    Definitely not boring. I am truly digging your build.
  7. Hotrodmyk
    Hotrodmyk
    NAW, kinda cool!
  8. bigheadbaxter
    bigheadbaxter
    I agree ⬆️. I want more but don't want it to end!!
  9. '52 F-3
    '52 F-3
    from Central PA
    I started cutting out a couple aluminum brackets and thought "these have an odd shape", how about another, "Guess what these are going to be"
    patmanta likes this.
  10. Leon Sandcastle
    Leon Sandcastle
    Um...... uh..... they look like some drawings we did in our school days..... not sure what they are, but they are gonna look fantastic if you're making them.
  11. 340HilbornDuster
    340HilbornDuster
    Front Shock Mounts?....OR.....
  12. '52 F-3
    '52 F-3
    from Central PA
    i should have put something in 1st picture for a size reference, it's 1/4" aluminum plate.
    this is the first test fit, and some "yankee 87" red clearance lights i'm changing to dual filament for rear parking light/turn signals. after much thinking i decided to mount on sides of my single rear brake/parking/license plate light.
    Stogy and ROCKER77 like this.
  13. '52 F-3
    '52 F-3
    from Central PA
    a little brown paint (frame color) on the housings and polish
  14. Finnrodder
    Finnrodder
    from Finland
    Wow,you really like to pay attention for the details.
    Good work!
    32Rules likes this.
  15. frdsuperduty
    frdsuperduty
    from Lewes De
    You must lay awake at nite thinking of new places to drill holes?Once you get a theme its tough to stop.Im doing the same on my current build.Love your work.Another friend of Bills.
    '52 F-3 likes this.
  16. '52 F-3
    '52 F-3
    from Central PA
    got rear painted.... need to measure and order some axle shafts, also trying to figure out what i'm going to do with factory drums. (if anything)
  17. Leon Sandcastle
    Leon Sandcastle
    Wow.... simply put, it's a piece of art.
  18. 340HilbornDuster
    340HilbornDuster
    I like your confidence...
    You build it, polish it / paint it right away...
    Where I live is + 95% humidity...
    You weld something...it's rusty the next day.
    I'll drive mine (if they call it a Ratrod..I'll %¢^]¥{™)
    Make sure it works and then paint it....
    Maybe next build?
    If I could paint it right away....!?
    Would save me lotso time...
    Thanks for sharing!
    Tommy
    Early Ironman likes this.
  19. '52 F-3
    '52 F-3
    from Central PA
    I'm sure i'll have to re-do a few things, but a lot i've done before so i have pretty good idea of were i'm going.
    I'm also kind of building this one bass ackwards, and eyeballing more than i should.... time will tell
  20. Terraizer
    Terraizer
    You do some nice work.
    '52 F-3 likes this.
  21. A+ for creativity
    A+ for craftsmanship
    '52 F-3 and ROCKER77 like this.
  22. TinShed
    TinShed
    Cool build!!!
    '52 F-3 likes this.
  23. '52 F-3
    '52 F-3
    from Central PA
    thanks for replies....
    going modify the 10 leaf rear spring i have. plan to reverse main spring, shorten 2nd, remove a couple and round/taper the ends.
  24. '52 F-3
    '52 F-3
    from Central PA
    a few hours on the band-saw and grinder...
    (removed 3, cut off short and put on the bottom to take up space for U-bolts to clamps tight) shorted, rounded and tapered all the others acouple inches. 4th from the top might be removed later if stance is too high.
    Early Ironman, ROCKER77 and Hotrodmyk like this.
  25. '52 F-3
    '52 F-3
    from Central PA
    got my axle shafts from "Moser", but need some bearings (ones i have aren't correct)..... starting to assemble brakes but need shorter wheel cylinder bleeders, everything is a very tight fit with this transverse spring mounted factory width.
    i really like the parking brake cables that came with the '51 F-1 axle, just cleaned up the drums with a sander and clear coated. I really like the look of things "worn through use"........
  26. 340HilbornDuster
    340HilbornDuster
    OMG That's Purdy!!!
  27. great progress, love it.
    Cheers,
    Drewfus
    '52 F-3 likes this.
  28. jeepers00creepers
    jeepers00creepers
  29. '52 F-3
    '52 F-3
    from Central PA
    thanks for nice comments! jeepers, i figure i'll be ready for Jalopy Showdown 2016 (also i only have stock model a parts, sorry)
    garage looks like a bomb went off, but did get the body off and sitting stable on lift. next is to strip and start modifying frame just a little, plan to box, build a custom cross-member install a 239/255 with a "cough, couch" automatic tranny. also been considering some flourishing holes
