Technical led turn incicators
Discussion in 'The Hokey Ass Message Board' started by ace43, Feb 1, 2015.
  1. ace43
    ace43
    from Seattle
    I want to use led lights for turn indicators on my 28'ford hotrod, but they won't flash. Do I need to add a resistor or what? Thanks, ace43
  2. HOTRODPRIMER
    HOTRODPRIMER
    You will probably have to use a LED flasher. HRP
    lothiandon1940 likes this.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    They probably don't draw enough current to cause the flasher can to cycle. You'll probably have to find circuitry that has a timed pulse to the LED.
    I had a friend who built a 3-axle 30 foot long trailer using all LEDs. The total amp draw at the hitch plug was 1 amp.
  4. 56 Dodge Pickup
    56 Dodge Pickup
    Definitely going to need an LED flasher Jim
  5. mike bowling
    mike bowling
    LED's ? ( like in Zeppelin?)
  6. Kiwi 4d
    Kiwi 4d
    Have you got LED front and rear? If you can run a bulb at the front and use the LED style brake lights you will be away .
  7. pro64tempest
    pro64tempest
    Use an electronic flasher from united pacific.....it has a ground wire you must hook up...this will cure the issue you are having
  8. blazedogs
    blazedogs
  9. nmpontiac
    nmpontiac
    from Taos, NM
    Are you talking about using LEDs for turn signals or indicators on the dash?
  10. blazedogs
    blazedogs
    I've run into this issue also with LED lights.No Luck with United Pacific,.can't seem to find flashers on their websight. Do you have to run 2 separate flashers when you use several LED Bulbs. .A necessity now-a -days in a rod, a 3rd LED brakelight in the back window. People are not attentive when they drive anymore.I want to blind them when I step on the brake pedal....... Gene
  11. Joe H
    Joe H
    If the lights flash on the corners of the car using a standard flasher, the LED's should also flash if wired into the mix. Where you have problems is with all LEDs and the old style by-metal flash. This type of flasher unit needs to see a pretty good load to heat up inside and turn it self on and off and LED's just pull enough juice to make them work. Adding a few LED's will not alter the original system or keep it from working.
    Check here for LED and resister information.
    http://www.petervis.com/electronics/led/led-resistor-calculator.html
    You may simply have them wired backwards, as they only work one way.
    Joe
  12. Mr48chev
  13. mj40's
    mj40's
  14. Max Gearhead
    Max Gearhead
    from Wisconsin
  15. Ohiovette
    Ohiovette
    I have been selling LED tail lights and front parking lights for 56 to 67 Corvettes for years.
    Typically if you just put in tail lights and use incandescent parking lights a electronic flasher is not needed. But some times it is due to low resistance bulbs.
    With front and rear LED's the flasher is required or you can put load resistors in the circuit, not recommended because they can get real hot.
    I like United Pacific's flasher since it uses a dedicated ground wire. Get PN 90652 which comes with a polarity reverser which is needed in some cases.
    Sometimes LED lights can screw up some electronics such as cruise control.
    Cheapest price is on Ebay.
  16. pro64tempest
    pro64tempest
    united pacific part#90650 two terminal.....90651 for three terminal styles.......i use them in all led applications and they always work fine....
